<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NPM Install klappt nicht]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">ich benötige dringend den KNX Adapter in Version 1.0.20. über den Admin komme ich leider nur bis 0.1.38 zurück.</p>
<p dir="auto">Auf NPM steht der Adapter in 1.0.20 zur Verfügung:<br />
<a href="https://www.npmjs.com/package/iobroker.knx/v/1.0.20" rel="nofollow ugc">https://www.npmjs.com/package/iobroker.knx/v/1.0.20</a></p>
<p dir="auto">Leider kommt beim ausführen der Befehle</p>
<pre><code>cd /opt/iobroker
npm i iobroker.knx@1.0.20
</code></pre>
<p dir="auto">bzw.</p>
<pre><code>npm install https://www.npmjs.com/package/iobroker.knx/v/1.0.20
</code></pre>
<p dir="auto">immer folgende Fehlermeldung:</p>
<pre><code>pi@ioBroker-RasPi4:/opt/iobroker $ npm i iobroker.knx@1.0.20
npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in 0.5.0
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/string-similarity/package.json'
npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/xpath/package.json'
npm ERR! code EACCES
npm ERR! syscall unlink
npm ERR! path /opt/iobroker/node_modules/eibd/bin/groupread
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/eibd/bin/groupread'
npm ERR!  [OperationalError: EACCES: permission denied, unlink '/opt/iobroker/node_modules/eibd/bin/groupread'] {
npm ERR!   cause: [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/eibd/bin/groupread'] {
npm ERR!     errno: -13,
npm ERR!     code: 'EACCES',
npm ERR!     syscall: 'unlink',
npm ERR!     path: '/opt/iobroker/node_modules/eibd/bin/groupread'
npm ERR!   },
npm ERR!   path: '/opt/iobroker/node_modules/eibd/bin/groupread',
npm ERR!   parent: 'iobroker'
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check the
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR!     /home/pi/.npm/_logs/2021-09-27T19_39_58_773Z-debug.log
</code></pre>
<p dir="auto">Habt ihr eine Idee, was ich falsch mache?</p>
]]></description><link>https://forum.iobroker.net/topic/48078/npm-install-klappt-nicht</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 17:05:04 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/48078.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Sep 2021 19:46:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to NPM Install klappt nicht on Tue, 28 Sep 2021 14:39:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/loverz" aria-label="Profile: loverz">@<bdi>loverz</bdi></a></p>
<p dir="auto">Wenn du was löschen/loswerden musst, dann den eibd Kram.</p>
]]></description><link>https://forum.iobroker.net/post/682145</link><guid isPermaLink="true">https://forum.iobroker.net/post/682145</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 28 Sep 2021 14:39:40 GMT</pubDate></item><item><title><![CDATA[Reply to NPM Install klappt nicht on Tue, 28 Sep 2021 13:25:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> denke schon:</p>
<pre><code>pi@ioBroker-RasPi4:~ $ date
Di 28. Sep 15:18:39 CEST 2021
</code></pre>
<p dir="auto">Hab nun auch mal versucht den iobroker vorher zu stoppen</p>
<pre><code>iob stop
</code></pre>
<p dir="auto">brachte auch nichts. Auch ein Neustart des Raspberrys brachte nichts.<br />
Vielleicht muss ich den Adapter komplett löschen, bevor ich diese Version installieren kann, aber dann verliere ich meine ganzen händisch korrigierten Objekte, das kann ich nicht riskieren. War viel arbeit :(</p>
]]></description><link>https://forum.iobroker.net/post/682119</link><guid isPermaLink="true">https://forum.iobroker.net/post/682119</guid><dc:creator><![CDATA[loverz]]></dc:creator><pubDate>Tue, 28 Sep 2021 13:25:52 GMT</pubDate></item><item><title><![CDATA[Reply to NPM Install klappt nicht on Mon, 27 Sep 2021 20:13:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/loverz" aria-label="Profile: loverz">@<bdi>loverz</bdi></a></p>
<p dir="auto">Mit dem Adapter machst du nicht falsch.<br />
Bei mir:</p>
<pre><code>echad@chet:/opt/iobroker $ npm i iobroker.knx@1.0.20
added 17 packages in 25s
39 packages are looking for funding
  run `npm fund` for details
</code></pre>
<p dir="auto">Da ist bei eibd was krumm gelaufen. Wo auch immer das herkommt.</p>
<p dir="auto">Am Rande: Ist deine Zeitzone richtig gestellt?</p>
]]></description><link>https://forum.iobroker.net/post/681901</link><guid isPermaLink="true">https://forum.iobroker.net/post/681901</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 27 Sep 2021 20:13:08 GMT</pubDate></item></channel></rss>
