<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem, nach Update läuft web.0 Adapter nicht mehr]]></title><description><![CDATA[<p dir="auto">Hallo Zusammen,</p>
<p dir="auto">ich benötige euere Hilfe.</p>
<p dir="auto">ich habe seit langem mal npm (8.15.0), node-js (v16.17.1), und js.controller geupdatet.<br />
Es läuft auch soweit das meiste, allerdings die web.0 Instanz nicht, die ist allerings ja auch wichtig für Vis.</p>
<pre><code>2022-09-29 21:56:37.720 - info: host.raspberrypi "system.adapter.web.0" disabled
2022-09-29 21:56:50.398 - info: host.raspberrypi "system.adapter.web.0" enabled
2022-09-29 21:56:50.525 - info: host.raspberrypi instance system.adapter.web.0 started with pid 13698
2022-09-29 21:56:55.110 - info: web.0 (13698) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v16.17.1, js-controller: 4.0.23
2022-09-29 21:56:55.208 - error: web.0 (13698) uncaught exception: Cannot read properties of undefined (reading 'getObjectView')
2022-09-29 21:56:55.211 - error: web.0 (13698) TypeError: Cannot read properties of undefined (reading 'getObjectView')
at getExtensionsAndSettings (/opt/iobroker/node_modules/iobroker.web/main.js:264:21)
at main (/opt/iobroker/node_modules/iobroker.web/main.js:297:5)
at Immediate. (/opt/iobroker/node_modules/iobroker.web/main.js:192:25)
at processImmediate (node:internal/timers:468:21)
2022-09-29 21:56:55.212 - error: web.0 (13698) Cannot read properties of undefined (reading 'getObjectView')
2022-09-29 21:56:55.225 - info: web.0 (13698) terminating
2022-09-29 21:56:55.228 - warn: web.0 (13698) Terminated (UNCAUGHT_EXCEPTION): Without reason
2022-09-29 21:56:55.859 - error: host.raspberrypi instance system.adapter.web.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/58470/problem-nach-update-läuft-web-0-adapter-nicht-mehr</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 02:58:55 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/58470.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 29 Sep 2022 20:39:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem, nach Update läuft web.0 Adapter nicht mehr on Tue, 04 Oct 2022 20:21:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> 🤣 stimmt, dem hab ich gar keine Beachtung geschenkt</p>
]]></description><link>https://forum.iobroker.net/post/868374</link><guid isPermaLink="true">https://forum.iobroker.net/post/868374</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 04 Oct 2022 20:21:43 GMT</pubDate></item><item><title><![CDATA[Reply to Problem, nach Update läuft web.0 Adapter nicht mehr on Tue, 04 Oct 2022 20:16:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> sagte in <a href="/post/868367">Problem, nach Update läuft web.0 Adapter nicht mehr</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jofeh88" aria-label="Profile: jofeh88">@<bdi>jofeh88</bdi></a> sagte in <a href="/post/868364">Problem, nach Update läuft web.0 Adapter nicht mehr</a>:</p>
<blockquote>
<p dir="auto">ERR! ENOTEMPTY: directory not empty,</p>
</blockquote>
<p dir="auto">Dazu gibt es einen extra Thread, hab ihn nur gerade nicht zur Hand</p>
</blockquote>
<p dir="auto">das ist der oben angepinnte Thread zu ERROR 25</p>
]]></description><link>https://forum.iobroker.net/post/868369</link><guid isPermaLink="true">https://forum.iobroker.net/post/868369</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Tue, 04 Oct 2022 20:16:55 GMT</pubDate></item><item><title><![CDATA[Reply to Problem, nach Update läuft web.0 Adapter nicht mehr on Tue, 04 Oct 2022 20:14:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jofeh88" aria-label="Profile: jofeh88">@<bdi>jofeh88</bdi></a> sagte in <a href="/post/868364">Problem, nach Update läuft web.0 Adapter nicht mehr</a>:</p>
<blockquote>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/868367</link><guid isPermaLink="true">https://forum.iobroker.net/post/868367</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 04 Oct 2022 20:14:39 GMT</pubDate></item><item><title><![CDATA[Reply to Problem, nach Update läuft web.0 Adapter nicht mehr on Tue, 04 Oct 2022 20:08:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a></p>
<p dir="auto">Vielen Dank, die Vis ist wieder erreichbar, es fehlen nur ein paar Icons aber die füge ich wieder händisch ein.</p>
<p dir="auto">Aber jetzt lassen keine Adapter mehr installieren, hier ein Beispiel Backitup, damit mir das nicht mehr passiert :-)</p>
<p dir="auto">Hier die Systemdaten:</p>
<pre><code>pi@raspberrypi:/opt/iobroker $ uname -m &amp;&amp; type -P nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; iob -v &amp;&amp; whoami &amp;&amp; groups &amp;&amp; pwd &amp;&amp; sudo apt update &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
armv7l
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v16.17.1
v16.17.1
8.15.0
4.0.23
pi
pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
/opt/iobroker
OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
OK:2 http://archive.raspberrypi.org/debian buster InRelease
OK:3 https://deb.nodesource.com/node_16.x buster InRelease
Alle Pakete sind aktuell.
