<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Zigbee Installation: Cannot set ....zigbee: DB closed]]></title><description><![CDATA[<p dir="auto">Ich wollte wegen eines Problems den Zigbee Adapter neu installieren, leider wirft der aber ein Fehler:</p>
<pre><code>$ iobroker upgrade zigbee@1.6.14
Update zigbee from @1.6.14 to @1.6.14
NPM version: 8.3.0
Installing iobroker.zigbee@1.6.14... (System call)
host.beelink Cannot install iobroker.zigbee@1.6.14: 217
Cannot set system.adapter.zigbee: DB closed
Cannot find view "system" for search "instance" : Connection is closed.
Cannot upgrade: Cannot find view "system"
ERROR: Process exited with code 25
</code></pre>
<p dir="auto">Hat jemand eine Idee, was das sein könnte?</p>
]]></description><link>https://forum.iobroker.net/topic/52275/zigbee-installation-cannot-set-zigbee-db-closed</link><generator>RSS for Node</generator><lastBuildDate>Sat, 23 May 2026 17:22:55 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/52275.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Feb 2022 16:45:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Zigbee Installation: Cannot set ....zigbee: DB closed on Mon, 07 Feb 2022 18:18:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/merlin123" aria-label="Profile: merlin123">@<bdi>merlin123</bdi></a></p>
<p dir="auto">Für die Nachwelt: Was hast du jetzt gemacht?</p>
]]></description><link>https://forum.iobroker.net/post/757793</link><guid isPermaLink="true">https://forum.iobroker.net/post/757793</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 07 Feb 2022 18:18:59 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Installation: Cannot set ....zigbee: DB closed on Mon, 07 Feb 2022 18:17:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> so.... Geht wieder..... Danke für eure Hilfe</p>
]]></description><link>https://forum.iobroker.net/post/757792</link><guid isPermaLink="true">https://forum.iobroker.net/post/757792</guid><dc:creator><![CDATA[Merlin123]]></dc:creator><pubDate>Mon, 07 Feb 2022 18:17:35 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Installation: Cannot set ....zigbee: DB closed on Mon, 07 Feb 2022 17:26:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/merlin123" aria-label="Profile: merlin123">@<bdi>merlin123</bdi></a></p>
<p dir="auto">Was kam denn raus?</p>
]]></description><link>https://forum.iobroker.net/post/757742</link><guid isPermaLink="true">https://forum.iobroker.net/post/757742</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 07 Feb 2022 17:26:10 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Installation: Cannot set ....zigbee: DB closed on Mon, 07 Feb 2022 17:13:54 GMT]]></title><description><![CDATA[<p dir="auto">Hab grad mal alle Versionen grad gezogen und teste mal. Danke für die Rückmeldung!</p>
]]></description><link>https://forum.iobroker.net/post/757730</link><guid isPermaLink="true">https://forum.iobroker.net/post/757730</guid><dc:creator><![CDATA[Merlin123]]></dc:creator><pubDate>Mon, 07 Feb 2022 17:13:54 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Installation: Cannot set ....zigbee: DB closed on Mon, 07 Feb 2022 17:00:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/asgothian" aria-label="Profile: asgothian">@<bdi>asgothian</bdi></a> sagte in <a href="/post/757713">Zigbee Installation: Cannot set ....zigbee: DB closed</a>:</p>
<blockquote>
<p dir="auto">Ich vermute das ist das Problem.</p>
</blockquote>
<p dir="auto">Das ist aber dann kein grundsätzliches Problem, bei mir läuft es nämlich damit. (In einer 'sauberen' nodeJS-Installation).</p>
]]></description><link>https://forum.iobroker.net/post/757715</link><guid isPermaLink="true">https://forum.iobroker.net/post/757715</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 07 Feb 2022 17:00:57 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Installation: Cannot set ....zigbee: DB closed on Mon, 07 Feb 2022 16:59:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/merlin123" aria-label="Profile: merlin123">@<bdi>merlin123</bdi></a> sagte in <a href="/post/757682">Zigbee Installation: Cannot set ....zigbee: DB closed</a>:</p>
<blockquote>
<p dir="auto">NPM version: 8.3.0</p>
</blockquote>
<p dir="auto">A.</p>
]]></description><link>https://forum.iobroker.net/post/757713</link><guid isPermaLink="true">https://forum.iobroker.net/post/757713</guid><dc:creator><![CDATA[Asgothian]]></dc:creator><pubDate>Mon, 07 Feb 2022 16:59:16 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Installation: Cannot set ....zigbee: DB closed on Mon, 07 Feb 2022 16:48:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/merlin123" aria-label="Profile: merlin123">@<bdi>merlin123</bdi></a></p>
<p dir="auto">nodeJS 'senkrecht' installiert?</p>
<pre><code>sudo ln -s /usr/bin/node /usr/bin/nodejs
which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; whoami &amp;&amp; pwd &amp;&amp; sudo apt update &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
</code></pre>
]]></description><link>https://forum.iobroker.net/post/757691</link><guid isPermaLink="true">https://forum.iobroker.net/post/757691</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 07 Feb 2022 16:48:58 GMT</pubDate></item></channel></rss>
