<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pushover Adapter lässt sich nicht installieren - Rechte?]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">Ich würde gerne bei mir den Pushover Adapter installieren.</p>
<p dir="auto">Jedoch klappt dies nicht / hat evtl. jemand einen Tipp für mich?<br />
besten Dank</p>
<p dir="auto">vg</p>
<pre><code>
Kommando-Ausführung: $ ./iobroker add pushover --host iobroker
Fertig mit Fehler: host.iobroker Cannot install iobroker.pushover@2.0.5: 243
host.iobroker	2021-07-21 09:44:28.697	error	iobroker host.iobroker Cannot install iobroker.pushover@2.0.5: 243
host.iobroker	2021-07-21 09:44:28.600	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-07-21T09_44_28_566Z-debug.log
host.iobroker	2021-07-21 09:44:28.557	info	iobroker npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/miio/node_modules/amounts'npm ERR! [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/miio/n
host.iobroker	2021-07-21 09:44:28.544	info	iobroker npm ERR! code EACCESnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/miio/node_modules/amountsnpm ERR! errno -13
10 silly saveTree +-- semver@5.7.1
110 silly saveTree `-- yargs@7.1.1
111 warn typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself.
112 warn typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself.
113 verbose stack Error: EACCES: permission denied, access '/opt/iobroker/node_modules/miio/node_modules/amounts'
114 verbose cwd /opt/iobroker
115 verbose Linux 5.4.34-1-pve
116 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.pushover@2.0.5" "--loglevel" "error" "--prefix" "/opt/iobroker"
117 verbose node v12.20.0
118 verbose npm  v6.14.8
119 error code EACCES
120 error syscall access
121 error path /opt/iobroker/node_modules/miio/node_modules/amounts
122 error errno -13
123 error Error: EACCES: permission denied, access '/opt/iobroker/node_modules/miio/node_modules/amounts'
123 error  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/miio/node_modules/amounts'] {
123 error   errno: -13,
123 error   code: 'EACCES',
123 error   syscall: 'access',
123 error   path: '/opt/iobroker/node_modules/miio/node_modules/amounts'
123 error }
124 error The operation was rejected by your operating system.
124 error It is likely you do not have the permissions to access this file as the current user
124 error
124 error If you believe this might be a permissions issue, please double-check the
124 error permissions of the file and its containing directories, or try running
124 error the command again as root/Administrator.
125 verbose exit [ -13, true ]
</code></pre>
<p dir="auto">Versionen:<br />
Node.js<br />
v12.20.0 (Es gibt eine neuere Version: v12.22.3)<br />
NPM<br />
6.14.8</p>
]]></description><link>https://forum.iobroker.net/topic/46478/pushover-adapter-lässt-sich-nicht-installieren-rechte</link><generator>RSS for Node</generator><lastBuildDate>Tue, 26 May 2026 07:37:15 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/46478.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Jul 2021 10:11:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pushover Adapter lässt sich nicht installieren - Rechte? on Wed, 21 Jul 2021 19:43:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Danke für den Tipp - nach dem fix hatte ich erst noch Probleme mit einigen Adaptern, die nicht gleich gestartet sind, und sich scheinbar laut log neu installiert haben - nach 30-40 Minuten lief aber alles wieder optimal.</p>
<p dir="auto">Klasse :)</p>
<p dir="auto">nodeJS - schaue ich mir an - danke auch für diesen Hinweis</p>
]]></description><link>https://forum.iobroker.net/post/655014</link><guid isPermaLink="true">https://forum.iobroker.net/post/655014</guid><dc:creator><![CDATA[Randyh]]></dc:creator><pubDate>Wed, 21 Jul 2021 19:43:45 GMT</pubDate></item><item><title><![CDATA[Reply to Pushover Adapter lässt sich nicht installieren - Rechte? on Wed, 21 Jul 2021 12:32:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/randyh" aria-label="Profile: randyh">@<bdi>randyh</bdi></a></p>
<p dir="auto">Und wenn du da mit dem</p>
<pre><code>iobroker fix
</code></pre>
<p dir="auto">mal rummachst?</p>
<p dir="auto">BTW: nodeJS aktuell halten.</p>
]]></description><link>https://forum.iobroker.net/post/654904</link><guid isPermaLink="true">https://forum.iobroker.net/post/654904</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 21 Jul 2021 12:32:44 GMT</pubDate></item><item><title><![CDATA[Reply to Pushover Adapter lässt sich nicht installieren - Rechte? on Wed, 21 Jul 2021 12:20:50 GMT]]></title><description><![CDATA[<p dir="auto">Danke für eure Antworten.</p>
<p dir="auto">Also ich habe das ganze unter Debian am laufen in einem proxmox container.</p>
<p dir="auto">Den Adapter hätte ich ganz normal über die Weboberfläche installiert / und daraus habe ich auch das Kommando inkl. der Meldung komplett raus kopiert.<br />
(Zeile 2+3)<br />
Angemeldet bin ich hier nicht extra.</p>
<p dir="auto">Die Zeilen 7-10 habe ich aus dem Log / Weboberfläche vom Io raus kopiert</p>
<p dir="auto">Die weiteren Zeilen aus der genannten debug.log datei</p>
]]></description><link>https://forum.iobroker.net/post/654899</link><guid isPermaLink="true">https://forum.iobroker.net/post/654899</guid><dc:creator><![CDATA[Randyh]]></dc:creator><pubDate>Wed, 21 Jul 2021 12:20:50 GMT</pubDate></item><item><title><![CDATA[Reply to Pushover Adapter lässt sich nicht installieren - Rechte? on Wed, 21 Jul 2021 10:25:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/randyh" aria-label="Profile: randyh">@<bdi>randyh</bdi></a></p>
<p dir="auto">Wenn du die komplette Ein- und Ausgabe ungefiltert inkl. login prompt gepostet hättest könnte man da vielleicht was zu sagen. So nicht.</p>
]]></description><link>https://forum.iobroker.net/post/654875</link><guid isPermaLink="true">https://forum.iobroker.net/post/654875</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 21 Jul 2021 10:25:25 GMT</pubDate></item><item><title><![CDATA[Reply to Pushover Adapter lässt sich nicht installieren - Rechte? on Wed, 21 Jul 2021 10:13:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/randyh" aria-label="Profile: randyh">@<bdi>randyh</bdi></a><br />
welches System benutzt du?<br />
Warum ./iobroker und nicht iobroker?<br />
Welcher Account war angemeldet?</p>
]]></description><link>https://forum.iobroker.net/post/654873</link><guid isPermaLink="true">https://forum.iobroker.net/post/654873</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 21 Jul 2021 10:13:50 GMT</pubDate></item></channel></rss>
