<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nach Stromausfall kein zugriff mehr]]></title><description><![CDATA[<p dir="auto">Bei uns gab es ein Stromausfall und seid dem komme ich nicht mehr auf die Webseite von iobroker. Hier habe ich mal ein Log nachdem der Strom wieder da war.</p>
<pre><code>2021-04-20 11:18:44.194  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 11:18:44.198  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 11:18:44.199  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.18.3
2021-04-20 11:18:44.199  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fd7f:fb38:10f:2:4ad:97ff:fe83:42de fe80::4ad:97ff:fe83:42de
2021-04-20 11:18:44.233  - error: host.iobrokerlxc-Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
2021-04-20 11:18:44.235  - error: host.iobrokerlxc-Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: /opt/iobroker/iobroker-data/objects.json.bak: Unexpected end of JSON input. Continue with empty dataset!
2021-04-20 11:18:44.308  - error: host.iobrokerlxc Cannot read system.config: null (OK when migrating or restoring)
2021-04-20 11:18:44.316  - error: host.iobrokerlxc-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
2021-04-20 11:18:44.460  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 11:18:44.620  - warn: host.iobrokerlxc logger system.adapter.admin.0.logging was deleted
2021-04-20 11:18:44.621  - warn: host.iobrokerlxc logger system.adapter.javascript.0.logging was deleted
2021-04-20 11:18:44.632  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 11:18:44.639  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 11:18:44.640  - error: host.iobrokerlxc Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
2021-04-20 11:18:44.655  - info: host.iobrokerlxc Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
2021-04-20 11:18:44.705  - error: host.iobrokerlxc Cannot find view "system" for search "host"
2021-04-20 11:18:44.732  - error: host.iobrokerlxc Cannot find view "system" for search "state"
2021-04-20 11:18:44.732  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 11:18:44.734  - error: host.iobrokerlxc Could not collect system.host.iobrokerlxc states to check for obsolete states: Error: Cannot find view "system"
2021-04-20 11:18:44.736  - error: host.iobrokerlxc _design/system missing - call node iobroker.js setup
2021-04-20 11:18:44.864  - info: host.iobrokerlxc Created UUID: 864707f8-6738-7d71-516e-86bc37bcddfa
2021-04-20 11:31:50.273  - info: host.iobrokerlxc received SIGTERM
2021-04-20 11:31:50.339  - info: host.iobrokerlxc terminated
2021-04-20 11:32:03.033  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 11:32:03.038  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 11:32:03.039  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.18.3
2021-04-20 11:32:03.039  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fd7f:fb38:10f:2:4ad:97ff:fe83:42de fe80::4ad:97ff:fe83:42de
2021-04-20 11:32:03.141  - error: host.iobrokerlxc Cannot read system.config: null (OK when migrating or restoring)
2021-04-20 11:32:03.264  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 11:32:03.393  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 11:32:03.425  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 11:32:03.426  - error: host.iobrokerlxc Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
2021-04-20 11:32:03.443  - info: host.iobrokerlxc Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
2021-04-20 11:32:03.493  - error: host.iobrokerlxc Cannot find view "system" for search "host"
2021-04-20 11:32:03.523  - error: host.iobrokerlxc Cannot find view "system" for search "state"
2021-04-20 11:32:03.524  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 11:32:03.525  - error: host.iobrokerlxc Could not collect system.host.iobrokerlxc states to check for obsolete states: Error: Cannot find view "system"
2021-04-20 11:32:03.526  - error: host.iobrokerlxc _design/system missing - call node iobroker.js setup
2021-04-20 11:33:01.134  - info: host.iobrokerlxc received SIGTERM
2021-04-20 11:33:01.161  - info: host.iobrokerlxc terminated
2021-04-20 11:33:12.528  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 11:33:12.543  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 11:33:12.543  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.18.3
2021-04-20 11:33:12.544  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fe80::4ad:97ff:fe83:42de
2021-04-20 11:33:12.684  - error: host.iobrokerlxc Cannot read system.config: null (OK when migrating or restoring)
2021-04-20 11:33:12.816  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 11:33:12.944  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 11:33:12.978  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 11:33:12.979  - error: host.iobrokerlxc Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
2021-04-20 11:33:12.999  - info: host.iobrokerlxc Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
2021-04-20 11:33:13.051  - error: host.iobrokerlxc Cannot find view "system" for search "host"
2021-04-20 11:33:13.086  - error: host.iobrokerlxc Cannot find view "system" for search "state"
