<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[was sagt dieser Fehler: Cannot update channel]]></title><description><![CDATA[<p dir="auto">ich bekomme seit den letzten Updates unten aufgelisteten Fehler, was bedeutet das bzw. wo kann ich da nachschauen?</p>
<pre><code>ping.0	2021-12-14 12:22:04.554	error	(7413) Cannot update channel : ping.0.fritz-repeater-Lehrte-Flur-unten Error: Error: The id "ping.0.fritz-repeater-Lehrte-Flur-unten." is invalid. Ids are not allowed to end in "."
</code></pre>
<p dir="auto">im Namen des  DP sehe ich aber keinen Punkt am Ende der Bezeichnung<br />
<img src="/assets/uploads/files/1639481170021-04ca128d-1f1a-4eda-b964-8882727a6958-image.png" alt="04ca128d-1f1a-4eda-b964-8882727a6958-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">im Ping Adapter steht der so drin<br />
<img src="/assets/uploads/files/1639481306269-c6ae03e9-1a1c-43e5-8769-822210a3458d-image.png" alt="c6ae03e9-1a1c-43e5-8769-822210a3458d-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">gerade gesehen noch zwei weitere</p>
<pre><code>ping.0	2021-12-14 12:31:06.404	error	(8190) Cannot update channel : ping.0.Ralf-Notebook Error: Error: The id "ping.0.Ralf-Notebook." is invalid. Ids are not allowed to end in "."
ping.0	2021-12-14 12:31:06.402	warn	(8190) This object will not be created in future versions. Please report this to the developer.
ping.0	2021-12-14 12:31:06.401	warn	(8190) Object ping.0.Ralf-Notebook. is invalid: obj.type has to exist
ping.0	2021-12-14 12:31:06.397	error	(8190) Cannot update channel : ping.0.fritz-repeater-Lehrte-Flur-unten Error: Error: The id "ping.0.fritz-repeater-Lehrte-Flur-unten." is invalid. Ids are not allowed to end in "."
ping.0	2021-12-14 12:31:06.395	warn	(8190) This object will not be created in future versions. Please report this to the developer.
ping.0	2021-12-14 12:31:06.394	warn	(8190) Object ping.0.fritz-repeater-Lehrte-Flur-unten. is invalid: obj.type has to exist
ping.0	2021-12-14 12:31:06.390	error	(8190) Cannot update channel : ping.0.Mobilheim-Frostwaechter Error: Error: The id "ping.0.Mobilheim-Frostwaechter." is invalid. Ids are not allowed to end in "."
ping.0	2021-12-14 12:31:06.388	warn	(8190) This object will not be created in future versions. Please report this to the developer.
ping.0	2021-12-14 12:31:06.387	warn	(8190) Object ping.0.Mobilheim-Frostwaechter. is invalid: obj.type has to exist
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/50273/was-sagt-dieser-fehler-cannot-update-channel</link><generator>RSS for Node</generator><lastBuildDate>Tue, 26 May 2026 13:34:01 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/50273.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Dec 2021 11:28:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to was sagt dieser Fehler: Cannot update channel on Wed, 15 Dec 2021 08:05:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickym" aria-label="Profile: mickym">@<bdi>mickym</bdi></a> danke, schau ich mir auch mal parallel an. Das erklärt auch warum er den Fehler mal hat und mal nicht</p>
]]></description><link>https://forum.iobroker.net/post/720610</link><guid isPermaLink="true">https://forum.iobroker.net/post/720610</guid><dc:creator><![CDATA[Rosi8818]]></dc:creator><pubDate>Wed, 15 Dec 2021 08:05:09 GMT</pubDate></item><item><title><![CDATA[Reply to was sagt dieser Fehler: Cannot update channel on Wed, 15 Dec 2021 08:04:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/haselchen" aria-label="Profile: haselchen">@<bdi>haselchen</bdi></a> den 1.5.0 habe ich installiert</p>
]]></description><link>https://forum.iobroker.net/post/720607</link><guid isPermaLink="true">https://forum.iobroker.net/post/720607</guid><dc:creator><![CDATA[Rosi8818]]></dc:creator><pubDate>Wed, 15 Dec 2021 08:04:22 GMT</pubDate></item><item><title><![CDATA[Reply to was sagt dieser Fehler: Cannot update channel on Tue, 14 Dec 2021 22:11:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rosi8818" aria-label="Profile: rosi8818">@<bdi>rosi8818</bdi></a> sagte in <a href="/post/720116">was sagt dieser Fehler: Cannot update channel</a>:</p>
<blockquote>
<p dir="auto">Ids are not allowed to end in "."</p>
</blockquote>
<p dir="auto">Welche PING Adapter Version hast Du installiert?</p>
]]></description><link>https://forum.iobroker.net/post/720509</link><guid isPermaLink="true">https://forum.iobroker.net/post/720509</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Tue, 14 Dec 2021 22:11:19 GMT</pubDate></item><item><title><![CDATA[Reply to was sagt dieser Fehler: Cannot update channel on Tue, 14 Dec 2021 22:00:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rosi8818" aria-label="Profile: rosi8818">@<bdi>rosi8818</bdi></a> Der PING Adapter kann in meinen Augen nicht mit Namen umgehen, nur mit IPAdressen. Die Namensauflösung funktioniert bei mir auch nicht. Ich nutze deshalb zusätzlich und vermehrt die PING Node in Node-Red.</p>
]]></description><link>https://forum.iobroker.net/post/720505</link><guid isPermaLink="true">https://forum.iobroker.net/post/720505</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Tue, 14 Dec 2021 22:00:12 GMT</pubDate></item></channel></rss>
