<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[gelöst] iobroker auf Raspi startet nach Stromausfall nicht]]></title><description><![CDATA[<p dir="auto">Eigentlich sagt der Titel eh schon alles.<br />
Mit SSH komme ich noch drauf. Aber iobroker startet nicht mehr.<br />
Das habe ich schon erfolglos versucht: <a href="https://rodnic.de/hausautomation/4-iobroker-backup-restor-nach-spannungsausfall-iobroker-laeuft-nicht-mehr/" rel="nofollow ugc">https://rodnic.de/hausautomation/4-iobroker-backup-restor-nach-spannungsausfall-iobroker-laeuft-nicht-mehr/</a><br />
Und auch das: <a href="https://www.iobroker.net/docu/index-26.htm?page_id=3928&amp;lang=de" rel="nofollow ugc">https://www.iobroker.net/docu/index-26.htm?page_id=3928&amp;lang=de</a></p>
<pre><code>pi@192.168.1.104's password:
Linux iobroker 5.10.63-v7+ #1496 SMP Wed Dec 1 15:58:11 GMT 2021 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Feb 10 15:51:16 2022 from 192.168.1.178
pi@iobroker:~ $ ps -A | grep iobroker
pi@iobroker:~ $ cd /opt/iobroker
pi@iobroker:/opt/iobroker $ iobroker start
pi@iobroker:/opt/iobroker $ cd /opt/iobroker
pi@iobroker:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.        js --logs
2022-02-10 16:03:29.872  - info: host.iobroker iobroker.js-controller version 3.        3.22 js-controller starting
2022-02-10 16:03:29.898  - info: host.iobroker Copyright (c) 2014-2021 bluefox,        2014 hobbyquaker
2022-02-10 16:03:29.901  - info: host.iobroker hostname: iobroker, node: v12.22.        8
2022-02-10 16:03:29.905  - info: host.iobroker ip addresses: 192.168.1.104 fd14:        5f94:b815:db00:245d:4677:bad2:d9e7 fe80::397e:830d:14f4:60b7
2022-02-10 16:03:30.834  - info: host.iobroker-Server  Error inMem-objects liste        ning on port 9001: Error: listen EADDRINUSE: address already in use 0.0.0.0:9001
2022-02-10 16:03:59.967  - error: host.iobroker No connection to databases possible, restart
2022-02-10 16:03:59.985  - info: host.iobroker iobroker _restart
Kann man da noch was retten?
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/52379/gelöst-iobroker-auf-raspi-startet-nach-stromausfall-nicht</link><generator>RSS for Node</generator><lastBuildDate>Sat, 23 May 2026 15:37:20 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/52379.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Feb 2022 15:08:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 20:20:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> Eigentlich reicht es.</p>
<p dir="auto">Vorher stoppen schadet aber auch nicht.</p>
]]></description><link>https://forum.iobroker.net/post/762086</link><guid isPermaLink="true">https://forum.iobroker.net/post/762086</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Sun, 13 Feb 2022 20:20:34 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 20:19:42 GMT]]></title><description><![CDATA[<p dir="auto">Bei Kodi schon, bei Industriesteuerungen die im ms Raster sämtliche Ein-Ausgänge verarbeiten, ist es wahrscheinlich nicht viel anders als bei iobroker.</p>
<blockquote>
<p dir="auto">Die werden in den seltensten Fällen auf SD Karten schreiben sondern haben eher etwas wie ROM Bausteine oder ReadOnly File Systeme.</p>
</blockquote>
<p dir="auto">Ja stimmt. Die laufen im RAM und das Programm liegt im Flash bzw. wird es beim Start auch ins RAM geladen und läuft dann dort.<br />
Wobei ich auch schon oft Raspi in Industriegeräten gesehen habe. Aber das  sind dann oft CM Module sind, die dann auch keine SD Card haben.</p>
<p dir="auto">Reicht eigentlich</p>
<pre><code>sudo shutdown -h 0
</code></pre>
<p dir="auto">Oder soll man vorher iobroker stoppen?</p>
]]></description><link>https://forum.iobroker.net/post/762085</link><guid isPermaLink="true">https://forum.iobroker.net/post/762085</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Sun, 13 Feb 2022 20:19:42 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 20:05:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> sagte in <a href="/post/762070">[gelöst] iobroker auf Raspi startet nach Stromausfall nicht</a>:</p>
<blockquote>
