<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Gelöst] Installation Synology Adapter]]></title><description><![CDATA[<p dir="auto">Hi,<br />
ich kann den Synology Adapter nicht installieren.<br />
Es kommt immer diese Fehlermeldung:</p>
<pre><code>npm install iobroker.synology@1.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
npm ERR! code E404
npm ERR! 404 Not Found - GET https://codeload.github.com/homeinstalator/syno/legacy.tar.gz/master
npm ERR! 404 npm ERR! 404 'syno@https://github.com/homeinstalator/syno/tarball/master/' is not in the npm registry.npm ERR! 404 You should bug the author to publish it (or use the name yourself!)npm ERR! 404 It was specified as a dependency of 'iobroker.synology'npm ERR! 404 npm ERR! 404 Note that you can also install from a
npm ERR! 404 tarball, folder, http url, or git url.
npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-09-06T08_36_58_801Z-debug.log
host.SmartHomePi Cannot install iobroker.synology@1.0.0: 1
ERROR: Process exited with code 25
</code></pre>
<p dir="auto">Problem ist das der GET Link ins Leere läuft.<br />
Was kann ich jetzt hier tun?</p>
]]></description><link>https://forum.iobroker.net/topic/47582/gelöst-installation-synology-adapter</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 09:17:57 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/47582.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Sep 2021 08:39:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Gelöst] Installation Synology Adapter on Fri, 24 Sep 2021 18:31:38 GMT]]></title><description><![CDATA[<p dir="auto">Adapter kann wieder normal installiert werden.</p>
]]></description><link>https://forum.iobroker.net/post/680805</link><guid isPermaLink="true">https://forum.iobroker.net/post/680805</guid><dc:creator><![CDATA[draexler]]></dc:creator><pubDate>Fri, 24 Sep 2021 18:31:38 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Installation Synology Adapter on Fri, 17 Sep 2021 12:24:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/smarthomer-0" aria-label="Profile: smarthomer-0">@<bdi>smarthomer-0</bdi></a> sagte in <a href="/post/675534">Installation Synology Adapter</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a><br />
Der Adapter lässt sich installieren, hat aber leider ein Issue bei der Eingabe/Speicherung des Passworts und läuft deshalb nicht</p>
<p dir="auto"><a href="https://github.com/iobroker-community-adapters/ioBroker.synology/issues/11" rel="nofollow ugc">https://github.com/iobroker-community-adapters/ioBroker.synology/issues/11</a></p>
<p dir="auto">Der Fehler tritt zumindest bei mir genau wie beschrieben auf.</p>
</blockquote>
<p dir="auto">MeisterTR hat das in der Github Version 2.01 zumindest temporär gelöst - der Adapter läuft wieder :-)</p>
]]></description><link>https://forum.iobroker.net/post/678026</link><guid isPermaLink="true">https://forum.iobroker.net/post/678026</guid><dc:creator><![CDATA[SmartHomer 0]]></dc:creator><pubDate>Fri, 17 Sep 2021 12:24:12 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Installation Synology Adapter on Fri, 10 Sep 2021 12:41:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a><br />
]]></description><link>https://forum.iobroker.net/post/675534</link><guid isPermaLink="true">https://forum.iobroker.net/post/675534</guid><dc:creator><![CDATA[SmartHomer 0]]></dc:creator><pubDate>Fri, 10 Sep 2021 12:41:04 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Installation Synology Adapter on Tue, 07 Sep 2021 07:32:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a> Habe geantwortet. Durch den Fakt das instalator seine Repos entfernt hat ist etwas Chaos noch gerade ... gitHub version unter <a href="https://github.com/iobroker-community-adapters/ioBroker.synology" rel="nofollow ugc">https://github.com/iobroker-community-adapters/ioBroker.synology</a> tut</p>
]]></description><link>https://forum.iobroker.net/post/674591</link><guid isPermaLink="true">https://forum.iobroker.net/post/674591</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Tue, 07 Sep 2021 07:32:03 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Installation Synology Adapter on Tue, 07 Sep 2021 07:30:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a></p>
<p dir="auto">Das ist schon der zweite Thread hier , mit einem Fehler  das die falsche URL vom synology-adapter gezogen wird !</p>
<p dir="auto">Kannst du damit was anfangen ?</p>
<p dir="auto">Thread 1:</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/47494/fehlermeldung-bei-adapterinstallation?_=1630999338100">https://forum.iobroker.net/topic/47494/fehlermeldung-bei-adapterinstallation?_=1630999338100</a></p>
]]></description><link>https://forum.iobroker.net/post/674589</link><guid isPermaLink="true">https://forum.iobroker.net/post/674589</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Tue, 07 Sep 2021 07:30:44 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Installation Synology Adapter on Mon, 06 Sep 2021 21:16:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a>: Automatisch, über die verfügbaren „stable“ Adapter in „admin“ ioBroker</p>
]]></description><link>https://forum.iobroker.net/post/674545</link><guid isPermaLink="true">https://forum.iobroker.net/post/674545</guid><dc:creator><![CDATA[draexler]]></dc:creator><pubDate>Mon, 06 Sep 2021 21:16:04 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Installation Synology Adapter on Mon, 06 Sep 2021 17:10:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/draexler" aria-label="Profile: draexler">@<bdi>draexler</bdi></a> sagte in <a href="/post/674376">Installation Synology Adapter</a>:</p>
<blockquote>
<p dir="auto">Wird das dann irgendwann mal angepasst?</p>
</blockquote>
<p dir="auto">ich kann leider nicht erkennen wie du installierst hast bzw versucht hast ., manuell über URL oder  ?</p>
<p dir="auto">Eigentlich sollte über die REPO die richtige URL gezogen werden .</p>
]]></description><link>https://forum.iobroker.net/post/674380</link><guid isPermaLink="true">https://forum.iobroker.net/post/674380</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Mon, 06 Sep 2021 17:10:41 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Installation Synology Adapter on Mon, 06 Sep 2021 17:04:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a>: Danke :-)<br />
Und das heißt jetzt? Wird das dann irgendwann mal angepasst? In dem verlinkten sprechen die auch schon von einer 2.0 Version?</p>
]]></description><link>https://forum.iobroker.net/post/674376</link><guid isPermaLink="true">https://forum.iobroker.net/post/674376</guid><dc:creator><![CDATA[draexler]]></dc:creator><pubDate>Mon, 06 Sep 2021 17:04:50 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Installation Synology Adapter on Mon, 06 Sep 2021 09:27:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/draexler" aria-label="Profile: draexler">@<bdi>draexler</bdi></a></p>
<p dir="auto">Falsche URL für die Installation .</p>
<p dir="auto">ist NEU :</p>
<pre><code>https://github.com/iobroker-community-adapters/ioBroker.synology
</code></pre>
<p dir="auto">Siehe hier warum :</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/33224/iobroker-synology-adapter">https://forum.iobroker.net/topic/33224/iobroker-synology-adapter</a></p>
]]></description><link>https://forum.iobroker.net/post/674191</link><guid isPermaLink="true">https://forum.iobroker.net/post/674191</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Mon, 06 Sep 2021 09:27:02 GMT</pubDate></item></channel></rss>