nodejs:
  Installiert:           16.17.1-deb-1nodesource1
  Installationskandidat: 16.17.1-deb-1nodesource1
  Versionstabelle:
 *** 16.17.1-deb-1nodesource1 500
        500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
        100 /var/lib/dpkg/status
     10.24.0~dfsg-1~deb10u1 500
</code></pre>
<p dir="auto">Und hier der Debug bei der Installation</p>
<pre><code>pi@raspberrypi:/opt/iobroker $ iobroker add backitup --debug                    NPM version: 8.15.0
Installing iobroker.backitup@2.4.12... (System call)
npm ERR! code ENOTEMPTY
npm ERR! syscall rename
npm ERR! path /opt/iobroker/node_modules/jsonwebtoken/node_modules/ms
npm ERR! dest /opt/iobroker/node_modules/jsonwebtoken/node_modules/.ms-oreSIGgs
npm ERR! errno -39
npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/jsonwebtoken/node_modules/ms' -&gt; '/opt/iobroker/node_modules/jsonwebtoken/node_modules/.ms-oreSIGgs'
npm ERR!     /home/iobroker/.npm/_logs/2022-10-04T20_06_12_683Z-debug-0.log
host.raspberrypi Cannot install iobroker.backitup@2.4.12: 217
</code></pre>
]]></description><link>https://forum.iobroker.net/post/868364</link><guid isPermaLink="true">https://forum.iobroker.net/post/868364</guid><dc:creator><![CDATA[Jofeh88]]></dc:creator><pubDate>Tue, 04 Oct 2022 20:08:26 GMT</pubDate></item><item><title><![CDATA[Reply to Problem, nach Update läuft web.0 Adapter nicht mehr on Fri, 30 Sep 2022 09:28:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jofeh88" aria-label="Profile: jofeh88">@<bdi>jofeh88</bdi></a> sagte in <a href="/post/865792">Problem, nach Update läuft web.0 Adapter nicht mehr</a>:</p>
<blockquote>
<p dir="auto">ein gesamtes Update aller Adapter gemacht</p>
</blockquote>
<p dir="auto">ein update oder upload?</p>
<p dir="auto">irgendwas stimmt mit deinem jquery-ui-timepicker-addon nicht</p>
<pre><code>iobroker upload all
</code></pre>
<p dir="auto">mal probieren</p>
]]></description><link>https://forum.iobroker.net/post/865865</link><guid isPermaLink="true">https://forum.iobroker.net/post/865865</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Fri, 30 Sep 2022 09:28:22 GMT</pubDate></item><item><title><![CDATA[Reply to Problem, nach Update läuft web.0 Adapter nicht mehr on Fri, 30 Sep 2022 08:59:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jofeh88" aria-label="Profile: jofeh88">@<bdi>jofeh88</bdi></a></p>
<p dir="auto">Vielleicht hilft diese Info noch aus der Console:</p>
<pre><code>jquery-ui-timepicker-addon-1.6.3.css:1          Failed to load resource: the server responded with a status of 404 (Not Found)
jquery-ui-timepicker-addon-1.6.3.js:1          Failed to load resource: the server responded with a status of 404 (Not Found)
fritzdect.js:46 Version fritzdect: 0.0.2
info.js:21 Version Info-Adapter-Widget: 0.0.9
edit.html:4522 Version vis-jqui-mfd: 1.0.12
edit.html:9368 Metro version: "1.2.0"
edit.html:15597 Version vis-weather: 2.5.6
edit.html:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247559
    at JSON.parse (&lt;anonymous&gt;)
    at getTranslation (info.js:13:47)