<p dir="auto">Ich frage mich nur wie das bei den Milliarden von Geräten gelöst ist auf denen auch Linux läuft. (Industriesteuerungen, Wechselrichter, Wallboxen, div. Spielzeug, Router,...)</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/762078</link><guid isPermaLink="true">https://forum.iobroker.net/post/762078</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Sun, 13 Feb 2022 20:05:27 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 20:00:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> sagte in <a href="/post/762070">[gelöst] iobroker auf Raspi startet nach Stromausfall nicht</a>:</p>
<blockquote>
<p dir="auto">Ich frage mich nur wie das bei den Milliarden von Geräten gelöst ist auf denen auch Linux läuft.</p>
</blockquote>
<p dir="auto">das hat nichts mit Linux zu tun.<br />
der ioBroker hat nur bedingt durch seine Datenbank-Struktur deutlich häufiger das Bestreben etwas zu schreiben.<br />
Und ein Dateisystem, das während eines Schreibvorgangs gestört wird ist (meist) hin.</p>
<p dir="auto">Wenn es nur Kodi-Videodaten betrifft, gast du danach Klötzchen an einer Stelle im Film.<br />
Bei Systemrelevanten Daten (Objects/states) ist der Schaden dagegen direkt sichtbar.</p>
]]></description><link>https://forum.iobroker.net/post/762074</link><guid isPermaLink="true">https://forum.iobroker.net/post/762074</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 13 Feb 2022 20:00:23 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 19:56:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> sagte in <a href="/post/761950">[gelöst] iobroker auf Raspi startet nach Stromausfall nicht</a>:</p>
<blockquote>
<p dir="auto">der Kodi schreibbt bestimmt auch nicht im Sekundentakt Daten auf die Karte.<br />
Da ist die Wahrscheinlichkeit einen Schreibvorgang zu erwischen auch deutlich geringer.</p>
</blockquote>
<p dir="auto">Ja da hast du sicher Recht. Ev. ist das auch der Grund, weshalb der Slave kein Problem damit hat. Da läuft im Gegensatz zum Master kaum was drauf.<br />
Und der 2. Slave hängt sowieso auf einem Akku.</p>
<p dir="auto">Stromausfall bzw. Stromabschaltung ist bei uns extrem selten (2 mal die letzten 10 Jahre). Aber rechnen muss man trotzdem damit.<br />
Bzw. kann man nicht davon ausgehen, dass es nicht auftritt.</p>
<p dir="auto">Eigentlich hängt auch der Master auf einer Art USV (Am Tag wird er vom Netz versorgt und iin der Nacht vom Akku).<br />
Die Umschaltung zwischen Netz und Akku läuft seit 2 Jahren problemlos. Nur bei Netzausfall ist die Umschaltzeit zu lange. (Detektierung Netzausfall)<br />
Da es bisher aber noch nie aufgetreten ist, ist mir das mit der zu langen Umschaltzeit nicht aufgefallen. (lässt sich sicher lösen)</p>
<blockquote>
<p dir="auto">dann hast du bisher nur unglaubliches Glück gehabt.</p>
</blockquote>
<p dir="auto">Wenn es mit direkt USB abstecken reproduzierbar nie ein Problem ist und mit Netzteil abstecken jetzt 3x nacheinander ein Problem war, kann man nicht von Glück sprechen. Da gibt es definitiv eine messbare Ursache.<br />
Aber Stimmt schon, einfach Spannung weg ist nie so toll.<br />
Ich frage mich nur wie das bei den Milliarden von Geräten gelöst ist auf denen auch Linux läuft. (Industriesteuerungen, Wechselrichter, Wallboxen, div. Spielzeug, Router,...)<br />
Da gibt es nirgends eine USV und die Geräte funktionieren auch nach einem Stromausfall noch.</p>
<p dir="auto">Bei der Wallbox werde ich es weiterhin riskieren, solange es keine Probleme verursacht.<br />
Für den Master, werde ich mir einen Button in der vis machen, damit ich nicht extra mit SSH verbinden muss. (man lernt ja dazu und ich lasse mir gerne auch was sagen)</p>
]]></description><link>https://forum.iobroker.net/post/762070</link><guid isPermaLink="true">https://forum.iobroker.net/post/762070</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Sun, 13 Feb 2022 19:56:45 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 18:18:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> sagte in <a href="/post/761944">[gelöst] iobroker auf Raspi startet nach Stromausfall nicht</a>:</p>
<blockquote>
<p dir="auto">Da ist jahrelang nie etwas passiert.</p>
</blockquote>
<blockquote>
