<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Viessmann.0 vcontrold]]></title><description><![CDATA[<p dir="auto">Hallo</p>
<p dir="auto">Ich nutze schon längere Zeit den alten viessmann Adapter mit vcontrold und der Optolink Schnittstelle ohne Probleme<br />
In den letzten Tagen habe ich damit Probleme.<br />
Wenn ich ihn manuell starte, läuft er einige Minuten, verliert die Verbindung und bleibt gelb.</p>
<pre><code>2022-09-23 07:23:02.474 - debug: viessmann.0 (2620) Redis Objects: Use Redis connection: 0.0.0.0:9001
2022-09-23 07:23:02.618 - debug: viessmann.0 (2620) Objects client ready ... initialize now
2022-09-23 07:23:02.631 - debug: viessmann.0 (2620) Objects create System PubSub Client
2022-09-23 07:23:02.632 - debug: viessmann.0 (2620) Objects create User PubSub Client
2022-09-23 07:23:02.746 - debug: viessmann.0 (2620) Objects client initialize lua scripts
2022-09-23 07:23:02.781 - debug: viessmann.0 (2620) Objects connected to redis: 0.0.0.0:9001
2022-09-23 07:23:02.785 - silly: viessmann.0 (2620) redis psubscribe cfg.o.system.user.*
2022-09-23 07:23:02.843 - silly: viessmann.0 (2620) redis psubscribe cfg.o.enum.*
2022-09-23 07:23:02.848 - silly: viessmann.0 (2620) objectDB connected
2022-09-23 07:23:02.855 - debug: viessmann.0 (2620) Redis States: Use Redis connection: 0.0.0.0:9000
2022-09-23 07:23:02.974 - debug: viessmann.0 (2620) States create System PubSub Client
2022-09-23 07:23:02.975 - debug: viessmann.0 (2620) States create User PubSub Client
2022-09-23 07:23:03.109 - debug: viessmann.0 (2620) States connected to redis: 0.0.0.0:9000
2022-09-23 07:23:03.110 - silly: viessmann.0 (2620) statesDB connected
2022-09-23 07:23:03.719 - info: viessmann.0 (2620) starting. Version 1.3.7 in /opt/iobroker/node_modules/iobroker.viessmann, node: v14.19.3, js-controller: 4.0.23
2022-09-23 07:23:03.769 - silly: viessmann.0 (2620) States system redis pmessage system.adapter.viessmann.0.logLevel/system.adapter.viessmann.0.logLevel:{"val":"silly","ack":true,"ts":1663910583753,"q":0,"from":"system.adapter.viessmann.0","lc":1663910583753}
2022-09-23 07:23:03.778 - info: viessmann.0 (2620) Connect with Viessmann sytem!
2022-09-23 07:23:03.779 - debug: viessmann.0 (2620) Commands for polling: getTempSpeicher
2022-09-23 07:23:03.780 - debug: viessmann.0 (2620) Commands for polling: getTempA
2022-09-23 07:23:03.780 - debug: viessmann.0 (2620) Commands for polling: getTempWWist
2022-09-23 07:23:03.780 - debug: viessmann.0 (2620) Commands for polling: getTempWWsoll
2022-09-23 07:23:03.781 - debug: viessmann.0 (2620) Commands for polling: getTempKist
2022-09-23 07:23:03.781 - debug: viessmann.0 (2620) Commands for polling: getTempKsoll
2022-09-23 07:23:03.781 - debug: viessmann.0 (2620) Commands for polling: getTempVListM2
2022-09-23 07:23:03.782 - debug: viessmann.0 (2620) Commands for polling: getTempVLsollM2
2022-09-23 07:23:03.782 - debug: viessmann.0 (2620) Commands for polling: getBrennerStatus
2022-09-23 07:23:03.782 - debug: viessmann.0 (2620) Commands for polling: getPumpeStatusM1
2022-09-23 07:23:03.783 - debug: viessmann.0 (2620) Commands for polling: getPumpeStatusSp
2022-09-23 07:23:03.783 - debug: viessmann.0 (2620) Commands for polling: getPumpeStatusM2
2022-09-23 07:23:03.784 - debug: viessmann.0 (2620) Wait for next run: 60000 in ms
2022-09-23 07:24:03.785 - debug: viessmann.0 (2620) Next poll: heartbeat (For Object: heartbeat)
2022-09-23 07:24:03.792 - debug: viessmann.0 (2620) Next poll: getTempVLsollM2 (For Object: TempVLsollM2)
2022-09-23 07:25:00.207 - info: host.iobroker instance system.adapter.dwd.0 started with pid 2760
2022-09-23 07:25:03.725 - info: dwd.0 (2760) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.19.3, js-controller: 4.0.23
2022-09-23 07:25:04.422 - info: dwd.0 (2760) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2022-09-23 07:25:05.005 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2022-09-23 07:26:03.808 - error: viessmann.0 (2620) Timeout connection error!
2022-09-23 07:26:03.810 - info: viessmann.0 (2620) Connection with Viessmann system disconnected!
</code></pre>
<p dir="auto">Adapter läuft auf einem Raspi als Slave. System ist aktuell.<br />
Hat jemand eine Idee?</p>
<p dir="auto">Gruß<br />
Happyuser20</p>
]]></description><link>https://forum.iobroker.net/topic/58238/viessmann-0-vcontrold</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 11:04:45 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/58238.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Sep 2022 05:31:43 GMT</pubDate><ttl>60</ttl></channel></rss>
