<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[iobroker startet nicht - cannot find module &#x27;picomatch&#x27;]]></title><description><![CDATA[<p dir="auto">Hallo liebe Mit-ioBroker-ler,<br />
nachdem meine noch recht junge ioBroker-Karriere doch ganz gut gestartet ist bin ich jetzt an einem Punkt wo ich eure Hilfe benötige.</p>
<p dir="auto">Nach diversen Updates will mein ioBroker gar nicht mehr. Egal ob ich ihn starten will, den Status abfragen oder sonst was, das Einzige was ich zurück kriege ist folgendes:</p>
<pre><code> iobroker start admin.0
internal/modules/cjs/loader.js:818
  throw err;
Error: Cannot find module 'picomatch'
Require stack:
- /opt/iobroker/node_modules/readdirp/index.js
- /opt/iobroker/node_modules/chokidar/index.js
- /opt/iobroker/node_modules/iobroker.js-controller/lib/cli/cliLogs.js
- /opt/iobroker/node_modules/iobroker.js-controller/lib/cli/index.js
- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    at Module.require (internal/modules/cjs/loader.js:887:19)
    at require (internal/modules/cjs/helpers.js:74:18)
    at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/readdirp/index.js:7:19)
    at Module._compile (internal/modules/cjs/loader.js:999:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    at Module.load (internal/modules/cjs/loader.js:863:32)
    at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    at Module.require (internal/modules/cjs/loader.js:887:19) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [
    '/opt/iobroker/node_modules/readdirp/index.js',
    '/opt/iobroker/node_modules/chokidar/index.js',
    '/opt/iobroker/node_modules/iobroker.js-controller/lib/cli/cliLogs.js',
    '/opt/iobroker/node_modules/iobroker.js-controller/lib/cli/index.js',
    '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
    '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
</code></pre>
<p dir="auto">Der aktuelle Stand an Versionen ist folgender:</p>
<pre><code>pi@raspberrypi:~ $ npm -v
6.14.12
pi@raspberrypi:~ $ node -v
v12.22.1
pi@raspberrypi:~ $ nodejs -v
v12.22.1
</code></pre>
<p dir="auto">Meint ihr ich habe ihn mir komplett zerschossen, dass nur noch neu aufsetzen hilft oder ist da noch was zu retten?</p>
<p dir="auto">Danke euch schonmal im Voraus!</p>
]]></description><link>https://forum.iobroker.net/topic/45807/iobroker-startet-nicht-cannot-find-module-picomatch</link><generator>RSS for Node</generator><lastBuildDate>Mon, 25 May 2026 17:08:37 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/45807.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Jun 2021 21:37:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Mon, 28 Jun 2021 04:15:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noobyn00b" aria-label="Profile: noobyn00b">@<bdi>noobyn00b</bdi></a> also entweder installierst du den Adapter neu.. und lernst die Geräte wenns ncht so viele sind neu an ..</p>
<p dir="auto">oder</p>
<p dir="auto">du entpakst das backupfile..<br />
da drin findet du bestimmt einen iobroker-data verzeichniss in dem ein zigbee_0 (es kann auch zigbee.0 sein) Verzeichniss drin ist<br />
das kopiertst du ins /opt/iobroker/iobroker-data rein (somit sind die Geräte schon mal alle da)</p>
<p dir="auto">wenn du nix an der zigbee konfig damals vor dem backup geändert hast<br />
zuerst den adapter aus dem GIT installieren..<br />
dann starten</p>
<p dir="auto">hast du was an der konfig geändert musst du die backup.json dir anschauen und drin am besten nach panid suchen.. (bei mir ist diese Datei 50 mb gross)</p>
<p dir="auto">jetzt hast du die Einstellungen gefunden kannst die übernehmen und den adapter starten<br />
...</p>
<p dir="auto">sollte jetzt keine Geräte da sein wieder melden.</p>
]]></description><link>https://forum.iobroker.net/post/647095</link><guid isPermaLink="true">https://forum.iobroker.net/post/647095</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Mon, 28 Jun 2021 04:15:37 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Sun, 27 Jun 2021 19:36:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noobyn00b" aria-label="Profile: noobyn00b">@<bdi>noobyn00b</bdi></a></p>
<p dir="auto">Da kann ich auch nicht helfen.</p>
]]></description><link>https://forum.iobroker.net/post/647060</link><guid isPermaLink="true">https://forum.iobroker.net/post/647060</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 27 Jun 2021 19:36:50 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Sun, 27 Jun 2021 19:33:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
selbst das erste Back-Up will er nicht wiederherstellen, immer mit dem gleichen Fehler. <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":disappointed:" alt="😞" /></p>