<p dir="auto">Auch mit IOBroker hatte ich noch nie das Problem</p>
</blockquote>
<p dir="auto">dann hast du bisher nur unglaubliches Glück gehabt.<br />
Hier im Forum kommen täglich User mit diesem Problem.</p>
<blockquote>
<p dir="auto">Mit einem Stromausfall muss man immer rechnen.</p>
</blockquote>
<p dir="auto">Wenn das bei dir in der Gegend so ist, dann musst du auch immer mit einer USV rechnen.<br />
Ich habe zwei.</p>
<blockquote>
<p dir="auto">Und was macht es dann für einen Unterschied ob ich abstecke oder es einen Stromausfall gibt?</p>
</blockquote>
<p dir="auto">keinen</p>
]]></description><link>https://forum.iobroker.net/post/761950</link><guid isPermaLink="true">https://forum.iobroker.net/post/761950</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 13 Feb 2022 18:18:22 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 18:15:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a><br />
Sagen wir mal so. Ich habe div. Raspis schon viele Jahre im Einsatz. Am Anfang war ich immer sehr vorsichtig. z.B. habe ich auf einem Kodi Mediacenter laufen gehabt und jeden Tag vor Strom ausschalten immer brav heruntergefahren. Irgendwann habe ich es einfach riskiert und einfach den Strom abgeschaltet, weil ich eh ein Backup hatte. Da ist jahrelang nie etwas passiert.<br />
Auch andere System hatten nie ein Problem. Auch mit IOBroker hatte ich noch nie das Problem, bis vor ein paar Tagen beim Stromausfall. Und das ist jetzt offensichtlich reproduzierbar.<br />
Ich bezweifle dass der Großteil den Raspi mit IOBroker auf einer USV hängen hat. Mit einem Stromausfall muss man immer rechnen.<br />
Und was macht es dann für einen Unterschied ob ich abstecke oder es einen Stromausfall gibt?<br />
Aber nachdem ich jetzt weiß, dass da iobroker etwas anfällig zu sein scheint, werde ich zukünftig herunterfahren bevor ich ihn abschalte. Zumindest beim Master, der das Problem zeigt.<br />
Beim Slave in der Wallbox ist das wenig praxistauglich. (kann meiner Frau schlecht erklären, dass sie sich zuerst mit SSH verbinden muss, bevor sie die Wallbox ausschaltet.)</p>
]]></description><link>https://forum.iobroker.net/post/761944</link><guid isPermaLink="true">https://forum.iobroker.net/post/761944</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Sun, 13 Feb 2022 18:15:13 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 18:04:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> sagte in <a href="/post/761926">[gelöst] iobroker auf Raspi startet nach Stromausfall nicht</a>:</p>
<blockquote>
<p dir="auto">Wenn ich einfach den USB-Stecker (Stromversorgung) abstecke, passiert gar nichts</p>
</blockquote>
<p dir="auto">Russisch Roulette ist dein bevorzugtes Glücksspiel?</p>
]]></description><link>https://forum.iobroker.net/post/761930</link><guid isPermaLink="true">https://forum.iobroker.net/post/761930</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 13 Feb 2022 18:04:10 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 18:03:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> sagte in <a href="/post/761926">[gelöst] iobroker auf Raspi startet nach Stromausfall nicht</a>:</p>
<blockquote>
<p dir="auto">Kann man irgendwie einen automatischen shutdown ausführen, wenn man sich ein Powerfail-Signal generiert?</p>
</blockquote>
<p dir="auto">Dafür gibt es Geräte, die da USV heißen.</p>
]]></description><link>https://forum.iobroker.net/post/761929</link><guid isPermaLink="true">https://forum.iobroker.net/post/761929</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 13 Feb 2022 18:03:41 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 18:02:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Ja werde ich in Zukunft bei einer geplanten Abschaltung machen.<br />
Bei einem richtigen Stromausfall geht das halt nicht.<br />
Eigenartig ist folgendes: Wenn ich einfach den USB-Stecker (Stromversorgung) abstecke, passiert gar nichts. Das habe ich wahrscheinlich schon 50x gemacht, wenn ich ein Backup der uSD-Card mache.<br />
Bei einem Stromausfall dürfte aber durch das Netzteil dann die Spannung langsam zusammenbrechen und sich das System dann zerstören.<br />
