<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[System Meldungen bei Neustart]]></title><description><![CDATA[<p dir="auto">Ich habe ein System neu aufgesetzt.<br />
Jetzt kommen beim Neustart komische Meldungen. Kann jemand was damit anfangen?</p>
<pre><code>host.raspberryPROD-Server
2021-12-24 00:37:44.492	error	Cannot move /opt/iobroker/iobroker-data/objects.json.new to /opt/iobroker/iobroker-data/objects.json: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json.new'. Try direct write as fallback
host.raspberryPROD
2021-12-24 00:37:44.024	error	Cannot find view "system" for search "instance" : Connection is closed.
host.raspberryPROD
2021-12-24 00:37:43.990	error	Cannot find view "system" for search "instance" : Connection is closed.
host.raspberryPROD
2021-12-24 00:37:43.951	error	instance system.adapter.ical.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
host.raspberryPROD
2021-12-24 00:37:43.935	error	Caught by controller[2]: at processImmediate (internal/timers.js:437:9)
host.raspberryPROD
2021-12-24 00:37:43.935	error	Caught by controller[2]: at runMicrotasks (&lt;anonymous&gt;)
host.raspberryPROD
2021-12-24 00:37:43.935	error	Caught by controller[2]: at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:479:40)
host.raspberryPROD
2021-12-24 00:37:43.935	error	Caught by controller[2]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
host.raspberryPROD
2021-12-24 00:37:43.934	error	Caught by controller[2]: Error: DB closed
host.raspberryPROD
2021-12-24 00:37:43.934	error	Caught by controller[2]: at runNextTicks (internal/process/task_queues.js:60:5)
host.raspberryPROD
2021-12-24 00:37:43.934	error	Caught by controller[2]: at Virtualpowermeter.setForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6531:35)
host.raspberryPROD
2021-12-24 00:37:43.935	error	Caught by controller[2]: at Virtualpowermeter.setForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6531:35)
host.raspberryPROD
2021-12-24 00:37:43.935	error	Caught by controller[2]: at runNextTicks (internal/process/task_queues.js:60:5)
host.raspberryPROD
2021-12-24 00:37:43.934	error	Caught by controller[2]: at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:479:40)
host.raspberryPROD
2021-12-24 00:37:43.933	error	Caught by controller[2]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:628:24)
host.raspberryPROD
2021-12-24 00:37:43.933	error	Caught by controller[1]: at processImmediate (internal/timers.js:437:9)
host.raspberryPROD
2021-12-24 00:37:43.933	error	Caught by controller[1]: at runMicrotasks (&lt;anonymous&gt;)
host.raspberryPROD
2021-12-24 00:37:43.934	error	Caught by controller[2]: at runMicrotasks (&lt;anonymous&gt;)
host.raspberryPROD
2021-12-24 00:37:43.934	error	Caught by controller[2]: at processImmediate (internal/timers.js:437:9)
host.raspberryPROD
2021-12-24 00:37:43.934	error	Caught by controller[2]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:628:24)
host.raspberryPROD
2021-12-24 00:37:43.932	error	Caught by controller[1]: at Virtualpowermeter.setForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6531:35)
host.raspberryPROD
2021-12-24 00:37:43.932	error	Caught by controller[1]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
host.raspberryPROD
2021-12-24 00:37:43.933	error	Caught by controller[1]: at runNextTicks (internal/process/task_queues.js:60:5)
host.raspberryPROD
2021-12-24 00:37:43.933	error	Caught by controller[2]: Error: DB closed
host.raspberryPROD
2021-12-24 00:37:43.933	error	Caught by controller[2]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
host.raspberryPROD
2021-12-24 00:37:43.932	error	Caught by controller[1]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:628:24)
host.raspberryPROD
2021-12-24 00:37:43.932	error	Caught by controller[1]: at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:479:40)
host.raspberryPROD
2021-12-24 00:36:43.173	error	No adapter name is specified for readBaseSettings command from system.adapter.admin.0
host.raspberryPROD
2021-12-24 00:35:31.479	error	instance system.adapter.wifilight.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
cloud.0
2021-12-24 00:02:53.633	error	Cloud says: timeout
cloud.0
2021-12-24 00:02:24.294	error	Cloud says: timeout
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/50611/system-meldungen-bei-neustart</link><generator>RSS for Node</generator><lastBuildDate>Mon, 25 May 2026 23:46:32 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/50611.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Dec 2021 23:55:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to System Meldungen bei Neustart on Fri, 24 Dec 2021 06:12:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcu" aria-label="Profile: mcu">@<bdi>mcu</bdi></a></p>
<p dir="auto">Das?</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host">https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host</a></p>
]]></description><link>https://forum.iobroker.net/post/725869</link><guid isPermaLink="true">https://forum.iobroker.net/post/725869</guid><dc:creator><![CDATA[sigi234]]></dc:creator><pubDate>Fri, 24 Dec 2021 06:12:40 GMT</pubDate></item></channel></rss>
