<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Gelöst -- iobroker startet nicht mehr]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">ich wollte den Adapter Solarman PV installieren und bekomme seitdem  iobroker nicht mehr zum Laufen. Beim Kommando "iobroker update -i" oder "iobroker list instances" kommt nur noch das hier:</p>
<pre><code>node:internal/modules/cjs/loader:936
  throw err;
Error: Cannot find module './lib/setup'
Require stack:
- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
    at Function.Module._load (node:internal/modules/cjs/loader:778:27)
    at Module.require (node:internal/modules/cjs/loader:1005:19)
    at require (node:internal/modules/cjs/helpers:102:18)
    at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
    at Module._compile (node:internal/modules/cjs/loader:1105:14)
    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
    at Module.load (node:internal/modules/cjs/loader:981:32)
    at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]
</code></pre>
<p dir="auto"><strong>MOD-EDIT: Code in code-tags gesetzt!</strong></p>
]]></description><link>https://forum.iobroker.net/topic/56389/gelöst-iobroker-startet-nicht-mehr</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 09:31:36 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/56389.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Jul 2022 13:14:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Gelöst -- iobroker startet nicht mehr on Sat, 16 Jul 2022 15:33:57 GMT]]></title><description><![CDATA[<p dir="auto">Hat sich erledigt, habe das Backup eingespielt.</p>
]]></description><link>https://forum.iobroker.net/post/828666</link><guid isPermaLink="true">https://forum.iobroker.net/post/828666</guid><dc:creator><![CDATA[lesiflo]]></dc:creator><pubDate>Sat, 16 Jul 2022 15:33:57 GMT</pubDate></item><item><title><![CDATA[Reply to Gelöst -- iobroker startet nicht mehr on Sat, 16 Jul 2022 13:29:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bananajoe" aria-label="Profile: bananajoe">@<bdi>bananajoe</bdi></a> sollte aber keine Rolle spielen, normalerweise wird der Befehl trotzdem ausgeführt, es fehlt halt einfach das modul, warum auch immer</p>
]]></description><link>https://forum.iobroker.net/post/828641</link><guid isPermaLink="true">https://forum.iobroker.net/post/828641</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Sat, 16 Jul 2022 13:29:25 GMT</pubDate></item><item><title><![CDATA[Reply to Gelöst -- iobroker startet nicht mehr on Sat, 16 Jul 2022 13:31:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bananajoe" aria-label="Profile: bananajoe">@<bdi>bananajoe</bdi></a> gleicher Fehler.</p>
<p dir="auto">Im /var/log/syslog kommt immer wieder das hier:</p>
<pre><code>
Jul 16 15:27:22 ioBroker-Pi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
Jul 16 15:27:22 ioBroker-Pi systemd[1]: iobroker.service: Failed with result 'exit-code'.
Jul 16 15:27:25 ioBroker-Pi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
Jul 16 15:27:25 ioBroker-Pi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 85.
Jul 16 15:27:25 ioBroker-Pi systemd[1]: Stopped ioBroker Server.
Jul 16 15:27:25 ioBroker-Pi systemd[1]: Started ioBroker Server.