Kann man irgendwie einen automatischen shutdown ausführen, wenn man sich ein Powerfail-Signal generiert? Oder dauert das zu lange? (vermute ich mal)</p>
<p dir="auto">Was anderes noch: Offensichtlich wird ja automatisch eine Sicherung erstellt die man dann mit diesen Schritten wiederherstellen kann.<br />
Aktuell wird der Backitup Adapter ziemlich beworben. Bietet das dann irgendwelche Vorteile? (einfachere Wiederherstellung oder so)</p>
]]></description><link>https://forum.iobroker.net/post/761926</link><guid isPermaLink="true">https://forum.iobroker.net/post/761926</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Sun, 13 Feb 2022 18:02:23 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 17:32:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> sagte in <a href="/post/761791">[gelöst] iobroker auf Raspi startet nach Stromausfall nicht</a>:</p>
<blockquote>
<p dir="auto">Heute nach einem erneuten "Stromausfall" (geplante Abschaltung)</p>
</blockquote>
<p dir="auto">Dann plan einen sauberen shutdown der Kiste ein.</p>
]]></description><link>https://forum.iobroker.net/post/761876</link><guid isPermaLink="true">https://forum.iobroker.net/post/761876</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 13 Feb 2022 17:32:48 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 17:22:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a><br />
Ah O.K. danke!</p>
]]></description><link>https://forum.iobroker.net/post/761861</link><guid isPermaLink="true">https://forum.iobroker.net/post/761861</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Sun, 13 Feb 2022 17:22:54 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 17:02:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> sagte in <a href="/post/761817">[gelöst] iobroker auf Raspi startet nach Stromausfall nicht</a>:</p>
<blockquote>
<p dir="auto">Das?</p>
</blockquote>
<p dir="auto">nein!</p>
<p dir="auto">Da s mini HowTo<br />
<a href="https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1621158068786">https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1621158068786</a></p>
]]></description><link>https://forum.iobroker.net/post/761831</link><guid isPermaLink="true">https://forum.iobroker.net/post/761831</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 13 Feb 2022 17:02:47 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 16:55:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a><br />
Das?: <a href="https://forum.iobroker.net/topic/33496/cannot-read-system-config-null/8">https://forum.iobroker.net/topic/33496/cannot-read-system-config-null/8</a><br />
Ich habe natürlich vorher schon gesucht und auch das gefunden, bin damit aber nicht wirklich weiter gekommen.<br />
Oder gibt es noch was anderes?</p>
]]></description><link>https://forum.iobroker.net/post/761817</link><guid isPermaLink="true">https://forum.iobroker.net/post/761817</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Sun, 13 Feb 2022 16:55:36 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 16:49:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> sagte in <a href="/post/761791">[gelöst] iobroker auf Raspi startet nach Stromausfall nicht</a>:</p>
<blockquote>
<p dir="auto">Woran kann das liegen?</p>
</blockquote>
<p dir="auto">Dann such mal nach dieser Fehlermeldung</p>
<blockquote>
<p dir="auto">Cannot read system.config: null</p>
</blockquote>
<p dir="auto">und du wirst ein mini-HowTo finden mit der Lösung</p>
]]></description><link>https://forum.iobroker.net/post/761804</link><guid isPermaLink="true">https://forum.iobroker.net/post/761804</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 13 Feb 2022 16:49:43 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Sun, 13 Feb 2022 16:45:23 GMT]]></title><description><![CDATA[<p dir="auto">Heute nach einem erneuten "Stromausfall" (geplante Abschaltung) hat sich IO-Broker wieder nicht starten lassen:</p>
<pre><code>pi@iobroker:/opt/iobroker $ iobroker version
3.3.22
pi@iobroker:/opt/iobroker $ iobroker status
 Cannot read system.config: null (OK when migrating or restoring)
iobroker is not running on this host.
