<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Gelöst]Slave neu installiert, einige Adapter bleiben gelb!]]></title><description><![CDATA[<p dir="auto">Hi Ihrs,</p>
<p dir="auto">habe meinen Slave neu installiert und mit dem Master verbunden. Es sinbd 4 Adapter auf dem Slave installiert.</p>
<p dir="auto">modbus --&gt; <span style="color:#37f21b">funktioniert</span><br />
zigbee --&gt; <span style="color:#37f21b">funktioniert</span></p>
<p dir="auto"><strong>sonoff --&gt; bleibt gelb  = FM im Log</strong></p>
<pre><code>sonoff.1	2021-08-07 08:19:58.049	info	(915) Starting MQTT server on port 1883
sonoff.1	2021-08-07 08:19:57.961	info	(915) starting. Version 2.4.5 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.1, js-controller: 3.2.16
host.RDJLTULLN	2021-08-07 08:15:57.124	info	instance system.adapter.sonoff.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
host.RDJLTULLN	2021-08-07 08:15:55.812	info	stopInstance system.adapter.sonoff.1 send kill signal
sonoff.1	2021-08-07 08:15:55.701	info	(666) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
sonoff.1	2021-08-07 08:15:55.699	info	(666) terminating
sonoff.1	2021-08-07 08:15:55.696	info	(666) Got terminate signal TERMINATE_YOURSELF
host.RDJLTULLN	2021-08-07 08:15:55.627	info	stopInstance system.adapter.sonoff.1 (force=false, process=true)
host.RDJLTULLN	2021-08-07 08:15:55.627	info	"system.adapter.sonoff.1" disabled
</code></pre>
<p dir="auto"><strong>mihome  --&gt; bleibt gelb  = FM im Log</strong></p>
<pre><code>mihome.1	2021-08-07 08:16:28.942	info	(896) Change connection status: false
mihome.1	2021-08-07 08:16:28.565	info	(896) starting. Version 1.3.7 in /opt/iobroker/node_modules/iobroker.mihome, node: v12.22.1, js-controller: 3.2.16
host.RDJLTULLN	2021-08-07 08:16:22.807	info	instance system.adapter.mihome.1 started with pid 896
host.RDJLTULLN	2021-08-07 08:16:21.864	info	"system.adapter.mihome.1" enabled
</code></pre>
<p dir="auto">auf beiden Master &amp; Slave sind die selben Adapter Versionen und:</p>
<p dir="auto">RDJLHome --&gt; MASTER</p>
<pre><code>Typ: js-controller
Titel: JS controller
OS: linux
Verfügbar: 3.3.15
Installiert: 3.2.16
</code></pre>
<p dir="auto">pi@RDJLHome:~$ node -v<br />
v12.22.1<br />
pi@RDJLHome:~$ nodejs -v<br />
v12.22.1<br />
pi@RDJLHome:~$ npm -v<br />
6.14.12<br />
<strong><strong>Fettschrift</strong></strong></p>
<p dir="auto">RDJLTULLN --&gt; SLAVE</p>
OS: linux
Verfügbar: 3.3.15
Installiert: 3.2.16
</code></pre>
<p dir="auto">pi@RDJLTULLN:~$ node -v<br />
v12.22.1<br />
pi@RDJLTULLN:~$ nodejs -v<br />
v12.22.1<br />
pi@RDJLTULLN:~$ npm -v<br />
6.14.12</p>
<p dir="auto">was kann ich dagegen tun?</p>
<p dir="auto">danke für eure Hilfe</p>
]]></description><link>https://forum.iobroker.net/topic/46829/gelöst-slave-neu-installiert-einige-adapter-bleiben-gelb</link><generator>RSS for Node</generator><lastBuildDate>Tue, 26 May 2026 19:13:00 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/46829.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Aug 2021 06:28:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Gelöst]Slave neu installiert, einige Adapter bleiben gelb! on Sat, 07 Aug 2021 07:39:11 GMT]]></title><description><![CDATA[<p dir="auto">@lls</p>
<p dir="auto">GELÖST, der Master hatte die falsche IP daher koinnte mihome und sonof sich nicht zum slave verbinden. DHCP per Router hat nie gegriffen, daher habe ich die "/etc/network/interfaces" umgeschgrieben und neugestartet ! jetzt funktionieren mihome und sonoff!</p>
]]></description><link>https://forum.iobroker.net/post/660099</link><guid isPermaLink="true">https://forum.iobroker.net/post/660099</guid><dc:creator><![CDATA[MyzerAT]]></dc:creator><pubDate>Sat, 07 Aug 2021 07:39:11 GMT</pubDate></item></channel></rss>
