<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Neuinstallion nicht möglich]]></title><description><![CDATA[<p dir="auto">Hallo liebe Community,</p>
<p dir="auto">wollte soeben ioBroker auf meinem RaspberryPi installieren (auf Raspberry PI OS Lite)<br />
(nach dieser Anleitung):<br />
<a href="https://www.iobroker.net/#de/documentation/install/linux.md" rel="nofollow ugc">https://www.iobroker.net/#de/documentation/install/linux.md</a></p>
<p dir="auto">hat auch alles soweit funktioniert, doch bei dem<br />
doch nach</p>
<pre><code>curl -sLf https://iobroker.net/install.sh | bash -
</code></pre>
<p dir="auto">lief es zwar bis (3/4) durch, doch danach kam nicht, wie in der Anleitung beschrieben:</p>
<pre><code>ioBroker was installed successfully
Open http://localhost:8081 in a browser and start configuring!
</code></pre>
<p dir="auto">Sondern folgendes:</p>
<pre><code>==========================================================================
    Installing ioBroker (3/4)
In file included from ../../nan/nan.h:58,
                 from ../src/main.cpp:3:
/home/pi/.cache/node-gyp/12.22.7/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(v8::Local&lt;v8::Object&gt;)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local&lt;v8::Object&gt;, v8::Local&lt;v8::Value&gt;, void*)’} [-Wcast-function-type]
  736 |       (node::addon_register_func) (regfunc),                          \
/home/pi/.cache/node-gyp/12.22.7/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
  770 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
   42 | NODE_MODULE(diskusage, Init)
                 from ../src/unix_dgram.cc:5:
../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
  404 | NODE_MODULE(unix_dgram, Initialize)
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
  135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
  175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
  215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
  271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
  316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
  366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
  412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
../src/serialport.cpp: At global scope:
../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
  433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local&lt;v8::String&gt;&amp; v8str)) {
../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
  452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
In file included from ../../../nan/nan.h:58,
                 from ../src/./serialport.h:13,
                 from ../src/serialport.cpp:1:
/home/pi/.cache/node-gyp/12.22.7/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local&lt;v8::Object&gt;)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local&lt;v8::Object&gt;, v8::Local&lt;v8::Value&gt;, void*)’} [-Wcast-function-type]
../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
  486 | NODE_MODULE(serialport, init);
../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
  179 |     snprintf(data-&gt;errorString, sizeof(data-&gt;errorString), "Error %s Cannot open %s", strerror(errno), data-&gt;path);
../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
   89 |     snprintf(data-&gt;errorString, sizeof(data-&gt;errorString), "Error: %s, cannot open %s", strerror(errno), data-&gt;path);
../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
ioBroker wants to make sure to deliver the most stable smart home system.
To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
If you want to disable the error reporting you can use the command
'iobroker plugin disable sentry'
This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
</code></pre>
<p dir="auto">Nun lässt sich auch ioBroker nicht aufrufen.<br />
<strong>Bitte um Hilfe!</strong></p>
]]></description><link>https://forum.iobroker.net/topic/49266/neuinstallion-nicht-möglich</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 05:50:46 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/49266.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Nov 2021 11:47:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Neuinstallion nicht möglich on Thu, 11 Nov 2021 12:05:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hpoperator" aria-label="Profile: hpoperator">@<bdi>hpoperator</bdi></a><br />
Knalls einfach nochmal drüber:</p>
</code></pre>