</code></pre>
<p dir="auto">Ist das normal, dass es das System beim Stromausfall immer zerstört?<br />
Ich habe auch noch einen weiteren Raspi mit IO-Broker in einer Wallbox laufen. Da schalte ich die Versorgung nach jedem Ladevorgang immer einfach aus und hatte noch nie Probleme.<br />
Woran kann das liegen? Es funktioniert immer der Master nicht mehr. In der Wallbox ist der Slave. Kann es damit zusammenhängen?<br />
Bzw. würde mich jetzt natürlich interessieren, wie man so ein Problem am schnellsten beheben kann oder ist die einfachste Lösung eh das Image wieder auf die SD-Card zu spielen?</p>
]]></description><link>https://forum.iobroker.net/post/761791</link><guid isPermaLink="true">https://forum.iobroker.net/post/761791</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Sun, 13 Feb 2022 16:45:23 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Fri, 11 Feb 2022 14:33:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/760456">[gelöst] iobroker auf Raspi startet nach Stromausfall nicht</a>:</p>
<blockquote>
<p dir="auto">mit node-red habe ich allerdings keine Aktien.</p>
</blockquote>
<p dir="auto">Soll ich einen neuen Thread starten? (hat ja mit dem eigentlich nichts mehr zu tun)<br />
EDIT: Habe jetzt einen neuen Thread angelegt:<br />
<a href="https://forum.iobroker.net/topic/52423/node-red-node-serialport-geht-mit-node-js-v14-19-0-nicht">https://forum.iobroker.net/topic/52423/node-red-node-serialport-geht-mit-node-js-v14-19-0-nicht</a></p>
]]></description><link>https://forum.iobroker.net/post/760465</link><guid isPermaLink="true">https://forum.iobroker.net/post/760465</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Fri, 11 Feb 2022 14:33:53 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Fri, 11 Feb 2022 13:48:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>pi@ioBrokerWallbox:~ $ cd /opt/iobroker/iobroker-data/node-red/node_modules/@serialport/bindings
pi@ioBrokerWallbox:/opt/iobroker/iobroker-data/node-red/node_modules/@serialport/bindings $
pi@ioBrokerWallbox:/opt/iobroker/iobroker-data/node-red/node_modules/@serialport/bindings $ npm rebuild
   │     New major version of npm available! 6.14.16 -&gt; 8.5.0      │
   │   Changelog: https://github.com/npm/cli/releases/tag/v8.5.0   │
   │               Run npm install -g npm to update!               │
pi@ioBrokerWallbox:/opt/iobroker/iobroker-data/node-red/node_modules/@serialport/bindings $ npm install -g npm
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/abbrev
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-align
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aproba
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/are-we-there-yet/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asap
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asn1
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/assert-plus
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/asynckit
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aws-sign2
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/aws4
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/balanced-match
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bluebird
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/buffer-from
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/builtins
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/byline
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/byte-size
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/call-limit
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/camelcase
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/capture-stack-trace
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/caseless
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chownr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ci-info
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-boxes
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/ansi-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/is-fullwidth-code-point
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/strip-ansi
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cliui/node_modules/string-width
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/clone
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/code-point-at
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/color-name
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/color-convert
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansi-styles
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/colors
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-map
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/brace-expansion
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-stream/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/console-control-strings
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/copy-concurrently/node_modules/aproba
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/copy-concurrently/node_modules/iferr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/core-util-is
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/create-error-class
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cross-spawn/node_modules/yallist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/crypto-random-string
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cyclist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dashdash
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/debug/node_modules/ms
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/debuglog
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/decamelize
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/decode-uri-component
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/deep-extend
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/defaults
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/delayed-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/combined-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/delegates
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/detect-indent
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/detect-newline
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dotenv
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexer3
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexify/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/editor
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/emoji-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/end-of-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/env-paths
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/err-code
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es6-promise
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es6-promisify
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/agent-base
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/escape-string-regexp
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/execa/node_modules/get-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/extend
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/extsprintf
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fast-json-stable-stringify
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/figgy-pudding
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/find-npm-prefix
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/forever-agent
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/from2/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-minipass/node_modules/minipass
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/iferr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs.realpath
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/function-bind
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gauge/node_modules/aproba
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gauge/node_modules/string-width
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/genfun
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/aproba
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/gentle-fs/node_modules/iferr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-caller-file
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/getpass
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/global-dirs