2021-04-20 11:33:13.087  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 11:33:13.089  - error: host.iobrokerlxc Could not collect system.host.iobrokerlxc states to check for obsolete states: Error: Cannot find view "system"
2021-04-20 11:33:13.091  - error: host.iobrokerlxc _design/system missing - call node iobroker.js setup
2021-04-20 11:37:57.023  - info: host.iobrokerlxc received SIGTERM
2021-04-20 11:37:57.071  - info: host.iobrokerlxc terminated
2021-04-20 11:47:12.649  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 11:47:12.654  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 11:47:12.654  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.18.3
2021-04-20 11:47:12.655  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fd7f:fb38:10f:2:4ad:97ff:fe83:42de fe80::4ad:97ff:fe83:42de
2021-04-20 11:47:12.757  - error: host.iobrokerlxc Cannot read system.config: null (OK when migrating or restoring)
2021-04-20 11:47:12.881  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 11:47:13.009  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 11:47:13.039  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 11:47:13.040  - error: host.iobrokerlxc Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
2021-04-20 11:47:13.057  - info: host.iobrokerlxc Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
2021-04-20 11:47:13.106  - error: host.iobrokerlxc Cannot find view "system" for search "host"
2021-04-20 11:47:13.140  - error: host.iobrokerlxc Cannot find view "system" for search "state"
2021-04-20 11:47:13.140  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 11:47:13.141  - error: host.iobrokerlxc Could not collect system.host.iobrokerlxc states to check for obsolete states: Error: Cannot find view "system"
2021-04-20 11:47:13.143  - error: host.iobrokerlxc _design/system missing - call node iobroker.js setup
2021-04-20 11:51:57.263  - info: host.iobrokerlxc received SIGTERM
2021-04-20 11:51:57.281  - info: host.iobrokerlxc terminated
2021-04-20 11:52:30.281  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 11:52:30.286  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 11:52:30.287  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.18.3
2021-04-20 11:52:30.287  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fd7f:fb38:10f:2:4ad:97ff:fe83:42de fe80::4ad:97ff:fe83:42de
2021-04-20 11:52:30.387  - error: host.iobrokerlxc Cannot read system.config: null (OK when migrating or restoring)
2021-04-20 11:52:30.515  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 11:52:30.644  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 11:52:30.677  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 11:52:30.678  - error: host.iobrokerlxc Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
2021-04-20 11:52:30.696  - info: host.iobrokerlxc Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
2021-04-20 11:52:30.745  - error: host.iobrokerlxc Cannot find view "system" for search "host"
2021-04-20 11:52:30.776  - error: host.iobrokerlxc Cannot find view "system" for search "state"
2021-04-20 11:52:30.776  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 11:52:30.777  - error: host.iobrokerlxc Could not collect system.host.iobrokerlxc states to check for obsolete states: Error: Cannot find view "system"
2021-04-20 11:52:30.779  - error: host.iobrokerlxc _design/system missing - call node iobroker.js setup
2021-04-20 11:57:57.767  - info: host.iobrokerlxc received SIGTERM
2021-04-20 11:57:57.907  - info: host.iobrokerlxc terminated
2021-04-20 12:00:14.897  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 12:00:14.902  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 12:00:14.903  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.18.3
2021-04-20 12:00:14.903  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fe80::4ad:97ff:fe83:42de
2021-04-20 12:00:15.067  - error: host.iobrokerlxc Cannot read system.config: null (OK when migrating or restoring)
2021-04-20 12:00:15.204  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 12:00:15.331  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 12:00:15.363  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 12:00:15.365  - error: host.iobrokerlxc Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
2021-04-20 12:00:15.426  - info: host.iobrokerlxc Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
2021-04-20 12:00:15.433  - error: host.iobrokerlxc Cannot find view "system" for search "host"
2021-04-20 12:00:15.468  - error: host.iobrokerlxc Cannot find view "system" for search "state"
2021-04-20 12:00:15.469  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 12:00:15.470  - error: host.iobrokerlxc Could not collect system.host.iobrokerlxc states to check for obsolete states: Error: Cannot find view "system"
2021-04-20 12:00:15.471  - error: host.iobrokerlxc _design/system missing - call node iobroker.js setup
2021-04-20 12:03:55.490  - info: host.iobrokerlxc received SIGTERM
2021-04-20 12:03:55.539  - info: host.iobrokerlxc terminated
2021-04-20 12:11:45.243  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 12:11:45.247  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 12:11:45.248  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.22.1
2021-04-20 12:11:45.249  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fd7f:fb38:10f:2:4ad:97ff:fe83:42de fe80::4ad:97ff:fe83:42de
