<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ioBroker startet nicht mehr nach expand filesystem]]></title><description><![CDATA[<p dir="auto">nach dem ich ein expand filesystem gemacht habe startet ioBroker nicht mehr.</p>
<p dir="auto">in den logs sehe ich</p>
<pre><code>node /opt/iobroker/node_modules/iobroker.js-controller/contro        ller.js --logs
2022-02-03 09:57:56.034  - info: host.raspberrypi iobroker.js-controller version        3.3.22 js-controller starting
2022-02-03 09:57:56.054  - info: host.raspberrypi Copyright (c) 2014-2021 bluefo        x, 2014 hobbyquaker
2022-02-03 09:57:56.056  - info: host.raspberrypi hostname: raspberrypi, node: v        14.19.0
2022-02-03 09:57:56.257  - error: host.raspberrypi Cannot read system.config: nu        ll (OK when migrating or restoring)
2022-02-03 09:57:56.394  - info: host.raspberrypi connected to Objects and State        s
2022-02-03 09:57:56.445  - info: host.raspberrypi added notifications configurat        ion of host
2022-02-03 09:57:56.537  - error: host.raspberrypi Cannot find view "system" for        search "instance"
2022-02-03 09:57:56.540  - error: host.raspberrypi Could not add notifications c        onfig of this host: Could not get notifications setup from instances: Cannot fin        d view "system"
2022-02-03 09:57:56.636  - info: host.raspberrypi Plugin sentry Sentry Plugin di        sabled for this process because sending of statistic data is disabled for the sy        stem
2022-02-03 09:57:56.653  - error: host.raspberrypi Cannot find view "system" for        search "host"
2022-02-03 09:57:56.673  - error: host.raspberrypi Cannot find view "system" for        search "state"
2022-02-03 09:57:56.676  - error: host.raspberrypi Cannot find view "system" for        search "instance"
2022-02-03 09:57:56.683  - error: host.raspberrypi Could not collect system.host        .raspberrypi states to check for obsolete states: Error: Cannot find view "syste        m"
2022-02-03 09:57:56.686  - error: host.raspberrypi _design/system missing - call        node iobroker.js setup
2022-02-03 09:57:56.687  - info: host.raspberrypi no instances found
doc.rows is not iterable
TypeError: doc.rows is not iterable
    at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroke        r.js-controller/lib/tools.js:2863:27)
    at async getInstances (/opt/iobroker/node_modules/iobroker.js-controller/mai        n.js:2707:23)
2022-02-03 09:57:56.700  - error: host.raspberrypi uncaught exception: doc.rows        is not iterable
2022-02-03 09:57:56.702  - error: host.raspberrypi TypeError: doc.rows is not it        erable
2022-02-03 09:57:56.721  - info: host.raspberrypi iobroker _restart
2022-02-03 09:57:56.766  - error: host.raspberrypi Cannot write host object:Erro        r: DB closed
2022-02-03 09:57:56.829  - info: host.raspberrypi terminated
object system.meta.uuid cannot be updated: Error: DB closed
object system.user.admin created
</code></pre>
<p dir="auto">weiß jemand woran dies liegen kann das DB geschlossen ist?</p>
<p dir="auto">iobroker status gibt folgendes</p>
<p dir="auto">Cannot read system.config: null (OK when migrating or restoring)<br />
iobroker is not running on this host.</p>
<p dir="auto">Objects type: file<br />
States  type: file</p>
]]></description><link>https://forum.iobroker.net/topic/52124/iobroker-startet-nicht-mehr-nach-expand-filesystem</link><generator>RSS for Node</generator><lastBuildDate>Sat, 23 May 2026 22:27:32 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/52124.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Feb 2022 10:40:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ioBroker startet nicht mehr nach expand filesystem on Thu, 03 Feb 2022 10:42:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rperez" aria-label="Profile: rperez">@<bdi>rperez</bdi></a></p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/52031/iobroker-l%C3%A4uft-nicht-mehr?_=1643884101603">https://forum.iobroker.net/topic/52031/iobroker-läuft-nicht-mehr?_=1643884101603</a></p>
]]></description><link>https://forum.iobroker.net/post/754979</link><guid isPermaLink="true">https://forum.iobroker.net/post/754979</guid><dc:creator><![CDATA[sigi234]]></dc:creator><pubDate>Thu, 03 Feb 2022 10:42:38 GMT</pubDate></item></channel></rss>