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/got/node_modules/get-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/graceful-fs
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-schema
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator/node_modules/fast-deep-equal
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator/node_modules/json-schema-traverse
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-flag
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-symbols
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/has-unicode
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-cache-semantics
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-proxy-agent
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/https-proxy-agent
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/iferr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/import-lazy
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/imurmurhash
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/infer-owner
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/inherits
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ini
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ip
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ip-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cidr-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-callable
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-ci/node_modules/ci-info
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-date-object
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-npm
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-obj
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dot-prop
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-redirect
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-retry-allowed
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-symbol
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es-to-primitive
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/es-abstract
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-typedarray
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isarray
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isexe
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/isstream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsbn
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ecc-jsbn
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-parse-better-errors
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-schema
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/json-stringify-safe
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsonparse
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lazy-property
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-try
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-limit
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/p-locate
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lock-verify
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lockfile
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._baseindexof
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._bindcallback
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._cacheindexof
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._createset
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._getnative
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._createcache
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._root
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash._baseuniq
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.clonedeep
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.restparam
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.union
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.uniq
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lodash.without
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lowercase-keys
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/meant
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mime-db
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mime-types
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/form-data
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minimatch
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ignore-walk
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minimist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/minizlib/node_modules/minipass
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mkdirp/node_modules/minimist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cmd-shim
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/move-concurrently/node_modules/aproba
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ms
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/humanize-ms
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/agentkeepalive
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mute-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-fetch-npm
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-cache-filename
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-logical-tree
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-normalize-package-bin
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-bundled
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/safe-buffer
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/number-is-nan
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-fullwidth-code-point
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/oauth-sign
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object-assign
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object-keys
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/define-properties
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/object.getownpropertydescriptors
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-homedir
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/os-tmpdir
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/osenv
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/nopt
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/p-finally
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pacote/node_modules/minipass
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/parallel-transform/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-exists
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/locate-path
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmconfig/node_modules/find-up
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-is-absolute
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-is-inside
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-vacuum
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-path-inside
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-installed-globally
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-key
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-run-path
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/path-parse
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/normalize-package-data/node_modules/resolve
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/performance-now
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pify
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/make-dir
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/prepend-http
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/process-nextick-args
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/are-we-there-yet/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/concat-stream/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/duplexify/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/from2/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/fs-write-stream-atomic/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/parallel-transform/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promise-inflight
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promise-retry/node_modules/retry
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/proto-list
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/config-chain
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/protoduck
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/prr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/errno
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pseudomap