Jul 16 15:27:26 ioBroker-Pi bash[4292]: node:internal/modules/cjs/loader:936
Jul 16 15:27:26 ioBroker-Pi bash[4292]:   throw err;
Jul 16 15:27:26 ioBroker-Pi bash[4292]:   ^
Jul 16 15:27:26 ioBroker-Pi bash[4292]: Error: Cannot find module 'luxon'
Jul 16 15:27:26 ioBroker-Pi bash[4292]: Require stack:
Jul 16 15:27:26 ioBroker-Pi bash[4292]: - /opt/iobroker/node_modules/cron-parser/lib/date.js
Jul 16 15:27:26 ioBroker-Pi bash[4292]: - /opt/iobroker/node_modules/cron-parser/lib/expression.js
Jul 16 15:27:26 ioBroker-Pi bash[4292]: - /opt/iobroker/node_modules/cron-parser/lib/parser.js
Jul 16 15:27:26 ioBroker-Pi bash[4292]: - /opt/iobroker/node_modules/node-schedule/lib/Job.js
Jul 16 15:27:26 ioBroker-Pi bash[4292]: - /opt/iobroker/node_modules/node-schedule/lib/schedule.js
Jul 16 15:27:26 ioBroker-Pi bash[4292]: - /opt/iobroker/node_modules/node-schedule/index.js
Jul 16 15:27:26 ioBroker-Pi bash[4292]: - /opt/iobroker/node_modules/iobroker.js-controller/main.js
Jul 16 15:27:26 ioBroker-Pi bash[4292]: - /opt/iobroker/node_modules/iobroker.js-controller/controller.js
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     at Function.Module._load (node:internal/modules/cjs/loader:778:27)
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     at require (node:internal/modules/cjs/helpers:102:18)
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/cron-parser/lib/date.js:3:13)
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     at Module._compile (node:internal/modules/cjs/loader:1105:14)
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     at Module.load (node:internal/modules/cjs/loader:981:32)
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     at Module.require (node:internal/modules/cjs/loader:1005:19) {
Jul 16 15:27:26 ioBroker-Pi bash[4292]:   code: 'MODULE_NOT_FOUND',
Jul 16 15:27:26 ioBroker-Pi bash[4292]:   requireStack: [
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     '/opt/iobroker/node_modules/cron-parser/lib/date.js',
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     '/opt/iobroker/node_modules/cron-parser/lib/expression.js',
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     '/opt/iobroker/node_modules/cron-parser/lib/parser.js',
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     '/opt/iobroker/node_modules/node-schedule/lib/Job.js',
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     '/opt/iobroker/node_modules/node-schedule/lib/schedule.js',
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     '/opt/iobroker/node_modules/node-schedule/index.js',
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     '/opt/iobroker/node_modules/iobroker.js-controller/main.js',
Jul 16 15:27:26 ioBroker-Pi bash[4292]:     '/opt/iobroker/node_modules/iobroker.js-controller/controller.js'
Jul 16 15:27:26 ioBroker-Pi bash[4292]:   ]
Jul 16 15:27:26 ioBroker-Pi bash[4292]: }
Jul 16 15:27:26 ioBroker-Pi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
Jul 16 15:27:26 ioBroker-Pi systemd[1]: iobroker.service: Failed with result 'exit-code'.
</code></pre>
]]></description><link>https://forum.iobroker.net/post/828640</link><guid isPermaLink="true">https://forum.iobroker.net/post/828640</guid><dc:creator><![CDATA[lesiflo]]></dc:creator><pubDate>Sat, 16 Jul 2022 13:31:32 GMT</pubDate></item><item><title><![CDATA[Reply to Gelöst -- iobroker startet nicht mehr on Sat, 16 Jul 2022 13:26:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lesiflo" aria-label="Profile: lesiflo">@<bdi>lesiflo</bdi></a> du bist schon mal im falschen pfad ... du musst in</p>
<pre><code>/opt/iobroker
</code></pre>
<p dir="auto">Verzeichnis stehen</p>
]]></description><link>https://forum.iobroker.net/post/828638</link><guid isPermaLink="true">https://forum.iobroker.net/post/828638</guid><dc:creator><![CDATA[BananaJoe]]></dc:creator><pubDate>Sat, 16 Jul 2022 13:26:18 GMT</pubDate></item><item><title><![CDATA[Reply to Gelöst -- iobroker startet nicht mehr on Sat, 16 Jul 2022 13:30:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djmarc75" aria-label="Profile: djmarc75">@<bdi>djmarc75</bdi></a></p>
<pre><code>pi@ioBroker-Pi:/opt/iobroker/iobroker-data/backitup $ iobroker update -i
  throw err;
Require stack:
</code></pre>
]]></description><link>https://forum.iobroker.net/post/828637</link><guid isPermaLink="true">https://forum.iobroker.net/post/828637</guid><dc:creator><![CDATA[lesiflo]]></dc:creator><pubDate>Sat, 16 Jul 2022 13:30:58 GMT</pubDate></item><item><title><![CDATA[Reply to Gelöst -- iobroker startet nicht mehr on Sat, 16 Jul 2022 13:18:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lesiflo" aria-label="Profile: lesiflo">@<bdi>lesiflo</bdi></a><br />
Servus, bitte die komplette Ein- und Ausgabe in Codetags hier einstellen.</p>
]]></description><link>https://forum.iobroker.net/post/828635</link><guid isPermaLink="true">https://forum.iobroker.net/post/828635</guid><dc:creator><![CDATA[DJMarc75]]></dc:creator><pubDate>Sat, 16 Jul 2022 13:18:15 GMT</pubDate></item></channel></rss>