]]></description><link>https://forum.iobroker.net/post/647059</link><guid isPermaLink="true">https://forum.iobroker.net/post/647059</guid><dc:creator><![CDATA[noobyn00b]]></dc:creator><pubDate>Sun, 27 Jun 2021 19:33:03 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Mon, 21 Jun 2021 19:35:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noobyn00b" aria-label="Profile: noobyn00b">@<bdi>noobyn00b</bdi></a> Älteres Backup nehmen</p>
]]></description><link>https://forum.iobroker.net/post/645137</link><guid isPermaLink="true">https://forum.iobroker.net/post/645137</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 21 Jun 2021 19:35:58 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Mon, 21 Jun 2021 18:54:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Leider kriege ich beim Einspielen des Backups den gleichen Fehler.</p>
<pre><code>[ERROR] [iobroker] internal/modules/cjs/loader.js:1044
[ERROR] [iobroker] throw err;
[ERROR] [iobroker] ^
[ERROR] [iobroker] SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167
[ERROR] [iobroker] at parse ()
[ERROR] [iobroker] at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)
[ERROR] [iobroker] at Module.load (internal/modules/cjs/loader.js:863:32)
[ERROR] [iobroker] at Function.Module._load (internal/modules/cjs/loader.js:708:14)
[ERROR] [iobroker] at Module.require (internal/modules/cjs/loader.js:887:19)
[ERROR] [iobroker] at require (internal/modules/cjs/helpers.js:74:18)
[ERROR] [iobroker] at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:480:19)
[ERROR] [iobroker] at BackupRestore.reloadAdaptersObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:550:29)
[ERROR] [iobroker] at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:569:34
[ERROR] [iobroker] at upload (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:370:51)
[DEBUG] [iobroker] ioBroker Restore completed successfully
[EXIT] 1 **** Restore was canceled!! ****
</code></pre>
]]></description><link>https://forum.iobroker.net/post/645106</link><guid isPermaLink="true">https://forum.iobroker.net/post/645106</guid><dc:creator><![CDATA[noobyn00b]]></dc:creator><pubDate>Mon, 21 Jun 2021 18:54:52 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Sun, 20 Jun 2021 21:52:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noobyn00b" aria-label="Profile: noobyn00b">@<bdi>noobyn00b</bdi></a> Da ist wohl die io-package.json korrupt. Backup einspielen.</p>
]]></description><link>https://forum.iobroker.net/post/644800</link><guid isPermaLink="true">https://forum.iobroker.net/post/644800</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 20 Jun 2021 21:52:41 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Sun, 20 Jun 2021 21:03:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Du bist der Beste! Es lebt wieder. Danke Dir vielmals! <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
<p dir="auto">Jetzt habe ich aber wieder das alte Problem, mit dem die ganze Misere angefangen hat.<br />
Der Zigbee-Adapter lässt sich nicht starten, jetzt habe ich in mal versucht neu zu installieren, kriege bei der Installation aber folgenden Fehler:</p>
<pre><code>$ ./iobroker add zigbee  --host raspberrypi
ERROR: internal/modules/cjs/loader.js:1044    throw err;    ^SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167    at parse (&lt;anonymous&gt;)    at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)    at Module.load (internal/modules/cjs/loader.js:863:32)    at Function.Module._load (internal/modules/cjs/loader.js:708:14)    at Module.require (internal/modules/cjs/loader.js:887:19)    at require (internal/modules/cjs/helpers.js:74:18)    at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:480:19)    at Immediate.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:847:20)    at processImmediate (internal/timers.js:463:21)
</code></pre>
<p dir="auto">Kannst du eventuell auch dazu was sagen?</p>
]]></description><link>https://forum.iobroker.net/post/644789</link><guid isPermaLink="true">https://forum.iobroker.net/post/644789</guid><dc:creator><![CDATA[noobyn00b]]></dc:creator><pubDate>Sun, 20 Jun 2021 21:03:15 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Thu, 17 Jun 2021 21:47:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noobyn00b" aria-label="Profile: noobyn00b">@<bdi>noobyn00b</bdi></a><br />
Kniffelig. Ich kann da auch nur raten.</p>
<pre><code>cd /opt/iobroker
npm install picomatch
</code></pre>
<p dir="auto">Wie schaut denn deine nodeJS jetzt aus?</p>
<pre><code>which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; sudo apt update &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