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cross-spawn/node_modules/lru-cache
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/psl
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pump
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/get-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/pumpify/node_modules/pump
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/punycode
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qs
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qw
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/promzard
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-cmd-shim
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/require-directory
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/require-main-filename
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/resolve-from
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/retry
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/run-queue/node_modules/aproba
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/safe-buffer
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/safer-buffer
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/iconv-lite
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/encoding
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/semver-diff
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/set-blocking
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sha
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/shebang-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/shebang-command
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/signal-exit
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/slide
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/smart-buffer
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/socks
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/socks-proxy-agent/node_modules/agent-base
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-object
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/isarray
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sorted-union-stream/node_modules/from2
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-exceptions
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-license-ids
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-expression-parse
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-correct
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/split-on-first
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-iterate/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-iterate/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-shift
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stream-each
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strict-uri-encode
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/query-string
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string_decoder/node_modules/safe-buffer
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/ansi-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/is-fullwidth-code-point
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/string-width/node_modules/strip-ansi
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/stringify-package
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-ansi
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-eof
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/strip-json-comments
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/rc
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/registry-auth-token
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/registry-url
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/supports-color
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/chalk
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/safe-buffer
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/yallist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tar/node_modules/minipass
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/term-size
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/JSONStream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through2/node_modules/string_decoder
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/through2/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/timed-out
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tough-cookie
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tunnel-agent
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tweetnacl
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bcrypt-pbkdf
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/sshpk
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/typedarray
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uid-number
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/umask
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-lifecycle
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-slug
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-filename
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unique-string
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unpipe
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/unzip-response
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uri-js/node_modules/punycode
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/har-validator/node_modules/ajv
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/url-parse-lax
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/package-json
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/latest-version
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-deprecate
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/readable-stream
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-extend
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-installed
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/util-promisify
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-package-tree
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/uuid
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-license
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/validate-npm-package-name
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/verror
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/jsprim
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/http-signature
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/request
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wcwidth
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/which-module
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wide-align/node_modules/string-width
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npmlog
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/widest-line
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/boxen
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/worker-farm
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libcipm
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/ansi-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/is-fullwidth-code-point
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/strip-ansi
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrap-ansi/node_modules/string-width
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/wrappy
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/dezalgo
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/once
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/inflight
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-packlist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/rimraf
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/readdir-scoped-modules
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/write-file-atomic
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/bin-links
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/xdg-basedir
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/configstore
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/update-notifier
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/xtend
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mississippi
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/y18n
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yallist
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/lru-cache
