<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fehlermeldungen bei Adapter - Updates]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">bei jedem Update bekomme ich immer diese Fehlermeldungen obwohl das Update des Adapters ohne Probleme installiert wird.</p>
<p dir="auto">Was kann / muss ich hier machen um diese Fehler zu beseitigen (für Anfänger bitte erklären :-))</p>
<p dir="auto">Danke...</p>
<pre><code>code_text
```NPM version: 6.14.12
npm install iobroker.vis@1.4.1 --loglevel error --prefix "/opt/iobroker" (System call)
sharp: Installation error: Use with glibc 2.24 requires manual installation of libvips &gt;= 8.10.6
In file included from ../src/common.cc:24:0:
/usr/local/include/vips/vips8:35:25: fatal error: glib-object.h: Datei oder Verzeichnis nicht gefunden #include &lt;glib-object.h&gt; ^compilation terminated.
make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:314:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 4.4.132+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.iot/node_modules/sharpgyp ERR! node -v v12.22.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok</code></pre>
]]></description><link>https://forum.iobroker.net/topic/46204/fehlermeldungen-bei-adapter-updates</link><generator>RSS for Node</generator><lastBuildDate>Mon, 25 May 2026 20:21:04 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/46204.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Jul 2021 13:05:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fehlermeldungen bei Adapter - Updates on Sun, 04 Jul 2021 14:03:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/njdfg" aria-label="Profile: njdfg">@<bdi>njdfg</bdi></a> sagte in <a href="/post/649701">Fehlermeldungen bei Adapter - Updates</a>:</p>
<blockquote>
<p dir="auto">Buster Image runterladen (läuft das auf dem Tinkerboard?</p>
</blockquote>
<p dir="auto">nimm ein aktuelles armbian, das läuft.<br />
ob es ein passendes linaro g7bt weiß ich nicht</p>
]]></description><link>https://forum.iobroker.net/post/649722</link><guid isPermaLink="true">https://forum.iobroker.net/post/649722</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 04 Jul 2021 14:03:22 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen bei Adapter - Updates on Sun, 04 Jul 2021 14:05:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/njdfg" aria-label="Profile: njdfg">@<bdi>njdfg</bdi></a> sagte in <a href="/post/649682">Fehlermeldungen bei Adapter - Updates</a>:</p>
<blockquote>
<p dir="auto">npm install iobroker.vis@1.4.1</p>
</blockquote>
<p dir="auto">Bist du auf <strong>BETA</strong> mit deinem ioBroker?</p>
<p dir="auto">Aktuell ist in Beta 1.4.2 die 1.4.1 wurde zurückgenommen/überarbeitet</p>
<pre><code>1.4.2 (2021-07-04)
    (bluefox) Added possibility to check license offline (only special once)
</code></pre>
]]></description><link>https://forum.iobroker.net/post/649720</link><guid isPermaLink="true">https://forum.iobroker.net/post/649720</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Sun, 04 Jul 2021 14:05:17 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen bei Adapter - Updates on Sun, 04 Jul 2021 13:37:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/njdfg" aria-label="Profile: njdfg">@<bdi>njdfg</bdi></a> Mit Backitup ein Backup ziehen ist immer eine gute Idee.</p>
<p dir="auto">Wie du dann das System auf Buster bringst kann ich dir nicht sagen, kenne die Tinkerboard-Plattform nicht. Aber eine frische Neuinstallation ist vermutlich der beste Weg, hast ja ein Backup vom ioBroker.</p>
]]></description><link>https://forum.iobroker.net/post/649703</link><guid isPermaLink="true">https://forum.iobroker.net/post/649703</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 04 Jul 2021 13:37:22 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen bei Adapter - Updates on Sun, 04 Jul 2021 13:33:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Wie wäre die einfachste Vorgehensweise?</p>
<ul>
<li>
<p dir="auto">Alles per BackItup sichern.</p>
</li>
<li>
</li>
<li>
<p dir="auto">Image auf SD-Karte mi z.B. Etcher?</p>
</li>
<li>
<p dir="auto">Manuell Iobroker installieren</p>
</li>
<li>
<p dir="auto">Backitup installieren</p>
</li>
<li>
<p dir="auto">Alles zurück sichern</p>
</li>
<li>
<p dir="auto">hoffen das alle 44 Adapter wieder laufen... (Grafana, Homemtic, InfluxDB, meine Scripte, meine Widget usw...)</p>
</li>
</ul>
<p dir="auto">korrekt so?</p>
]]></description><link>https://forum.iobroker.net/post/649701</link><guid isPermaLink="true">https://forum.iobroker.net/post/649701</guid><dc:creator><![CDATA[Njdfg]]></dc:creator><pubDate>Sun, 04 Jul 2021 13:33:10 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen bei Adapter - Updates on Sun, 04 Jul 2021 13:23:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/njdfg" aria-label="Profile: njdfg">@<bdi>njdfg</bdi></a> Stretch ist tot.<br />
Bring das System auf Buster.</p>
]]></description><link>https://forum.iobroker.net/post/649697</link><guid isPermaLink="true">https://forum.iobroker.net/post/649697</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 04 Jul 2021 13:23:45 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen bei Adapter - Updates on Sun, 04 Jul 2021 13:22:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent<br />
permitted by applicable law.<br />
Last login: Thu Jul  1 17:27:57 2021<br />
linaro@tinkerboard:~$ lsb_release -d<br />
Description:    Debian GNU/Linux 9.13 (stretch)<br />
linaro@tinkerboard:~$</p>
]]></description><link>https://forum.iobroker.net/post/649696</link><guid isPermaLink="true">https://forum.iobroker.net/post/649696</guid><dc:creator><![CDATA[Njdfg]]></dc:creator><pubDate>Sun, 04 Jul 2021 13:22:55 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen bei Adapter - Updates on Sun, 04 Jul 2021 13:18:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/njdfg" aria-label="Profile: njdfg">@<bdi>njdfg</bdi></a><br />
Bitte den Text in CodeTags posten. Danke.</p>
<p dir="auto">Und dein System auf etwas aktuelles, noch lebendes umstellen. Da läuft bestimmt ein obsoletes Debian.</p>
]]></description><link>https://forum.iobroker.net/post/649693</link><guid isPermaLink="true">https://forum.iobroker.net/post/649693</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 04 Jul 2021 13:18:59 GMT</pubDate></item></channel></rss>
