<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fehler nach Backup: packetName vis-material]]></title><description><![CDATA[<p dir="auto">Ich habe gestern ein node update von 10 auf 12 gemacht (Synology/Docker). Einfachste Methode. Neuer Container und Backup einspielen. Alles lief schnell und reibungslos. Allerdings gibt es eine Fehlermeldung beim Neustart:</p>
<pre><code>
2021-07-10 03:02:02.408 - warn: host.iobroker_V51 startInstance cannot find adapter "vis-material@0.1.3". Try to install it... 1 attempt
2021-07-10 03:02:02.409 - info: host.iobroker_V51 iobroker install vis-material@0.1.3 using installedFrom
2021-07-10 03:02:02.548 - info: host.iobroker_V51 instance system.adapter.admin.0 started with pid 455
2021-07-10 03:02:04.197 - error: host.iobroker_V51 iobroker npm-install: host.iobroker_V51 Unknown packetName vis-material
2021-07-10 03:02:04.198 - info: host.iobroker_V51 iobroker npm-install: host.iobroker_V51 download vis-materialFile not found: vis-material
2021-07-10 03:02:04.201 - info: host.iobroker_V51 iobroker npm-install: exit 1
2021-07-10 03:02:04.567 - info: admin.0 (455) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.2, js-controller: 3.2.16
2021-07-10 03:02:04.609 - info: admin.0 (455) requesting all states
2021-07-10 03:02:04.609 - info: admin.0 (455) requesting all objects
2021-07-10 03:02:05.473 - warn: host.iobroker_V51 startInstance cannot find adapter "vis-materialdesign@0.5.9". Try to install it... 1 attempt
2021-07-10 03:02:05.474 - info: host.iobroker_V51 iobroker install vis-materialdesign@0.5.9 using installedFrom
2021-07-10 03:02:05.994 - info: admin.0 (455) received all objects
2021-07-10 03:02:06.124 - info: admin.0 (455) http server listening on port 8081
2021-07-10 03:02:06.124 - info: admin.0 (455) Use link "http://localhost:8081" to configure.
2021-07-10 03:02:06.500 - info: host.iobroker_V51 instance system.adapter.alexa2.0 started with pid 477
2021-07-10 03:02:07.435 - error: host.iobroker_V51 iobroker npm-install: host.iobroker_V51 Unknown packetName vis-materialdesign
2021-07-10 03:02:07.445 - info: host.iobroker_V51 iobroker npm-install: host.iobroker_V51 download vis-materialdesignFile not found: vis-materialdesign
2021-07-10 03:02:07.458 - info: host.iobroker_V51 iobroker npm-install: exit 1
</code></pre>
<p dir="auto">Was kann ich tun damit der Fehler verschwindet? Aufgefallen das mir was fehlt in VIS ist mir nicht. Nutze es aber auch nur selten, da weitest gehend alles automatisch bei mir läuft…</p>
]]></description><link>https://forum.iobroker.net/topic/46309/fehler-nach-backup-packetname-vis-material</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 17:29:24 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/46309.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Jul 2021 06:27:25 GMT</pubDate><ttl>60</ttl></channel></rss>
