<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[gelöst] iobroker nicht erreichbar -&gt;doc.rows is not iter..]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">nach einem Adapterupdate während die Vodafone Netzverbindung weg war, bekomme ich jetzt folgenede Meldung zum Status der iobrokers:</p>
<pre><code>pi@raspberrypi-iob:~ $ sudo service iobroker status
● iobroker.service - ioBroker Server
   Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset:
   Active: active (running) since Mon 2022-01-31 15:38:10 CET; 2s ago
     Docs: http://iobroker.net
 Main PID: 4062 (iobroker.js-con)
    Tasks: 18 (limit: 4915)
   CGroup: /system.slice/iobroker.service
           ├─4062 iobroker.js-controller
           └─4080 node /opt/iobroker/node_modules/iobroker.js-controller/iobroke
Jan 31 15:38:10 raspberrypi-iob systemd[1]: Started ioBroker Server.
Jan 31 15:38:12 raspberrypi-iob bash[4062]: doc.rows is not iterable
Jan 31 15:38:12 raspberrypi-iob bash[4062]: TypeError: doc.rows is not iterable
Jan 31 15:38:12 raspberrypi-iob bash[4062]:     at Object.getInstancesOrderedByS
Jan 31 15:38:12 raspberrypi-iob bash[4062]:     at async getInstances (/opt/iobr
lines 1-15/15 (END)...skipping...
   Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
           └─4080 node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js _restart
Jan 31 15:38:12 raspberrypi-iob bash[4062]:     at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2863:27)
Jan 31 15:38:12 raspberrypi-iob bash[4062]:     at async getInstances (/opt/iobroker/node_modules/iobroker.js-controller/main.js:2707:23)
</code></pre>
<p dir="auto">Was kann ich tun?</p>
<p dir="auto">Grüße<br />
Thomas</p>
]]></description><link>https://forum.iobroker.net/topic/52014/gelöst-iobroker-nicht-erreichbar-doc-rows-is-not-iter</link><generator>RSS for Node</generator><lastBuildDate>Sun, 24 May 2026 02:35:32 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/52014.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 Jan 2022 14:43:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [gelöst] iobroker nicht erreichbar -&gt;doc.rows is not iter.. on Mon, 31 Jan 2022 19:59:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a> thx.</p>
<p dir="auto">das sieht schon a bissl besser aus:</p>
<pre><code>pi@raspberrypi-iob:/opt/iobroker/iobroker-data/backup-objects $ sudo service iobroker status
   Active: active (running) since Mon 2022-01-31 20:54:50 CET; 26s ago
 Main PID: 24285 (iobroker.js-con)
    Tasks: 22 (limit: 4915)
           ├─24285 iobroker.js-controller
           └─24376 /usr/bin/node /opt/iobroker/node_modules/iobroker.alexa2/main.js 0 info
Jan 31 20:54:55 raspberrypi-iob bash[24285]: host.raspberrypi-iob check instance "system.adapter.govee.0" for host "raspberrypi-iob"
Jan 31 20:54:55 raspberrypi-iob bash[24285]: host.raspberrypi-iob check instance "system.adapter.ble.0" for host "raspberrypi-iob"
Jan 31 20:54:55 raspberrypi-iob bash[24285]: host.raspberrypi-iob check instance "system.adapter.systeminfo.0" for host "raspberrypi-iob"
Jan 31 20:54:55 raspberrypi-iob bash[24285]: host.raspberrypi-iob check instance "system.adapter.coronavirus-statistics.0" for host "raspberrypi-iob"
Jan 31 20:54:55 raspberrypi-iob bash[24285]: host.raspberrypi-iob check instance "system.adapter.yahka.0" for host "raspberrypi-iob"
Jan 31 20:54:55 raspberrypi-iob bash[24285]: host.raspberrypi-iob check instance "system.adapter.smartcontrol.0" for host "raspberrypi-iob"
Jan 31 20:54:57 raspberrypi-iob bash[24285]: ================================== &gt; LOG REDIRECT system.adapter.admin.0 =&gt; false [Process stopped]
Jan 31 20:54:57 raspberrypi-iob bash[24285]: ================================== &gt; LOG REDIRECT system.adapter.admin.0 =&gt; false [system.adapter.admin.0.logging]
Jan 31 20:55:04 raspberrypi-iob bash[24285]: ================================== &gt; LOG REDIRECT system.adapter.javascript.0 =&gt; false [Process stopped]
Jan 31 20:55:04 raspberrypi-iob bash[24285]: ================================== &gt; LOG REDIRECT system.adapter.javascript.0 =&gt; false [system.adapter.javascript.0.logging]
</code></pre>
]]></description><link>https://forum.iobroker.net/post/753010</link><guid isPermaLink="true">https://forum.iobroker.net/post/753010</guid><dc:creator><![CDATA[tklein]]></dc:creator><pubDate>Mon, 31 Jan 2022 19:59:06 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker nicht erreichbar -&gt;doc.rows is not iter.. on Mon, 31 Jan 2022 15:06:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tklein" aria-label="Profile: tklein">@<bdi>tklein</bdi></a> sagte in <a href="/post/752727">iobroker nicht erreichbar --&gt; doc.rows is not iterable</a>:</p>
<blockquote>
<p dir="auto">Cannot read system.config: null (OK when migrating or restoring)</p>
</blockquote>
<p dir="auto"><a href="https://forum.iobroker.net/search?term=null%20(OK%20when%20migrating%20or%20restoring)&amp;in=titlesposts">https://forum.iobroker.net/search?term=null (OK when migrating or restoring)&amp;in=titlesposts</a></p>
]]></description><link>https://forum.iobroker.net/post/752744</link><guid isPermaLink="true">https://forum.iobroker.net/post/752744</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Mon, 31 Jan 2022 15:06:10 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] iobroker nicht erreichbar -&gt;doc.rows is not iter.. on Mon, 31 Jan 2022 14:52:52 GMT]]></title><description><![CDATA[<pre><code>pi@raspberrypi-iob:~ $ iobroker version
3.3.22
</code></pre>
<p dir="auto">iobroker update ergibt das:</p>
<pre><code>pi@raspberrypi-iob:~ $ iobroker update
Error: Object "system.config" not found
 Cannot read system.config: null (OK when migrating or restoring)</code></pre>
]]></description><link>https://forum.iobroker.net/post/752727</link><guid isPermaLink="true">https://forum.iobroker.net/post/752727</guid><dc:creator><![CDATA[tklein]]></dc:creator><pubDate>Mon, 31 Jan 2022 14:52:52 GMT</pubDate></item></channel></rss>