2021-04-20 12:11:45.355  - error: host.iobrokerlxc Cannot read system.config: null (OK when migrating or restoring)
2021-04-20 12:11:45.488  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 12:11:45.615  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 12:11:45.649  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 12:11:45.650  - error: host.iobrokerlxc Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
2021-04-20 12:11:45.668  - info: host.iobrokerlxc Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
2021-04-20 12:11:45.719  - error: host.iobrokerlxc Cannot find view "system" for search "host"
2021-04-20 12:11:45.752  - error: host.iobrokerlxc Cannot find view "system" for search "state"
2021-04-20 12:11:45.753  - error: host.iobrokerlxc Cannot find view "system" for search "instance"
2021-04-20 12:11:45.754  - error: host.iobrokerlxc Could not collect system.host.iobrokerlxc states to check for obsolete states: Error: Cannot find view "system"
2021-04-20 12:11:45.755  - error: host.iobrokerlxc _design/system missing - call node iobroker.js setup
2021-04-20 12:13:52.713  - info: host.iobrokerlxc received SIGTERM
2021-04-20 12:13:52.734  - info: host.iobrokerlxc terminated
2021-04-20 12:13:54.619  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 12:13:54.625  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 12:13:54.625  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.22.1
2021-04-20 12:13:54.626  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fd7f:fb38:10f:2:4ad:97ff:fe83:42de fe80::4ad:97ff:fe83:42de
2021-04-20 12:13:54.863  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 12:13:54.995  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 12:13:55.373  - info: host.iobrokerlxc no instances found
2021-04-20 12:19:29.147  - info: host.iobrokerlxc received SIGTERM
2021-04-20 12:19:29.166  - info: host.iobrokerlxc terminated
2021-04-20 12:20:25.095  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 12:20:25.106  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 12:20:25.107  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.22.1
2021-04-20 12:20:25.107  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fd7f:fb38:10f:2:4ad:97ff:fe83:42de fe80::4ad:97ff:fe83:42de
2021-04-20 12:20:25.336  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 12:20:25.468  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 12:20:25.764  - info: host.iobrokerlxc no instances found
2021-04-20 12:25:13.564  - info: host.iobrokerlxc received SIGTERM
2021-04-20 12:25:13.586  - info: host.iobrokerlxc terminated
2021-04-20 12:25:15.480  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 12:25:15.486  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 12:25:15.486  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.22.1
2021-04-20 12:25:15.487  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fd7f:fb38:10f:2:4ad:97ff:fe83:42de fe80::4ad:97ff:fe83:42de
2021-04-20 12:25:15.723  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 12:25:15.855  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 12:25:16.154  - info: host.iobrokerlxc no instances found
2021-04-20 12:27:14.699  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 12:27:14.706  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 12:27:14.707  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.22.1
2021-04-20 12:27:14.708  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fd7f:fb38:10f:2:4ad:97ff:fe83:42de fe80::4ad:97ff:fe83:42de
2021-04-20 12:27:14.751  - info: host.iobrokerlxc-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 192.168.10.46:9001
2021-04-20 12:27:44.740  - error: host.iobrokerlxc No connection to databases possible, restart
2021-04-20 12:27:44.744  - info: host.iobrokerlxc iobroker _restart
2021-04-20 12:27:45.222  - info: host.iobrokerlxc iobroker Starting node restart.js
2021-04-20 12:27:50.100  - error: host.iobrokerlxc-Server Objects 192.168.10.100:54801 (Init=false) Redis error:Error: Invalid Chunk: parse failed
2021-04-20 12:27:50.106  - error: host.iobrokerlxc-Server Objects 192.168.10.100:54802 (Init=false) Redis error:Error: Invalid Chunk: parse failed
2021-04-20 12:27:50.109  - error: host.iobrokerlxc-Server Objects 192.168.10.100:54803 (Init=false) Redis error:Error: Invalid Chunk: parse failed
2021-04-20 12:27:51.145  - error: host.iobrokerlxc-Server Objects 192.168.10.100:54806 (Init=false) Redis error:Error: Invalid Chunk: parse failed
2021-04-20 12:27:51.148  - error: host.iobrokerlxc-Server Objects 192.168.10.100:54807 (Init=false) Redis error:Error: Invalid Chunk: parse failed
2021-04-20 12:27:51.150  - error: host.iobrokerlxc-Server Objects 192.168.10.100:54808 (Init=false) Redis error:Error: Invalid Chunk: parse failed
2021-04-20 12:33:25.027  - info: host.iobrokerlxc received SIGTERM
2021-04-20 12:33:25.056  - info: host.iobrokerlxc terminated
2021-04-20 12:33:26.916  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 12:33:26.921  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 12:33:26.922  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.22.1
2021-04-20 12:33:26.922  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fd7f:fb38:10f:2:4ad:97ff:fe83:42de fe80::4ad:97ff:fe83:42de
