<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ical Adapter läßt sich nicht updaten]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
mein ical-Adapter läßt sich nicht updaten. Es kommt die Fehlermeldung<br />
<img src="/assets/uploads/files/1654890864625-ical.png" alt="ical.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Ich habe aber den js-contoller 4.0.23 installiert.</p>
<pre><code>pi@raspberrypi:/opt/iobroker $ iob update
Used repository: beta
Adapter    "admin"        : 6.0.2    , installed 6.0.0  [Updatable]
Adapter    "alarm"        : 3.1.0    , installed 3.1.0
Adapter    "alexa2"       : 3.12.0   , installed 3.12.0
Adapter    "backitup"     : 2.4.9    , installed 2.4.9
Adapter    "calendar"     : 1.2.0    , installed 1.2.0
Adapter    "cameras"      : 0.1.8    , installed 0.1.8
Adapter    "cloud"        : 4.1.1    , installed 4.1.1
Adapter    "deconz"       : 1.3.21   , installed 2.0.5
Adapter    "denon"        : 1.13.4   , installed 1.13.4
Adapter    "devices"      : 1.0.12   , installed 1.0.10 [Updatable]
Adapter    "discovery"    : 3.0.4    , installed 3.0.3  [Updatable]
Adapter    "egigeozone"   : 0.1.2    , installed 0.1.2
Adapter    "email"        : 1.1.3    , installed 1.1.3
Adapter    "exchangerates": 0.0.14   , installed 0.0.14
Adapter    "fb-checkpresence": 1.1.15, installed 1.1.15
Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
Adapter    "geofency"     : 1.1.1    , installed 1.1.1
Adapter    "heatingcontrol": 2.9.0   , installed 2.8.7  [Updatable]
Adapter    "history"      : 2.1.3    , installed 2.1.2  [Updatable]
Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
Adapter    "homeconnect"  : 1.0.1    , installed 1.0.1
Adapter    "homee"        : 1.2.0    , installed 1.2.0
Adapter    "ical"         : 1.12.2   , installed 1.12.1 [Updatable]
Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
Adapter    "icons-material-png": 0.1.0, installed 0.1.0
Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
Adapter    "info"         : 1.9.19   , installed 1.9.19
Adapter    "javascript"   : 5.7.0    , installed 5.7.0
Controller "js-controller": 4.0.23   , installed 4.0.23
Adapter    "landroid"     : 1.0.3    , installed 1.0.3
Adapter    "lifx"         : 0.1.1    , installed 0.1.1
Adapter    "meross"       : 1.11.0   , installed 1.11.0
Adapter    "node-red"     : 3.3.1    , installed 3.3.1
Adapter    "onvif"        : 0.4.4    , installed 0.4.4
Adapter    "openweathermap": 0.2.4   , installed 0.2.4
Adapter    "paw"          : 0.3.2    , installed 0.3.2
Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
Adapter    "sayit"        : 1.12.6   , installed 1.12.6
Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
Adapter    "shelly"       : 5.3.2    , installed 5.3.2
Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
Adapter    "socketio"     : 6.1.5    , installed 6.1.4  [Updatable]
Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
Adapter    "telegram"     : 1.13.0   , installed 1.13.0
Adapter    "text2command" : 2.2.1    , installed 2.2.1
Adapter    "toyota"       : 0.0.3    , installed 0.0.3
Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
Adapter    "trashschedule": 2.0.3    , installed 2.0.3
Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
Adapter    "vis-material" : 0.1.3    , installed 0.1.3
Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
Adapter    "weatherunderground": 3.4.2, installed 3.4.2
Adapter    "web"          : 5.2.2    , installed 5.2.0  [Updatable]
Adapter    "worx"         : 1.5.5    , installed 1.5.5
Adapter    "ws"           : 2.1.1    , installed 2.1.0  [Updatable]
Adapter    "yr"           : 5.3.0    , installed 5.3.0
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/55560/ical-adapter-läßt-sich-nicht-updaten</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 03:24:58 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/55560.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Jun 2022 19:56:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ical Adapter läßt sich nicht updaten on Fri, 10 Jun 2022 21:18:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joergfrde" aria-label="Profile: joergfrde">@<bdi>joergfrde</bdi></a> Wenn du weiter am Beta Test vom Admin 6 teilnehmen möchtest findest du hier den Workaround wie du eine Admin 6.0.0 Version aktualisiert: <a href="https://github.com/ioBroker/ioBroker.admin/issues/1509" rel="nofollow ugc">https://github.com/ioBroker/ioBroker.admin/issues/1509</a> damit du auf die aktuelle Beta 6.0.2 kommst.<br />
Ansonsten downgrade auf die stable Version vom Admin :-)</p>
]]></description><link>https://forum.iobroker.net/post/813019</link><guid isPermaLink="true">https://forum.iobroker.net/post/813019</guid><dc:creator><![CDATA[Feuersturm]]></dc:creator><pubDate>Fri, 10 Jun 2022 21:18:57 GMT</pubDate></item><item><title><![CDATA[Reply to ical Adapter läßt sich nicht updaten on Fri, 10 Jun 2022 20:33:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joergfrde" aria-label="Profile: joergfrde">@<bdi>joergfrde</bdi></a> sagte in <a href="/post/812986">ical Adapter läßt sich nicht updaten</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Und warum hältst du deine zutestenden Beta-Versionen nicht auf dem letzten Stand und betatestest diese? Obsolete Versionen muss niemand mehr testen.</p>
<p dir="auto">Ich denke im stabilen Zweig wärst du wesentlich besser aufgehoben. Da muss man sich auch weniger um das System kümmern.</p>
]]></description><link>https://forum.iobroker.net/post/813007</link><guid isPermaLink="true">https://forum.iobroker.net/post/813007</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 10 Jun 2022 20:33:43 GMT</pubDate></item><item><title><![CDATA[Reply to ical Adapter läßt sich nicht updaten on Fri, 10 Jun 2022 20:01:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a></p>
<p dir="auto">Und täglich grüßt das Mumeltier ....  :)</p>
]]></description><link>https://forum.iobroker.net/post/812990</link><guid isPermaLink="true">https://forum.iobroker.net/post/812990</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Fri, 10 Jun 2022 20:01:57 GMT</pubDate></item><item><title><![CDATA[Reply to ical Adapter läßt sich nicht updaten on Fri, 10 Jun 2022 20:01:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joergfrde" aria-label="Profile: joergfrde">@<bdi>joergfrde</bdi></a> sagte in <a href="/post/812986">ical Adapter läßt sich nicht updaten</a>:</p>
<blockquote>
<p dir="auto">Used repository: <span style="color:#ff0000"><strong>beta</strong></span></p>
</blockquote>
<p dir="auto">Warum?</p>
]]></description><link>https://forum.iobroker.net/post/812989</link><guid isPermaLink="true">https://forum.iobroker.net/post/812989</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 10 Jun 2022 20:01:14 GMT</pubDate></item><item><title><![CDATA[Reply to ical Adapter läßt sich nicht updaten on Fri, 10 Jun 2022 19:57:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joergfrde" aria-label="Profile: joergfrde">@<bdi>joergfrde</bdi></a></p>
<p dir="auto">Schau mal hier :</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/55381/admin-6-0-neu-als-beta">https://forum.iobroker.net/topic/55381/admin-6-0-neu-als-beta</a></p>
]]></description><link>https://forum.iobroker.net/post/812988</link><guid isPermaLink="true">https://forum.iobroker.net/post/812988</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Fri, 10 Jun 2022 19:57:53 GMT</pubDate></item></channel></rss>