</code></pre>
]]></description><link>https://forum.iobroker.net/post/643794</link><guid isPermaLink="true">https://forum.iobroker.net/post/643794</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 17 Jun 2021 21:47:41 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Thu, 17 Jun 2021 21:11:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Schuldig im Sinne der Anklage, habe mein node aktualisiert - bzw es versucht - weil diverse Adapter auf einmal nicht mehr funktioniert haben.. danach ging gar nichts mehr.</p>
<p dir="auto">Wie kann ich den Adapter denn deinstallieren? Ich komme nicht mehr in die GUI und beim manuellen deinstallieren kommt wieder die gleiche Fehlermeldung.</p>
<pre><code>pi@raspberrypi:/opt/iobroker $ iobroker del alexa2
  throw err;
Require stack:
  requireStack: [
</code></pre>
]]></description><link>https://forum.iobroker.net/post/643788</link><guid isPermaLink="true">https://forum.iobroker.net/post/643788</guid><dc:creator><![CDATA[noobyn00b]]></dc:creator><pubDate>Thu, 17 Jun 2021 21:11:46 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Thu, 17 Jun 2021 20:16:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noobyn00b" aria-label="Profile: noobyn00b">@<bdi>noobyn00b</bdi></a> Da hast du mal mit npm@7 herumgemacht, stimmt es?</p>
<p dir="auto">Installier alexa2 nochmal neu.</p>
]]></description><link>https://forum.iobroker.net/post/643775</link><guid isPermaLink="true">https://forum.iobroker.net/post/643775</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 17 Jun 2021 20:16:17 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Thu, 17 Jun 2021 19:37:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>pi@raspberrypi:~ $ cd /opt/iobroker
pi@raspberrypi:/opt/iobroker $ npm list picomatch
npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
iobroker.inst@2.0.3 /opt/iobroker
├─┬ UNMET DEPENDENCY iobroker.alexa2@3.8.1
│ └─┬ UNMET DEPENDENCY alexa-remote2@3.7.1
│   └─┬ UNMET DEPENDENCY alexa-cookie2@3.4.2
│     └─┬ UNMET DEPENDENCY http-proxy-middleware@1.0.6
│       └─┬ UNMET DEPENDENCY micromatch@4.0.2
│         └── UNMET DEPENDENCY picomatch@2.2.2
└─┬ iobroker.js-controller@3.1.6
  └─┬ chokidar@3.5.1
    ├─┬ anymatch@3.1.1
    └─┬ readdirp@3.5.0
npm ERR! missing: iobroker.alexa2@3.8.1, required by iobroker.inst@2.0.3
npm ERR! missing: alexa-remote2@3.7.1, required by iobroker.alexa2@3.8.1
npm ERR! missing: alexa-cookie2@3.4.2, required by alexa-remote2@3.7.1
npm ERR! missing: http-proxy-middleware@1.0.6, required by alexa-cookie2@3.4.2
npm ERR! missing: micromatch@4.0.2, required by http-proxy-middleware@1.0.6
npm ERR! missing: picomatch@2.2.2, required by micromatch@4.0.2
npm ERR! missing: picomatch@2.2.2, required by anymatch@3.1.1
npm ERR! missing: picomatch@2.2.2, required by readdirp@3.5.0
</code></pre>
<p dir="auto">Kann ich das "einfach" über npm nachinstallieren oder ist das nur eine Symptom- und keine Ursachenbekämpfung?</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arteck" aria-label="Profile: arteck">@<bdi>arteck</bdi></a><br />
Weil ich über das normale "iobroker start" gar keine Rückmeldung bekommen habe, und so wenigstens die o.g. Fehlermeldung.</p>
]]></description><link>https://forum.iobroker.net/post/643766</link><guid isPermaLink="true">https://forum.iobroker.net/post/643766</guid><dc:creator><![CDATA[noobyn00b]]></dc:creator><pubDate>Thu, 17 Jun 2021 19:37:30 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Wed, 16 Jun 2021 06:26:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noobyn00b" aria-label="Profile: noobyn00b">@<bdi>noobyn00b</bdi></a> sagte in <a href="/post/643074">iobroker startet nicht - cannot find module 'picomatch'</a>:</p>
<blockquote>
<p dir="auto">iobroker start admin.0</p>
</blockquote>
<p dir="auto">warum startest du den admin von der consle aus ?</p>
]]></description><link>https://forum.iobroker.net/post/643111</link><guid isPermaLink="true">https://forum.iobroker.net/post/643111</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Wed, 16 Jun 2021 06:26:15 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht - cannot find module &#x27;picomatch&#x27; on Tue, 15 Jun 2021 21:56:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noobyn00b" aria-label="Profile: noobyn00b">@<bdi>noobyn00b</bdi></a></p>
npm list picomatch
</code></pre>
]]></description><link>https://forum.iobroker.net/post/643076</link><guid isPermaLink="true">https://forum.iobroker.net/post/643076</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 15 Jun 2021 21:56:15 GMT</pubDate></item></channel></rss>
