<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Kann kein Backup einspielen]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">leider kann ich kein Backup nach einer ioBroker Neuinstallation gerade einspielen.<br />
Da ist wohl was wegen js-controller version daneben:</p>
<pre><code>pi@raspberrypi:~ $ iob restore 0
host.raspberrypi Using backup file 2022_05_25-11_04_11_backupiobroker.tar.gz
iobroker controller daemon is not running
host.raspberrypi OK.
The current version of js-controller differs from the version in the backup.
The js-controller version of the backup can not be restored automatically.
To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@3.3.21 --production" inside your ioBroker directory
If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
</code></pre>
<p dir="auto">habe ich auch getan, geht aber noch immer nicht:</p>
<pre><code>pi@raspberrypi:~ $ npm i iobroker.js-controller@3.3.21 --production
npm WARN config production Use `--omit=dev` instead.
added 1 package, removed 27 packages, changed 18 packages, and audited 284 packages in 22s
14 packages are looking for funding
  run `npm fund` for details
4 vulnerabilities (3 moderate, 1 high)
To address all issues (including breaking changes), run:
  npm audit fix --force
Run `npm audit` for details.
pi@raspberrypi:~ $
</code></pre>
<p dir="auto">wenn ich</p>
<pre><code>npm audit fix --force
</code></pre>
<p dir="auto">ausführe macht er wieder ein Update auf js-controller 4</p>
]]></description><link>https://forum.iobroker.net/topic/55962/kann-kein-backup-einspielen</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 17:51:00 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/55962.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Jun 2022 08:15:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Kann kein Backup einspielen on Thu, 30 Jun 2022 12:23:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hg6806" aria-label="Profile: hg6806">@<bdi>hg6806</bdi></a></p>
<p dir="auto">Keine Ahnung. Da waren aber halt ein paar 'Ungereimtheiten' bei dir drin.</p>
]]></description><link>https://forum.iobroker.net/post/821312</link><guid isPermaLink="true">https://forum.iobroker.net/post/821312</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 30 Jun 2022 12:23:15 GMT</pubDate></item><item><title><![CDATA[Reply to Kann kein Backup einspielen on Thu, 30 Jun 2022 12:21:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/821266">Kann kein Backup einspielen</a>:</p>
<blockquote>
<p dir="auto">sudo -H -u iobroker npm install iobroker.js-controller@3.3.21</p>
</blockquote>
<p dir="auto">Nach einem erneuten Restore geht es jetzt.</p>
<p dir="auto">Ich frage mich nur welchen Fehler ich gemacht habe? Backup von zu alter js-controller-version?</p>
]]></description><link>https://forum.iobroker.net/post/821311</link><guid isPermaLink="true">https://forum.iobroker.net/post/821311</guid><dc:creator><![CDATA[hg6806]]></dc:creator><pubDate>Thu, 30 Jun 2022 12:21:26 GMT</pubDate></item><item><title><![CDATA[Reply to Kann kein Backup einspielen on Thu, 30 Jun 2022 10:07:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/821285">Kann kein Backup einspielen</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Das hat zwar funktioniert, das Backup geht noch immer nicht:</p>
<pre><code>pi@raspberrypi:~ $ iob status
 Cannot read system.config: null (OK when migrating or restoring)
iobroker is not running on this host.
</code></pre>
]]></description><link>https://forum.iobroker.net/post/821291</link><guid isPermaLink="true">https://forum.iobroker.net/post/821291</guid><dc:creator><![CDATA[hg6806]]></dc:creator><pubDate>Thu, 30 Jun 2022 10:07:03 GMT</pubDate></item><item><title><![CDATA[Reply to Kann kein Backup einspielen on Thu, 30 Jun 2022 09:55:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hg6806" aria-label="Profile: hg6806">@<bdi>hg6806</bdi></a></p>
<p dir="auto">In /opt/iobroker agiert man besser auch als user iobroker. So</p>
<pre><code>sudo -H -u iobroker npm install iobroker.js-controller@3.3.21
</code></pre>
]]></description><link>https://forum.iobroker.net/post/821285</link><guid isPermaLink="true">https://forum.iobroker.net/post/821285</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 30 Jun 2022 09:55:28 GMT</pubDate></item><item><title><![CDATA[Reply to Kann kein Backup einspielen on Thu, 30 Jun 2022 09:55:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/821283">Kann kein Backup einspielen</a>:</p>
<blockquote>
<p dir="auto">sudo -u iobroker rm /opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF</p>
</blockquote>
<pre><code>pi@raspberrypi:/opt/iobroker $ sudo -u iobroker rm /opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF
rm: cannot remove '/opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF': No such file or directory
</code></pre>
