<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nach Restore Fehler bei Installation VIS]]></title><description><![CDATA[<p dir="auto">Habe einen neuen Docker Container erstellt und einen Restore durchgeführt. Soweit scheint auch alles zu laufen außer VIS:</p>
<pre><code>host.iobroker_V61
2022-05-02 08:13:01.584	info	iobroker npm-install: exit 25
host.iobroker_V61
2022-05-02 08:13:00.563	error	iobroker npm-install: host.iobroker_V61 Cannot install iobroker.vis@1.4.15: 6
vis.0
2022-05-02 08:12:57.573	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
vis.0
2022-05-02 08:12:57.572	info	terminating
vis.0
2022-05-02 08:12:57.049	error	Not exists
vis.0
2022-05-02 08:12:57.047	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.&lt;anonymous&gt; (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:466:21)
vis.0
2022-05-02 08:12:57.045	error	unhandled promise rejection: Not exists
vis.0
2022-05-02 08:12:57.044	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
vis.0
2022-05-02 08:12:56.829	info	vis license is OK.
vis.0
2022-05-02 08:12:56.652	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.1, js-controller: 4.0.23
host.iobroker_V61
2022-05-02 08:12:55.142	info	iobroker npm-install:
host.iobroker_V61
2022-05-02 08:12:55.141	info	iobroker npm-install: &gt; iobroker.vis@1.4.15 install /opt/iobroker/node_modules/iobroker.vis&gt; node main.js --install
</code></pre>
<p dir="auto">Auch manuell über die Web-Oberfläche funktioniert nicht (gleicher Fehler). Was kann ich tun</p>
]]></description><link>https://forum.iobroker.net/topic/54651/nach-restore-fehler-bei-installation-vis</link><generator>RSS for Node</generator><lastBuildDate>Thu, 23 Apr 2026 13:21:20 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/54651.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 May 2022 06:21:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Nach Restore Fehler bei Installation VIS on Mon, 02 May 2022 09:51:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cash" aria-label="Profile: cash">@<bdi>cash</bdi></a> PERFEKT !</p>
]]></description><link>https://forum.iobroker.net/post/798009</link><guid isPermaLink="true">https://forum.iobroker.net/post/798009</guid><dc:creator><![CDATA[SigiMOE]]></dc:creator><pubDate>Mon, 02 May 2022 09:51:56 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Restore Fehler bei Installation VIS on Mon, 02 May 2022 09:46:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sigimoe" aria-label="Profile: sigimoe">@<bdi>sigimoe</bdi></a> said in <a href="/post/798000">Nach Restore Fehler bei Installation VIS</a>:</p>
<blockquote></blockquote>
<p dir="auto">danke. Erst die alte Version zu installieren hat funktioniert. Vielen Dank.</p>
]]></description><link>https://forum.iobroker.net/post/798004</link><guid isPermaLink="true">https://forum.iobroker.net/post/798004</guid><dc:creator><![CDATA[cash]]></dc:creator><pubDate>Mon, 02 May 2022 09:46:08 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Restore Fehler bei Installation VIS on Mon, 02 May 2022 09:38:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cash" aria-label="Profile: cash">@<bdi>cash</bdi></a> Probiere mal das hier (ohne Gewähr) aber bei mir hat es so funktioniert :</p>
<p dir="auto">Quelle : <a href="https://github.com/ioBroker/ioBroker.vis/issues/440#issuecomment-1074726418" rel="nofollow ugc">https://github.com/ioBroker/ioBroker.vis/issues/440#issuecomment-1074726418</a></p>
<p dir="auto">Nach backup war die VIS weg. Konnte den Adapter nicht löschen und nicht neu installieren. Es ging nichts. Dank eurer Anleitung oben, über die Shell habe ich alles wieder hinbekommen. Herzlichen Dank. In so einer VIS steckt eine menge Herzblut drin.<br />
Falls noch jemand das Problem hat und nicht so fit ist,<br />
ich habe über SSH " /opt/iobroker $ " " iob install vis@1.4.5 "durchgeführt, danach " iobroker update " und anschließend " iobroker upgrade " durchgeführt .<br />
Jetzt ist alles wieder da.<br />
Schöne Grüße.</p>
]]></description><link>https://forum.iobroker.net/post/798000</link><guid isPermaLink="true">https://forum.iobroker.net/post/798000</guid><dc:creator><![CDATA[SigiMOE]]></dc:creator><pubDate>Mon, 02 May 2022 09:38:12 GMT</pubDate></item></channel></rss>
