    2. English
    4. ESP32 CAM and GSM
    • Update NodeJS best practise, supported 14, 16 und 18!
    • Update js-controller 4.0.24 (Stable)
    • Fehler 25, 217 oder "ENOTEMPTY" bei Adapter-Install/Update
    ESP32 CAM and GSM
    • B
      barnis last edited by
      Hello all. i have been researching options to create an ESP32CAM-based Arduino solution for water meter reading. I've found quite a few great projects with lots of maturity. Unfortunately all that i have found is code which assumes a WIFI connection and I am looking for a hardware solution which can use a GSM Shield to send data either as SMS test, data text, MMS Image, or data images. I can't determine if this is easily done and if there are any good examples or tutorials which might be able to guide me. Any help would be appreciated!
      • A
        anekfor @barnis last edited by anekfor
        ESP32 development board that combines a SIM800L GSM/GPRS module. Besides Wi-Fi and Bluetooth, you can communicate with this ESP32 board using SMS or phone calls. Additionally, you can connect the ESP32 to the internet using your SIM card data plan.. .
        1.6k
        29.1k
        63.2k
        965.7k
        The ioBroker Community 2014-2021