]]></description><link>https://forum.iobroker.net/post/821284</link><guid isPermaLink="true">https://forum.iobroker.net/post/821284</guid><dc:creator><![CDATA[hg6806]]></dc:creator><pubDate>Thu, 30 Jun 2022 09:55:05 GMT</pubDate></item><item><title><![CDATA[Reply to Kann kein Backup einspielen on Thu, 30 Jun 2022 09:53:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hg6806" aria-label="Profile: hg6806">@<bdi>hg6806</bdi></a> sagte in <a href="/post/821280">Kann kein Backup einspielen</a>:</p>
<blockquote>
<p dir="auto">/opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF</p>
</blockquote>
<p dir="auto">Lösch das:</p>
<pre><code>sudo -u iobroker rm /opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF
</code></pre>
]]></description><link>https://forum.iobroker.net/post/821283</link><guid isPermaLink="true">https://forum.iobroker.net/post/821283</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 30 Jun 2022 09:53:44 GMT</pubDate></item><item><title><![CDATA[Reply to Kann kein Backup einspielen on Thu, 30 Jun 2022 09:53:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hg6806" aria-label="Profile: hg6806">@<bdi>hg6806</bdi></a> sagte in <a href="/post/821275">Kann kein Backup einspielen</a>:</p>
<blockquote>
<p dir="auto">jedoch wurde ja trotzdem was ausgeführt</p>
</blockquote>
<p dir="auto">Natürlich. Aber es liegt jetzt im home vom pi herum.</p>
]]></description><link>https://forum.iobroker.net/post/821281</link><guid isPermaLink="true">https://forum.iobroker.net/post/821281</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 30 Jun 2022 09:53:03 GMT</pubDate></item><item><title><![CDATA[Reply to Kann kein Backup einspielen on Thu, 30 Jun 2022 09:53:36 GMT]]></title><description><![CDATA[<p dir="auto">iobroker lief nicht, also habe ich nochmal alles neu installiert, also den Pi neu aufgesetzt.</p>
<p dir="auto">Jetzt kommt folgende Meldung:</p>
<pre><code>pi@raspberrypi:/opt/iobroker $ npm i iobroker.js-controller@3.3.21 --production
npm ERR! code EACCES
npm ERR! syscall rename
npm ERR! path /opt/iobroker/node_modules/alcalzone-shared
npm ERR! dest /opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, rename '/opt/iobroker/node_modules/al        calzone-shared' -&gt; '/opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF'
npm ERR!  [Error: EACCES: permission denied, rename '/opt/iobroker/node_modules/        alcalzone-shared' -&gt; '/opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF'] {
npm ERR!   errno: -13,
npm ERR!   code: 'EACCES',
npm ERR!   syscall: 'rename',
npm ERR!   path: '/opt/iobroker/node_modules/alcalzone-shared',
npm ERR!   dest: '/opt/iobroker/node_modules/.alcalzone-shared-FgX40TmF'
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the        current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check t        he
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR!     /home/pi/.npm/_logs/2022-06-30T09_48_50_758Z-debug-0.log
</code></pre>
]]></description><link>https://forum.iobroker.net/post/821280</link><guid isPermaLink="true">https://forum.iobroker.net/post/821280</guid><dc:creator><![CDATA[hg6806]]></dc:creator><pubDate>Thu, 30 Jun 2022 09:53:36 GMT</pubDate></item><item><title><![CDATA[Reply to Kann kein Backup einspielen on Thu, 30 Jun 2022 09:20:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/821266">Kann kein Backup einspielen</a>:</p>
<blockquote>
<p dir="auto">Du musst nach /opt/iobroker wechseln.</p>
</blockquote>
<p dir="auto">Hatte ich zwar auf dem Schirm, jedoch wurde ja trotzdem was ausgeführt, deshalb dachte ich das mit dem Verzeichnis ist ok.</p>
<blockquote>
<p dir="auto">npm audit fix --force</p>
</blockquote>
<p dir="auto">Das stand ja auch in der Meldung, deshalb hatte ich das ausgeführt.</p>
<p dir="auto">Läuft jetzt! Danke!</p>
]]></description><link>https://forum.iobroker.net/post/821275</link><guid isPermaLink="true">https://forum.iobroker.net/post/821275</guid><dc:creator><![CDATA[hg6806]]></dc:creator><pubDate>Thu, 30 Jun 2022 09:20:24 GMT</pubDate></item><item><title><![CDATA[Reply to Kann kein Backup einspielen on Thu, 30 Jun 2022 08:50:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hg6806" aria-label="Profile: hg6806">@<bdi>hg6806</bdi></a> sagte in <a href="/post/821255">Kann kein Backup einspielen</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Nie machen! Schon gerade gar nicht per force!</p>
<blockquote>
<p dir="auto">pi@raspberrypi:~ $ npm i iobroker.js-controller@3.3.21</p>
</blockquote>
<p dir="auto">Da stehst du im falschen Verzeichnis.<br />
<pre><code>cd /opt/iobroker
</code></pre>
]]></description><link>https://forum.iobroker.net/post/821266</link><guid isPermaLink="true">https://forum.iobroker.net/post/821266</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 30 Jun 2022 08:50:08 GMT</pubDate></item></channel></rss>
