<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fehler im Log]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">ich habe einen Fehler in meinem Log.</p>
<p dir="auto">was kann ich tun?</p>
<pre><code>log fehler
host.raspberrypi
2021-09-14 11:36:46.007	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
host.raspberrypi
2021-09-14 11:36:46.007	error	Caught by controller[0]: }
host.raspberrypi
2021-09-14 11:36:46.006	error	Caught by controller[0]: ]
host.raspberrypi
2021-09-14 11:36:46.006	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
host.raspberrypi
2021-09-14 11:36:46.006	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
host.raspberrypi
2021-09-14 11:36:46.005	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
host.raspberrypi
2021-09-14 11:36:46.005	error	Caught by controller[0]: requireStack: [
host.raspberrypi
2021-09-14 11:36:46.005	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
host.raspberrypi
2021-09-14 11:36:46.004	error	Caught by controller[0]: {
host.raspberrypi
2021-09-14 11:36:46.004	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
host.raspberrypi
2021-09-14 11:36:46.004	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
host.raspberrypi
2021-09-14 11:36:46.004	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:778:12)
host.raspberrypi
2021-09-14 11:36:46.004	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:937:32)
host.raspberrypi
2021-09-14 11:36:46.003	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1101:10)
host.raspberrypi
2021-09-14 11:36:46.003	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1072:14)
host.raspberrypi
2021-09-14 11:36:46.003	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
host.raspberrypi
2021-09-14 11:36:46.003	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:92:18)
host.raspberrypi
2021-09-14 11:36:46.003	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:961:19)
host.raspberrypi
2021-09-14 11:36:46.003	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:778:12)
host.raspberrypi
2021-09-14 11:36:46.002	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:937:32)
host.raspberrypi
2021-09-14 11:36:46.002	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1101:10)
host.raspberrypi
2021-09-14 11:36:46.002	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1072:14)
host.raspberrypi
2021-09-14 11:36:46.002	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
host.raspberrypi
2021-09-14 11:36:46.002	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:92:18)
host.raspberrypi
2021-09-14 11:36:46.001	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:961:19)
host.raspberrypi
2021-09-14 11:36:46.001	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:778:12)
host.raspberrypi
2021-09-14 11:36:46.001	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:937:32)
host.raspberrypi
2021-09-14 11:36:46.001	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1101:10)
host.raspberrypi
2021-09-14 11:36:46.001	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1072:14)
host.raspberrypi
2021-09-14 11:36:46.000	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
host.raspberrypi
2021-09-14 11:36:46.000	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:92:18)
host.raspberrypi
2021-09-14 11:36:46.000	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:961:19)
host.raspberrypi
2021-09-14 11:36:46.000	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:745:27)
host.raspberrypi
2021-09-14 11:36:46.000	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:889:15)
host.raspberrypi
2021-09-14 11:36:45.999	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
host.raspberrypi
2021-09-14 11:36:45.999	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
host.raspberrypi
2021-09-14 11:36:45.999	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
host.raspberrypi
2021-09-14 11:36:45.999	error	Caught by controller[0]: Require stack:
host.raspberrypi
2021-09-14 11:36:45.999	error	Caught by controller[0]: Error: Cannot find module 'typescript'
host.raspberrypi
2021-09-14 11:36:45.998	error	Caught by controller[0]: ^
host.raspberrypi
2021-09-14 11:36:45.998	error	Caught by controller[0]: throw err;
host.raspberrypi
2021-09-14 11:36:45.998	error	Caught by controller[0]: internal/modules/cjs/loader.js:892
</code></pre>
<p dir="auto">Ich danke euch im Voraus</p>
]]></description><link>https://forum.iobroker.net/topic/47745/fehler-im-log</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 23:00:51 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/47745.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Sep 2021 09:38:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fehler im Log on Tue, 14 Sep 2021 10:17:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kk_ddorf" aria-label="Profile: kk_ddorf">@<bdi>kk_ddorf</bdi></a></p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/47662/javascript-rot-error-loader-js-nach-iobroker-neustart">https://forum.iobroker.net/topic/47662/javascript-rot-error-loader-js-nach-iobroker-neustart</a></p>
]]></description><link>https://forum.iobroker.net/post/676822</link><guid isPermaLink="true">https://forum.iobroker.net/post/676822</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Tue, 14 Sep 2021 10:17:15 GMT</pubDate></item></channel></rss>
