<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[unifi.0.default falscher Dateityp]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
seit einiger Zeit habe ich noch diverse LOG-Einträge zum Unifi-Adapter.</p>
<pre><code>State value to set for "unifi.0.default.devices.MACADRESSE.upgradable" has to be type "boolean" but received type "string"
</code></pre>
<p dir="auto">ich mache dazu auch noch bei Github einen Eintrag...</p>
<p dir="auto">Gruß,<br />
Marcus</p>
]]></description><link>https://forum.iobroker.net/topic/48775/unifi-0-default-falscher-dateityp</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 22:43:42 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/48775.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Oct 2021 08:26:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to unifi.0.default falscher Dateityp on Mon, 25 Oct 2021 16:52:04 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/iobroker-community-adapters/ioBroker.unifi/issues/470#issue-1035358968" rel="nofollow ugc">https://github.com/iobroker-community-adapters/ioBroker.unifi/issues/470#issue-1035358968</a></p>
]]></description><link>https://forum.iobroker.net/post/693720</link><guid isPermaLink="true">https://forum.iobroker.net/post/693720</guid><dc:creator><![CDATA[mguenther]]></dc:creator><pubDate>Mon, 25 Oct 2021 16:52:04 GMT</pubDate></item><item><title><![CDATA[Reply to unifi.0.default falscher Dateityp on Mon, 25 Oct 2021 16:41:22 GMT]]></title><description><![CDATA[<p dir="auto">jetzt habe ich auch noch die Umfänge:</p>
<pre><code>State value to set for "unifi.0.default.clients.MACADRESSE.channel" has to be type "string" but received type "number"
</code></pre>
]]></description><link>https://forum.iobroker.net/post/693714</link><guid isPermaLink="true">https://forum.iobroker.net/post/693714</guid><dc:creator><![CDATA[mguenther]]></dc:creator><pubDate>Mon, 25 Oct 2021 16:41:22 GMT</pubDate></item><item><title><![CDATA[Reply to unifi.0.default falscher Dateityp on Mon, 25 Oct 2021 16:35:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a></p>
<p dir="auto">tja,<br />
Instanz gestoppt, Objekte gelöscht, Instanz gestartet:</p>
</code></pre>
<p dir="auto">zumindest scheint es nicht in der stable Version 0.5.10 gelöst zu sein.</p>
]]></description><link>https://forum.iobroker.net/post/693710</link><guid isPermaLink="true">https://forum.iobroker.net/post/693710</guid><dc:creator><![CDATA[mguenther]]></dc:creator><pubDate>Mon, 25 Oct 2021 16:35:05 GMT</pubDate></item><item><title><![CDATA[Reply to unifi.0.default falscher Dateityp on Mon, 25 Oct 2021 10:01:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mguenther" aria-label="Profile: mguenther">@<bdi>mguenther</bdi></a> ja, wenn es zwischenzeitlich in einer neueren Adapter Version gefixt wurde und es sich nicht automatisch anpasst, muss man Hand anlegen und einmal manuell den DP löschen, wenn dann immer noch ein DP nicht korrekt angelegt ist, dann Issue beim jeweiligen Adapter.<br />
(manchmal kommt es vor, je nach Adapter/Ereignis, das ein DP irgendwann im späteren Verlauf erst auftaucht/beschrieben wird), wenn man z.b. den ganzen Objektbaum löscht</p>
]]></description><link>https://forum.iobroker.net/post/693430</link><guid isPermaLink="true">https://forum.iobroker.net/post/693430</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Mon, 25 Oct 2021 10:01:33 GMT</pubDate></item><item><title><![CDATA[Reply to unifi.0.default falscher Dateityp on Mon, 25 Oct 2021 09:11:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mguenther" aria-label="Profile: mguenther">@<bdi>mguenther</bdi></a> Zumindest wird das hier im Forum nach dem letzten Update des JS-Controllers diskutiert.</p>
]]></description><link>https://forum.iobroker.net/post/693400</link><guid isPermaLink="true">https://forum.iobroker.net/post/693400</guid><dc:creator><![CDATA[Meister Mopper]]></dc:creator><pubDate>Mon, 25 Oct 2021 09:11:51 GMT</pubDate></item><item><title><![CDATA[Reply to unifi.0.default falscher Dateityp on Mon, 25 Oct 2021 09:10:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meister-mopper" aria-label="Profile: meister-mopper">@<bdi>meister-mopper</bdi></a></p>
<p dir="auto">ist das so?</p>
]]></description><link>https://forum.iobroker.net/post/693399</link><guid isPermaLink="true">https://forum.iobroker.net/post/693399</guid><dc:creator><![CDATA[mguenther]]></dc:creator><pubDate>Mon, 25 Oct 2021 09:10:41 GMT</pubDate></item><item><title><![CDATA[Reply to unifi.0.default falscher Dateityp on Mon, 25 Oct 2021 08:45:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mguenther" aria-label="Profile: mguenther">@<bdi>mguenther</bdi></a> Vielleicht reicht es auch, den Adapter zu stoppen, seinen Objektbaum zu löschen und den Adapter wieder neu zu starten.<br />
Dann werden (hoffentlich) die Objekte mit dem richtigen Dateityp neu angelegt.</p>
]]></description><link>https://forum.iobroker.net/post/693390</link><guid isPermaLink="true">https://forum.iobroker.net/post/693390</guid><dc:creator><![CDATA[Meister Mopper]]></dc:creator><pubDate>Mon, 25 Oct 2021 08:45:14 GMT</pubDate></item></channel></rss>