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/hosted-git-info
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/read-package-json
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-install-checks
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-package-arg
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-pick-manifest
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ssri
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cacache
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/make-fetch-happen
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/node-gyp
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs-parser/node_modules/camelcase
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/ansi-regex
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/is-fullwidth-code-point
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/p-try
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/p-limit
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/p-locate
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/locate-path
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/find-up
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/strip-ansi
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/yargs/node_modules/string-width
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpx
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansicolors
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/ansistyles
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/archy
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-columns
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/cli-table3
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/columnify
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/init-package-json
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/is-cidr
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmaccess
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmhook
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmorg
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmpublish
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmsearch
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/libnpmteam
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-audit-report
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-profile
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-user-validate
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/opener
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/qrcode-terminal
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/text-table
npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/tiny-relative-date
npm ERR! code EACCES
npm ERR! syscall access
npm ERR! path /usr/lib/node_modules/npm/node_modules/abbrev
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'
npm ERR!  [Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/abbrev'] {
npm ERR!   errno: -13,
npm ERR!   code: 'EACCES',
npm ERR!   syscall: 'access',
npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/abbrev'
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check the
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR!     /home/iobroker/.npm/_logs/2022-02-11T13_46_04_107Z-debug.log
</code></pre>
<p dir="auto">Wieder mit den gleichen Fehlermeldungen nach Neustart der Instanz.</p>
]]></description><link>https://forum.iobroker.net/post/760463</link><guid isPermaLink="true">https://forum.iobroker.net/post/760463</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Fri, 11 Feb 2022 13:48:42 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Fri, 11 Feb 2022 13:33:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a></p>
<p dir="auto">Dann muss man tiefer rein.<br />
Vermutlich</p>
<pre><code>cd /opt/iobroker/iobroker-data/node-red/node_modules/@serialport/bindings
npm rebuild
</code></pre>
]]></description><link>https://forum.iobroker.net/post/760456</link><guid isPermaLink="true">https://forum.iobroker.net/post/760456</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 11 Feb 2022 13:33:01 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Fri, 11 Feb 2022 13:29:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/760448">[gelöst] iobroker auf Raspi startet nach Stromausfall nicht</a>:</p>
<blockquote>
<p dir="auto">iobroker rebuild node-red</p>
</blockquote>
<pre><code>pi@ioBrokerWallbox:~ $ iobroker rebuild node-red
npm rebuild --loglevel error (System call1) in "/opt/iobroker/node_modules/iobro                                           ker.node-red"
Rebuild node-red done
</code></pre>
<p dir="auto">Dann habe ich die Instanz neu gestartet. Aber wieder mit den gleichen Fehlermeldungen.</p>
]]></description><link>https://forum.iobroker.net/post/760454</link><guid isPermaLink="true">https://forum.iobroker.net/post/760454</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Fri, 11 Feb 2022 13:29:21 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Fri, 11 Feb 2022 13:26:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a></p>
<pre><code>iobroker rebuild node-red
</code></pre>
<p dir="auto">mal versuchen.</p>
]]></description><link>https://forum.iobroker.net/post/760448</link><guid isPermaLink="true">https://forum.iobroker.net/post/760448</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 11 Feb 2022 13:26:23 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Fri, 11 Feb 2022 13:17:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Ich verstehe leider nur Bahnhof.<br />
Verstehe ich das jetzt richtig, dass ich dieses Problem durch das Node.js Update habe?<br />
Ohne Update würde es also weiterhin funktionieren?<br />
Nun gut, zumindest habe ich jetzt ein aktuelles System.<br />
Aber was muss ich jetzt konkret machen, damit es wieder funktioniert?</p>
]]></description><link>https://forum.iobroker.net/post/760443</link><guid isPermaLink="true">https://forum.iobroker.net/post/760443</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Fri, 11 Feb 2022 13:17:43 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Fri, 11 Feb 2022 13:13:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuel001" aria-label="Profile: manuel001">@<bdi>manuel001</bdi></a> sagte in <a href="/post/760419">[gelöst] iobroker auf Raspi startet nach Stromausfall nicht</a>:</p>
<blockquote>
<p dir="auto">was compiled against a different Node.js version using        NODE_MODULE_VERSION 72. This version of Node.js requires        NODE_MODULE_VERSION 83. Please try re-compiling or re-installing        the module (for instance, using <code>npm rebuild</code> or <code>npm install</code>).</p>
</blockquote>
<p dir="auto">Muss gegen die neue ABI gebaut werden.</p>
]]></description><link>https://forum.iobroker.net/post/760438</link><guid isPermaLink="true">https://forum.iobroker.net/post/760438</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 11 Feb 2022 13:13:40 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker auf Raspi startet nach Stromausfall nicht on Fri, 11 Feb 2022 12:39:53 GMT]]></title><description><![CDATA[<p dir="auto">Ich glaube, dass ich es geschafft habe. Allerdings funktioniert es nicht:</p>
<pre><code>2022-02-11 13:32:50.937 - error: node-red.2 (951) install: ["node-red-node-serialport"]
2022-02-11 13:32:51.516 - info: node-red.2 (951) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
2022-02-11 13:32:59.638 - warn: node-red.2 (951) 11 Feb 13:32:59 - [warn] ------------------------------------------------------
2022-02-11 13:32:59.642 - warn: node-red.2 (951) 11 Feb 13:32:59 - [warn] [node-red-node-serialport/serialport] Error: The module '/opt/iobroker/iobroker-data/node-red/node_modules/@serialport/bindings/build/Release/bindings.node'
the module (for instance, using `npm rebuild` or `npm install`).
2022-02-11 13:32:59.649 - warn: node-red.2 (951) 11 Feb 13:32:59 - [warn] ------------------------------------------------------
2022-02-11 13:32:59.660 - warn: node-red.2 (951) 11 Feb 13:32:59 - [warn] Projects disabled : editorTheme.projects.enabled=false
11 Feb 13:32:59 - [info] Flows file : /opt/iobroker/iobroker-data/node-red/flows.json
</code></pre>
]]></description><link>https://forum.iobroker.net/post/760419</link><guid isPermaLink="true">https://forum.iobroker.net/post/760419</guid><dc:creator><![CDATA[Manuel001]]></dc:creator><pubDate>Fri, 11 Feb 2022 12:39:53 GMT</pubDate></item></channel></rss>
