<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[docker:  buanet&#x2F;iobroker Raspberry 4 error]]></title><description><![CDATA[<p dir="auto">Hallo zusammen</p>
<p dir="auto">Ich versuche nun schon seit einiger Zeit, das Docker Image buanet/iobroker auf meinem Raspi 4 zum laufen zu bringen.</p>
<p dir="auto">Allerdings erfolglos und mit folgendem Log. Ich bin für jede Hilfe dankbar. Grüße Knoblauchzehe</p>
<pre><code>--------------------------------------------------------------------------------
-------------------------     1970-01-01 01:00:00      -------------------------
-----                 Welcome to your ioBroker-container!                  -----
-----                    Startupscript is now running.                     -----
-----                          Please be patient!                          -----
-----                        Debugging information                         -----
-----                                System                                -----
-----                    arch:                armv7l                       -----
-----                             Docker-Image                             -----
-----                    image:               v5.2.0                       -----
-----                    build:               2021-10-01T03:48:11+00:00    -----
-----                               Versions                               -----
terminate called after throwing an instance of 'std::length_error'
  what():  basic_string::_M_replace_aux
-----                    node:                                             -----
-----                    npm:                                              -----
-----                                 ENV                                  -----
-----                    SETGID:              1000                         -----
-----                    SETUID:              1000                         -----
-----                  Step 1 of 5: Preparing container                   -----
Nothing to do here.
-----             Step 2 of 5: Detecting ioBroker installation             -----
Existing installation of ioBroker detected in /opt/iobroker.
-----             Step 3 of 5: Checking ioBroker installation              -----
(Re)Setting folder permissions (This might take a while! Please be patient!)...
Done.
Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
cp: preserving times for '/opt/iobroker/iobroker.bak': Operation not permitted
Done.
iobroker: line 6:    65 Aborted                 gosu iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
/opt/scripts/iobroker_startup.sh: line 199: [: !=: unary operator expected
-----                Step 4 of 5: Applying special settings                -----
Some adapters have special requirements/ settings which can be activated by the use of environment variables.
For more information take a look at readme.md on Github!
-----                    Step 5 of 5: ioBroker startup                     -----
Starting ioBroker...
/opt/scripts/iobroker_startup.sh: line 505:    85 Aborted                 gosu iobroker node node_modules/iobroker.js-controller/controller.js
tail: cannot read realtime clock: Operation not permitted
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/48207/docker-buanet-iobroker-raspberry-4-error</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 17:21:34 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/48207.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 03 Oct 2021 16:17:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to docker:  buanet&#x2F;iobroker Raspberry 4 error on Wed, 06 Oct 2021 08:42:15 GMT]]></title><description><![CDATA[<p dir="auto">@ben-0 sagte in <a href="/post/685033">docker: buanet/iobroker Raspberry 4 error</a>:</p>
<blockquote>
<p dir="auto">Solltest du eine Lösung finden</p>
</blockquote>
<p dir="auto">Ich habe doch ein Link oben beigefügt und auch Andre hat ein Kommentar dort dazu geschieben , eine Lösung ist doch vorhanden !?</p>
<p dir="auto">Du hast es doch auch selber auf Github verlinkt !?</p>
]]></description><link>https://forum.iobroker.net/post/685065</link><guid isPermaLink="true">https://forum.iobroker.net/post/685065</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Wed, 06 Oct 2021 08:42:15 GMT</pubDate></item><item><title><![CDATA[Reply to docker:  buanet&#x2F;iobroker Raspberry 4 error on Wed, 06 Oct 2021 06:34:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/knoblauch-zehe" aria-label="Profile: knoblauch-zehe">@<bdi>knoblauch-zehe</bdi></a> Ich habe das gleiche Problem seit dem Update des RPi heute. Eventuell ist es auch mit dem Update vom 1.10. von ioBroker mit rein gekommen und ich habe es nicht gemerkt.</p>
<p dir="auto">Solltest du eine Lösung finden wäre ich froh du lässt es mich wissen. Umgekehrt gilt natürlich das gleiche.</p>
<p dir="auto">Danke im Voraus!</p>
<p dir="auto">EDIT: <a href="https://github.com/buanet/ioBroker.docker/issues/199" rel="nofollow ugc">https://github.com/buanet/ioBroker.docker/issues/199</a></p>
]]></description><link>https://forum.iobroker.net/post/685033</link><guid isPermaLink="true">https://forum.iobroker.net/post/685033</guid><dc:creator><![CDATA[Ben. 0]]></dc:creator><pubDate>Wed, 06 Oct 2021 06:34:39 GMT</pubDate></item><item><title><![CDATA[Reply to docker:  buanet&#x2F;iobroker Raspberry 4 error on Sun, 03 Oct 2021 17:17:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/knoblauch-zehe" aria-label="Profile: knoblauch-zehe">@<bdi>knoblauch-zehe</bdi></a> sagte in <a href="/post/684031">docker: buanet/iobroker Raspberry 4 error</a>:</p>
<blockquote>
<p dir="auto">auf meinem Raspi 4 zum laufen zu bringen.</p>
</blockquote>
<p dir="auto">Wozu? Lass das nativ laufen.</p>
]]></description><link>https://forum.iobroker.net/post/684068</link><guid isPermaLink="true">https://forum.iobroker.net/post/684068</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 03 Oct 2021 17:17:58 GMT</pubDate></item><item><title><![CDATA[Reply to docker:  buanet&#x2F;iobroker Raspberry 4 error on Sun, 03 Oct 2021 16:21:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/knoblauch-zehe" aria-label="Profile: knoblauch-zehe">@<bdi>knoblauch-zehe</bdi></a></p>
<p dir="auto">Schau mal hier :</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/4733/howto-iobroker-unter-docker-auf-synology-diskstation/2525">https://forum.iobroker.net/topic/4733/howto-iobroker-unter-docker-auf-synology-diskstation/2525</a></p>
]]></description><link>https://forum.iobroker.net/post/684036</link><guid isPermaLink="true">https://forum.iobroker.net/post/684036</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Sun, 03 Oct 2021 16:21:25 GMT</pubDate></item></channel></rss>
