<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adapter Update läuft nicht nach Update nodejs]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">ich habe nach Anleitung:</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition">https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition</a></p>
<p dir="auto">Upgedatet auf:</p>
<pre><code>uname -m &amp;&amp; which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v        :(
x86_64
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v16.15.1
v16.15.1
8.11.0
</code></pre>
<pre><code>iobroker upgrade devices --debug
This upgrade of "devices" will introduce the following changes:
-&gt; 1.0.12:
Allowed to work with devices behind reverse proxy
Replaced the function icon
-&gt; 1.0.11:
Updated some libraries
Would you like to upgrade devices from @1.0.10 to @1.0.12 now? [(y)es, (n)o]: y
Update devices from @1.0.10 to @1.0.12
NPM version: 8.11.0
Installing iobroker.devices@1.0.12... (System call)
npm ERR! code ENOTEMPTY
npm ERR! syscall rename
npm ERR! path /opt/iobroker/node_modules/array.prototype.findindex
npm ERR! dest /opt/iobroker/node_modules/.array.prototype.findindex-JX1jwpiR
npm ERR! errno -39
npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/array.prototype.findindex' -&gt; '/opt/iobroker/node_modules/.array.prototype.findindex-JX1jwpiR'
npm ERR!     /home/iobroker/.npm/_logs/2022-06-27T20_04_23_757Z-debug-0.log
host.zotac Cannot install iobroker.devices@1.0.12: 217
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/55901/adapter-update-läuft-nicht-nach-update-nodejs</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 16:43:01 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/55901.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Jun 2022 20:09:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adapter Update läuft nicht nach Update nodejs on Sat, 02 Jul 2022 08:43:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sissiwup" aria-label="Profile: sissiwup">@<bdi>sissiwup</bdi></a></p>
<p dir="auto">Was musst du denn da neu einrichten?<br />
Einfach einen User nutzen, ggf. noch sudo nachinstallieren. Wobei das installiert ist, der 'iobroker' läuft ja auch über sudo.</p>
]]></description><link>https://forum.iobroker.net/post/821949</link><guid isPermaLink="true">https://forum.iobroker.net/post/821949</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 02 Jul 2022 08:43:48 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter Update läuft nicht nach Update nodejs on Sat, 02 Jul 2022 08:38:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/820237">Adapter Update läuft nicht nach Update nodejs</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sissiwup" aria-label="Profile: sissiwup">@<bdi>sissiwup</bdi></a> sagte in <a href="/post/820233">Adapter Update läuft nicht nach Update nodejs</a>:</p>
<blockquote>
<p dir="auto">/root/</p>
</blockquote>
</blockquote>
<p dir="auto">Hi,</p>
<p dir="auto">ich weiss, läuft aber seit ca. 2013 so. Kein bock auf neues Einrichten ...</p>
]]></description><link>https://forum.iobroker.net/post/821948</link><guid isPermaLink="true">https://forum.iobroker.net/post/821948</guid><dc:creator><![CDATA[sissiwup]]></dc:creator><pubDate>Sat, 02 Jul 2022 08:38:30 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter Update läuft nicht nach Update nodejs on Mon, 27 Jun 2022 21:20:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sissiwup" aria-label="Profile: sissiwup">@<bdi>sissiwup</bdi></a> sagte in <a href="/post/820233">Adapter Update läuft nicht nach Update nodejs</a>:</p>
<blockquote>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/820237</link><guid isPermaLink="true">https://forum.iobroker.net/post/820237</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 27 Jun 2022 21:20:31 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter Update läuft nicht nach Update nodejs on Mon, 27 Jun 2022 21:18:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a><br />
Hi, danke das war der entscheidene Tipp:<br />
Die iobroker.icons-open-icon-library-png@0.1.3 ist scheinbar die falsche Version. Da brauchte ich die iobroker.icons-open-icon-library-png@0.1.2</p>
<p dir="auto">Jetzt geht das Update wieder.  (Wenn auch seeeeeeehr viel langsamer als früher)</p>
<pre><code>npm ls | grep ERR        :(
npm ERR! code ELSPROBLEMS
npm ERR! extraneous: acorn-walk@8.2.0 /opt/iobroker/node_modules/acorn-walk
npm ERR! extraneous: acorn@8.7.0 /opt/iobroker/node_modules/acorn
npm ERR! invalid: iobroker.icons-open-icon-library-png@0.1.3 /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
npm ERR! extraneous: jsonata@1.8.5 /opt/iobroker/node_modules/jsonata
npm ERR! extraneous: vm2@3.9.5 /opt/iobroker/node_modules/vm2
npm ERR!     /root/.npm/_logs/2022-06-27T21_00_11_904Z-debug-0.log
# iobroker del iobroker.icons-open-icon-library-png
Delete adapter "icons-open-icon-library-png"
host.zotac Counted 1 instances of icons-open-icon-library-png
host.zotac Counted 1 meta of icons-open-icon-library-png
host.zotac Counted 1 adapter for icons-open-icon-library-png
host.zotac Counted 1 states of system.adapter.icons-open-icon-library-png
host.zotac file icons-open-icon-library-png deleted
host.zotac file icons-open-icon-library-png.admin deleted
host.zotac object icons-open-icon-library-png deleted
host.zotac object icons-open-icon-library-png.admin deleted
host.zotac Deleting 4 object(s).