conn.js:273 2022-09-30T08:55:56.644Z Connected =&gt; authenticate
conn.js:293 2022-09-30T08:55:57.176Z Authenticated: true
DevTools failed to load source map: Could not load content for http://192.168.10.30:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
</code></pre>
]]></description><link>https://forum.iobroker.net/post/865848</link><guid isPermaLink="true">https://forum.iobroker.net/post/865848</guid><dc:creator><![CDATA[Jofeh88]]></dc:creator><pubDate>Fri, 30 Sep 2022 08:59:49 GMT</pubDate></item><item><title><![CDATA[Reply to Problem, nach Update läuft web.0 Adapter nicht mehr on Fri, 30 Sep 2022 08:55:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a></p>
<p dir="auto">Leider habe ich nur ein sehr altes Backup und ich komme auch nicht in das Start-Projekt.</p>
<p dir="auto"><img src="/assets/uploads/files/1664528120610-unbenannt.jpg" alt="Unbenannt.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Ich hoffe man kann die Visualisierung irgendwie retten, liegt die nicht irgendwo auf der SD-Karte (sorry kein Fachmann)</p>
]]></description><link>https://forum.iobroker.net/post/865842</link><guid isPermaLink="true">https://forum.iobroker.net/post/865842</guid><dc:creator><![CDATA[Jofeh88]]></dc:creator><pubDate>Fri, 30 Sep 2022 08:55:40 GMT</pubDate></item><item><title><![CDATA[Reply to Problem, nach Update läuft web.0 Adapter nicht mehr on Fri, 30 Sep 2022 08:26:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jofeh88" aria-label="Profile: jofeh88">@<bdi>jofeh88</bdi></a> sagte in <a href="/post/865792">Problem, nach Update läuft web.0 Adapter nicht mehr</a>:</p>
<blockquote>
<p dir="auto">Es kommt nur loading values,</p>
</blockquote>
<p dir="auto">Hole dein Projekt aus einem Backup ... siehe hier :</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/58056/gel%C3%B6st-vis-projekt-l%C3%A4dt-nicht-mehr">https://forum.iobroker.net/topic/58056/gelöst-vis-projekt-lädt-nicht-mehr</a></p>
]]></description><link>https://forum.iobroker.net/post/865821</link><guid isPermaLink="true">https://forum.iobroker.net/post/865821</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Fri, 30 Sep 2022 08:26:33 GMT</pubDate></item><item><title><![CDATA[Reply to Problem, nach Update läuft web.0 Adapter nicht mehr on Fri, 30 Sep 2022 07:32:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jofeh88" aria-label="Profile: jofeh88">@<bdi>jofeh88</bdi></a></p>
<p dir="auto">ein kleine Update: web.0 läuft jetzt, habe noch Einmal ein gesamtes Update aller Adapter gemacht.</p>
<p dir="auto">Nun komme ich allerdings nicht mehr auf die Visualisierung:</p>
<p dir="auto">Es kommt nur loading values, auch die Start-Vis kann nicht geöffnet werden</p>
<p dir="auto"><img src="/assets/uploads/files/1664523113782-unbenannt.jpg" alt="Unbenannt.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/865792</link><guid isPermaLink="true">https://forum.iobroker.net/post/865792</guid><dc:creator><![CDATA[Jofeh88]]></dc:creator><pubDate>Fri, 30 Sep 2022 07:32:59 GMT</pubDate></item></channel></rss>
