<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Probleme beim Backup]]></title><description><![CDATA[<p dir="auto">Ich habe folgendes Problem. Das Backup des iobrokers bricht immer ab:</p>
<pre><code>pi@raspberrypi:/opt/iobroker/backups $ iob stop
pi@raspberrypi:/opt/iobroker/backups $ iob backup
host.raspberrypi 15355 states saved
host.raspberrypi 17179 objects saved
internal/buffer.js:956
    super(bufferOrLength, byteOffset, length);
RangeError: Array buffer allocation failed
    at new ArrayBuffer (&lt;anonymous&gt;)
    at new Uint8Array (&lt;anonymous&gt;)
    at new FastBuffer (internal/buffer.js:956:5)
    at createUnsafeBuffer (buffer.js:152:12)
    at allocate (buffer.js:419:10)
    at Function.allocUnsafe (buffer.js:384:10)
    at Function.encodeBufBulk (/opt/iobroker/node_modules/respjs/index.js:46:27)
    at RedisHandler.sendBufBulk (/opt/iobroker/node_modules/@iobroker/db-base/lib/redisHandler.js:259:44)
    at RedisHandler.&lt;anonymous&gt; (/opt/iobroker/node_modules/@iobroker/db-objects-file/lib/objects/objectsInMemServerRedis.js:452:29)
    at RedisHandler.emit (events.js:400:28)
</code></pre>
<p dir="auto"><strong>MOD-Edit: Code in code-tags gesetzt!</strong></p>
<p dir="auto">Hat da jemand einen Lösungsansatz?</p>
]]></description><link>https://forum.iobroker.net/topic/48148/probleme-beim-backup</link><generator>RSS for Node</generator><lastBuildDate>Sat, 23 May 2026 17:22:52 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/48148.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Oct 2021 13:01:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Probleme beim Backup on Tue, 08 Feb 2022 08:02:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/drillo123" aria-label="Profile: drillo123">@<bdi>drillo123</bdi></a> Hast du eine Lösung? ich habe dasselbe Problem?</p>
]]></description><link>https://forum.iobroker.net/post/758248</link><guid isPermaLink="true">https://forum.iobroker.net/post/758248</guid><dc:creator><![CDATA[hohmannc]]></dc:creator><pubDate>Tue, 08 Feb 2022 08:02:02 GMT</pubDate></item></channel></rss>