2021-04-20 12:33:27.154  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 12:33:27.282  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 12:33:27.576  - info: host.iobrokerlxc no instances found
2021-04-20 12:34:42.676  - info: host.iobrokerlxc received SIGTERM
2021-04-20 12:34:42.703  - info: host.iobrokerlxc terminated
2021-04-20 12:35:13.681  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 12:35:13.692  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 12:35:13.693  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.22.1
2021-04-20 12:35:13.693  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fe80::4ad:97ff:fe83:42de
2021-04-20 12:35:13.947  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 12:35:14.080  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 12:35:14.464  - info: host.iobrokerlxc no instances found
2021-04-20 13:33:41.303  - error: host.iobrokerlxc-Server Objects 192.168.10.100:55640 (Init=false) Redis error:Error: Invalid Chunk: parse failed
2021-04-20 13:33:41.311  - error: host.iobrokerlxc-Server Objects 192.168.10.100:55641 (Init=false) Redis error:Error: Invalid Chunk: parse failed
2021-04-20 13:33:41.314  - error: host.iobrokerlxc-Server Objects 192.168.10.100:55642 (Init=false) Redis error:Error: Invalid Chunk: parse failed
2021-04-20 13:37:11.302  - info: host.iobrokerlxc received SIGTERM
2021-04-20 13:37:11.332  - info: host.iobrokerlxc terminated
2021-04-20 13:37:13.166  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 13:37:13.171  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 13:37:13.171  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.22.1
2021-04-20 13:37:13.172  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fd7f:fb38:10f:2:4ad:97ff:fe83:42de fe80::4ad:97ff:fe83:42de
2021-04-20 13:37:13.397  - info: host.iobrokerlxc connected to Objects and States
2021-04-20 13:37:13.522  - info: host.iobrokerlxc added notifications configuration of host
2021-04-20 13:37:13.798  - info: host.iobrokerlxc no instances found
</code></pre>
<p dir="auto">Kann man da noch was retten?  Ich habe auch gerade gesehen das meine Backup Files alle nur  0 kb groß sind.</p>
<pre><code>root@iobrokerlxc:/opt/iobroker# iobroker status
Objects type: file
States  type: file
</code></pre>
<pre><code>root@iobrokerlxc:/opt/iobroker# iobroker info
Platform       : linux
os             : linux
Architecture   : x64
CPUs           : 4
Speed          : 2196 MHz
Model          : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
RAM            : 6 GB
System uptime  : 02:08:51
Node.js        : v12.22.1
Disk size      : 29.4 GiB
Disk free      : 23.5 GiB
NPM            : v6.14.12
</code></pre>
<pre><code>root@iobrokerlxc:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js --logs
2021-04-20 14:17:18.730  - info: host.iobrokerlxc iobroker.js-controller version 3.2.16 js-controller starting
2021-04-20 14:17:18.736  - info: host.iobrokerlxc Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2021-04-20 14:17:18.737  - info: host.iobrokerlxc hostname: iobrokerlxc, node: v12.22.1
2021-04-20 14:17:18.738  - info: host.iobrokerlxc ip addresses: 192.168.10.46 fd7f:fb38:10f:2:4ad:97ff:fe83:42de fe80::4ad:97ff:fe83:42de
2021-04-20 14:17:18.777  - info: host.iobrokerlxc-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 192.168.10.46:9001
2021-04-20 14:17:48.768  - error: host.iobrokerlxc No connection to databases possible, restart
2021-04-20 14:17:48.772  - info: host.iobrokerlxc iobroker _restart
2021-04-20 14:17:49.265  - info: host.iobrokerlxc iobroker Starting node restart.js
</code></pre>
<p dir="auto">Es wäre schön wenn mir jemand Helfen könnte iobroker wieder hin zubekommen.</p>
]]></description><link>https://forum.iobroker.net/topic/44369/nach-stromausfall-kein-zugriff-mehr</link><generator>RSS for Node</generator><lastBuildDate>Sat, 23 May 2026 12:20:48 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/44369.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Apr 2021 12:12:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Nach Stromausfall kein zugriff mehr on Tue, 20 Apr 2021 15:49:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a>  Vielen dank für den Link, das war die Rettung.</p>
]]></description><link>https://forum.iobroker.net/post/618122</link><guid isPermaLink="true">https://forum.iobroker.net/post/618122</guid><dc:creator><![CDATA[jack99n]]></dc:creator><pubDate>Tue, 20 Apr 2021 15:49:06 GMT</pubDate></item><item><title><![CDATA[Reply to Nach Stromausfall kein zugriff mehr on Tue, 20 Apr 2021 12:22:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jack99n" aria-label="Profile: jack99n">@<bdi>jack99n</bdi></a></p>
<p dir="auto">1.) Auch in einem Container hüpft man nicht als root durch das System.<br />
2.) Hört sich danach an.<br />
<a href="https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1618919490365">https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1618919490365</a></p>
]]></description><link>https://forum.iobroker.net/post/617997</link><guid isPermaLink="true">https://forum.iobroker.net/post/617997</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 20 Apr 2021 12:22:44 GMT</pubDate></item></channel></rss>