added 181 packages, removed 399 packages, and changed 1173 packages in 2m
126 packages are looking for funding
  run `npm fund` for details
iobroker del iobroker.icons-open-icon-library-png  51,39s user 10,60s system 34% cpu 2:58,53 total
# iobroker install iobroker.icons-open-icon-library-png
</code></pre>
]]></description><link>https://forum.iobroker.net/post/820233</link><guid isPermaLink="true">https://forum.iobroker.net/post/820233</guid><dc:creator><![CDATA[sissiwup]]></dc:creator><pubDate>Mon, 27 Jun 2022 21:18:22 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter Update läuft nicht nach Update nodejs on Mon, 27 Jun 2022 20:55:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sissiwup" aria-label="Profile: sissiwup">@<bdi>sissiwup</bdi></a></p>
<p dir="auto">Fängt hier an ...</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition/359">https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition/359</a></p>
<p dir="auto">und hier z.B. durchgehend...</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/55683/kein-update-mehr-m%C3%B6glich-mit-node-js-16">https://forum.iobroker.net/topic/55683/kein-update-mehr-möglich-mit-node-js-16</a></p>
]]></description><link>https://forum.iobroker.net/post/820227</link><guid isPermaLink="true">https://forum.iobroker.net/post/820227</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Mon, 27 Jun 2022 20:55:43 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter Update läuft nicht nach Update nodejs on Mon, 27 Jun 2022 20:50:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sissiwup" aria-label="Profile: sissiwup">@<bdi>sissiwup</bdi></a> sagte in <a href="/post/820223">Adapter Update läuft nicht nach Update nodejs</a>:</p>
<blockquote>
<p dir="auto">Liegt das an der neuen nodejs Version?</p>
</blockquote>
<p dir="auto">Ja ... brauchst nur in deinem beigefügten Link alles dazu lesen , bzw. jeder 15 neu erstellter Beitrag hier im Forum handelt davon " ERROR 25 "</p>
]]></description><link>https://forum.iobroker.net/post/820225</link><guid isPermaLink="true">https://forum.iobroker.net/post/820225</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Mon, 27 Jun 2022 20:50:12 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter Update läuft nicht nach Update nodejs on Mon, 27 Jun 2022 20:48:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a><br />
Hi,<br />
da kommen dann immer neue Dateien, die ich umbenennen soll.<br />
Als letztes iobroker.devices<br />
Dann sagt er das modul ist nicht installiert.</p>
<p dir="auto">Wenn ich das dann installieren möchte, kommt das</p>
-&gt; 1.0.12:
-&gt; 1.0.11:
NPM version: 8.11.0
npm ERR! path /opt/iobroker/node_modules/iobroker.devices
npm ERR! dest /opt/iobroker/node_modules/.iobroker.devices-1FmykokK
npm ERR! errno -39
npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.devices' -&gt; '/opt/iobroker/node_modules/.iobroker.devices-1FmykokK'
npm ERR!     /home/iobroker/.npm/_logs/2022-06-27T20_20_49_788Z-debug-0.log
Adapter "devices"        is not installed.
iobroker install devices --debug
NPM version: 8.11.0
npm ERR! path /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
npm ERR! dest /opt/iobroker/node_modules/.iobroker.icons-open-icon-library-png-dWPxt8qG
npm ERR! errno -39
npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.icons-open-icon-library-png' -&gt; '/opt/iobroker/node_modules/.iobroker.icons-open-icon-library-png-dWPxt8qG'
npm ERR!     /home/iobroker/.npm/_logs/2022-06-27T20_22_27_327Z-debug-0.log
iobroker del devices        :(
Delete adapter "devices"
host.zotac object devices deleted
host.zotac object devices.admin deleted
Error deleting adapter devices from disk: Cannot find module 'iobroker.devices/io-package.json'
Require stack:
- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js
- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
You might have to delete it yourself!
</code></pre>
<p dir="auto">Liegt das an der neuen nodejs Version?<br />
Ich habe jetzt erstmal das Backup von heute morgen eingespielt.<br />
Alle 3 zu updatenden Adapter laufen auf ähnliche Fehler.</p>
]]></description><link>https://forum.iobroker.net/post/820223</link><guid isPermaLink="true">https://forum.iobroker.net/post/820223</guid><dc:creator><![CDATA[sissiwup]]></dc:creator><pubDate>Mon, 27 Jun 2022 20:48:07 GMT</pubDate></item><item><title><![CDATA[Reply to Adapter Update läuft nicht nach Update nodejs on Mon, 27 Jun 2022 20:14:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sissiwup" aria-label="Profile: sissiwup">@<bdi>sissiwup</bdi></a> sagte in <a href="/post/820207">Adapter Update läuft nicht nach Update nodejs</a>:</p>
<blockquote>
<p dir="auto">directory not empty, rename '/opt/iobroker/node_modules/array.prototype.findindex' -&gt; '/opt/iobroker/node_modules/.array.prototype.findindex-JX1jwpiR'</p>
</blockquote>
<pre><code>sudo -u iobroker mv /opt/iobroker/node_modules/array.prototype.findindex /opt/iobroker/node_modules/.array.prototype.findindex-JX1jwpiR
</code></pre>
]]></description><link>https://forum.iobroker.net/post/820209</link><guid isPermaLink="true">https://forum.iobroker.net/post/820209</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Mon, 27 Jun 2022 20:14:18 GMT</pubDate></item></channel></rss>