]]></description><link>https://forum.iobroker.net/post/701710</link><guid isPermaLink="true">https://forum.iobroker.net/post/701710</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 11 Nov 2021 12:05:50 GMT</pubDate></item><item><title><![CDATA[Reply to Neuinstallion nicht möglich on Thu, 11 Nov 2021 12:00:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> said in <a href="/post/701701">Neuinstallion nicht möglich</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hpoperator" aria-label="Profile: hpoperator">@<bdi>hpoperator</bdi></a> sagte in <a href="/post/701698">Neuinstallion nicht möglich</a>:</p>
<blockquote>
<p dir="auto">Nun lässt sich auch ioBroker nicht aufrufen.</p>
</blockquote>
<p dir="auto">ist ja auch noch (lange) nicht fertig.<br />
Da macht die Installation nur eine (längere) Display-Auszeit.<br />
Läuft im Hintergrund weiter</p>
<p dir="auto">Warten!<br />
auf keinen Fall aabbrechen oder stören!</p>
</blockquote>
<p dir="auto">habe es abgebrochen :-(<br />
ich depp.</p>
<p dir="auto">wie komme ich denn nochmals auf anfang, bzw. wie kann ich denn das ganze nochmals deinstallieren?</p>
]]></description><link>https://forum.iobroker.net/post/701704</link><guid isPermaLink="true">https://forum.iobroker.net/post/701704</guid><dc:creator><![CDATA[hpoperator]]></dc:creator><pubDate>Thu, 11 Nov 2021 12:00:28 GMT</pubDate></item><item><title><![CDATA[Reply to Neuinstallion nicht möglich on Thu, 11 Nov 2021 11:52:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hpoperator" aria-label="Profile: hpoperator">@<bdi>hpoperator</bdi></a></p>
<p dir="auto">Das ist keine Fehlermeldung. Alles i. O.</p>
<pre><code>iobroker status
</code></pre>
<p dir="auto">liefert?</p>
]]></description><link>https://forum.iobroker.net/post/701702</link><guid isPermaLink="true">https://forum.iobroker.net/post/701702</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 11 Nov 2021 11:52:53 GMT</pubDate></item><item><title><![CDATA[Reply to Neuinstallion nicht möglich on Thu, 11 Nov 2021 11:52:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hpoperator" aria-label="Profile: hpoperator">@<bdi>hpoperator</bdi></a> sagte in <a href="/post/701698">Neuinstallion nicht möglich</a>:</p>
<blockquote>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/701701</link><guid isPermaLink="true">https://forum.iobroker.net/post/701701</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Thu, 11 Nov 2021 11:52:55 GMT</pubDate></item><item><title><![CDATA[Reply to Neuinstallion nicht möglich on Thu, 11 Nov 2021 11:48:28 GMT]]></title><description><![CDATA[<p dir="auto">Evtl. für eine Hilfestellung benötig:</p>
<pre><code> ip a
1: lo: &lt;LOOPBACK,UP,LOWER_UP&gt; mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: &lt;BROADCAST,MULTICAST,UP,LOWER_UP&gt; mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether b8:27:eb:ed:ef:6c brd ff:ff:ff:ff:ff:ff
    inet 192.168.178.48/24 brd 192.168.178.255 scope global dynamic noprefixroute eth0
       valid_lft 861907sec preferred_lft 753907sec
    inet6 2a02:810c:8cc0:1a05:6bc6:9986:4881:fb78/64 scope global dynamic mngtmpaddr noprefixroute
       valid_lft 6796sec preferred_lft 3196sec
    inet6 fe80::21ae:73e8:4f3:490f/64 scope link
3: wlan0: &lt;BROADCAST,MULTICAST&gt; mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether b8:27:eb:b8:ba:39 brd ff:ff:ff:ff:ff:ff
</code></pre>
<pre><code>ifconfig
eth0: flags=4163&lt;UP,BROADCAST,RUNNING,MULTICAST&gt;  mtu 1500
        inet 192.168.178.48  netmask 255.255.255.0  broadcast 192.168.178.255
        inet6 fe80::21ae:73e8:4f3:490f  prefixlen 64  scopeid 0x20&lt;link&gt;
        inet6 2a02:810c:8cc0:1a05:6bc6:9986:4881:fb78  prefixlen 64  scopeid 0x0&lt;global&gt;
        ether b8:27:eb:ed:ef:6c  txqueuelen 1000  (Ethernet)
        RX packets 102700  bytes 135303282 (129.0 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 53791  bytes 5253685 (5.0 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73&lt;UP,LOOPBACK,RUNNING&gt;  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10&lt;host&gt;
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 253  bytes 59145 (57.7 KiB)
        TX packets 253  bytes 59145 (57.7 KiB)
</code></pre>
]]></description><link>https://forum.iobroker.net/post/701699</link><guid isPermaLink="true">https://forum.iobroker.net/post/701699</guid><dc:creator><![CDATA[hpoperator]]></dc:creator><pubDate>Thu, 11 Nov 2021 11:48:28 GMT</pubDate></item></channel></rss>
