<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[InfluxDB ständig Warnmeldungen]]></title><description><![CDATA[<p dir="auto">Kann mir vielleicht einer sagen warum ich ständig Warnmeldungen bekommen ?</p>
<p dir="auto">Ich habe Variablen erstellt und diese werden aus einem Json String per Skript beschrieben.</p>
<p dir="auto">Aber ich bekomme immer wieder ständig Warnmeldungen.</p>
<pre><code>influxdb.0
2022-08-08 02:50:27.608	info	Add point that had error for 0_userdata.0.Batterie.gesamtKapazität to buffer again, error-count=7
influxdb.0
2022-08-08 02:50:27.608	warn	Error on writePoint("{"value":7163.9039999999995,"time":"2022-08-08T00:50:17.539Z","from":"system.adapter.javascript.0","q":0,"ack":false}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
influxdb.0
2022-08-08 02:50:27.605	info	Add point that had error for 0_userdata.0.Batterie.gesamtKapazität to buffer again, error-count=6
influxdb.0
2022-08-08 02:50:27.604	warn	Error on writePoint("{"value":7164.416000000001,"time":"2022-08-08T00:50:16.545Z","from":"system.adapter.javascript.0","q":0,"ack":false}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
influxdb.0
2022-08-08 02:50:27.553	info	Add point that had error for 0_userdata.0.Batterie.LadeEntladeStrom to buffer again, error-count=9
influxdb.0
2022-08-08 02:50:27.552	warn	Error on writePoint("{"value":-5.18,"time":"2022-08-08T00:50:17.445Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
influxdb.0
2022-08-08 02:50:27.542	info	Add point that had error for 0_userdata.0.Batterie.verbleibendeKapazität to buffer again, error-count=4
influxdb.0
2022-08-08 02:50:27.542	warn	Error on writePoint("{"value":139.92,"time":"2022-08-08T00:50:17.445Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
influxdb.0
2022-08-08 02:50:27.540	info	Add point that had error for 0_userdata.0.Batterie.verbleibendeKapazität to buffer again, error-count=3
influxdb.0
2022-08-08 02:50:27.540	warn	Error on writePoint("{"value":139.93,"time":"2022-08-08T00:50:16.442Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
influxdb.0
2022-08-08 02:50:27.500	info	Add point that had error for 0_userdata.0.Batterie.ZellenSpannungen.Zelle9 to buffer again, error-count=6
influxdb.0
2022-08-08 02:50:27.499	warn	Error on writePoint("{"value":3.29,"time":"2022-08-08T00:50:17.444Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
influxdb.0
2022-08-08 02:50:27.464	info	Add point that had error for 0_userdata.0.Batterie.Temperaturen.ZellTemp1 to buffer again, error-count=8
influxdb.0
2022-08-08 02:50:27.464	warn	Error on writePoint("{"value":22.9,"time":"2022-08-08T00:50:17.444Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
influxdb.0
2022-08-08 02:50:26.576	info	Add point that had error for shelly.0.SHEM-3#C45BBE785A7F#1.Total.InstantPower to buffer again, error-count=9
influxdb.0
2022-08-08 02:50:26.576	warn	Error on writePoint("{"value":13.02,"time":"2022-08-08T00:50:16.538Z","from":"system.adapter.shelly.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
influxdb.0
2022-08-08 02:50:26.575	info	Add point that had error for 0_userdata.0.Batterie.LadeEntladeStrom to buffer again, error-count=8
influxdb.0
2022-08-08 02:50:26.575	warn	Error on writePoint("{"value":-5.4,"time":"2022-08-08T00:50:16.442Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
influxdb.0
2022-08-08 02:50:26.566	info	Add point that had error for 0_userdata.0.Batterie.BatterieSpannung to buffer again, error-count=4
influxdb.0
2022-08-08 02:50:26.566	warn	Error on writePoint("{"value":52.68,"time":"2022-08-08T00:50:16.442Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
influxdb.0
2022-08-08 02:50:26.565	info	Add point that had error for 0_userdata.0.Batterie.BatterieSpannung to buffer again, error-count=3
influxdb.0
2022-08-08 02:50:26.564	warn	Error on writePoint("{"value":52.69,"time":"2022-08-08T00:50:15.448Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: {"error":"timeout"} / "{\"error\":\"timeout\"}\n""
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/56997/influxdb-ständig-warnmeldungen</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 21:07:31 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/56997.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Aug 2022 13:47:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to InfluxDB ständig Warnmeldungen on Mon, 08 Aug 2022 19:27:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcu" aria-label="Profile: mcu">@<bdi>mcu</bdi></a></p>
<p dir="auto">Vielen Dank für den Hinweis. Das werde ich mir mal anschauen.</p>
]]></description><link>https://forum.iobroker.net/post/839765</link><guid isPermaLink="true">https://forum.iobroker.net/post/839765</guid><dc:creator><![CDATA[Yoshi]]></dc:creator><pubDate>Mon, 08 Aug 2022 19:27:30 GMT</pubDate></item><item><title><![CDATA[Reply to InfluxDB ständig Warnmeldungen on Mon, 08 Aug 2022 13:59:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yoshi" aria-label="Profile: yoshi">@<bdi>yoshi</bdi></a><br />
<a href="https://github.com/ioBroker/ioBroker.influxdb/issues/96" rel="nofollow ugc">https://github.com/ioBroker/ioBroker.influxdb/issues/96</a><br />
Schau dir den Link zum influxdb-Kommentar an.</p>
]]></description><link>https://forum.iobroker.net/post/839644</link><guid isPermaLink="true">https://forum.iobroker.net/post/839644</guid><dc:creator><![CDATA[MCU]]></dc:creator><pubDate>Mon, 08 Aug 2022 13:59:33 GMT</pubDate></item></channel></rss>
