<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TUYA Adapter bleibt gelb]]></title><description><![CDATA[<p dir="auto">Hallöchen, ich nutze seit langem den TUYA Adapter. Aktuell habe ich 3.5.6 installiert.<br />
Leider wird der Adapter nicht mehr. Grün. Ich habe den Adapter samt Objekten schon deinstalliert, leider ohne Erfolg.<br />
Das Log sieht so aus:</p>
<pre><code>tuya.0	2021-03-13 13:16:49.088	info	(4640) bf248fabbc07a96606wg3e: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:49.088	info	(4640) bfbf68d5d56d8cf0d8ri0j: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:49.087	info	(4640) 11622547bcddc28ede36: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:49.087	info	(4640) 88008560d8f15bd1d73c: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:49.086	info	(4640) bf0babf38073437b8exhto: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:49.085	info	(4640) bf9397e3c0910123cbc5vo: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:49.065	info	(4640) bfbf68d5d56d8cf0d8ri0j: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:49.063	info	(4640) 26504734ecfabc4b5445: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:49.062	info	(4640) 332670202462ab3b09cc: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:49.060	info	(4640) 53231408a4cf12cb0e66: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:49.059	info	(4640) 332670202462ab3b09cc: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:49.057	info	(4640) bf1db16bd4c7cc2132mbpx: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.931	info	(4640) bf3fc4ada92398abf39bay: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.930	info	(4640) bf9397e3c0910123cbc5vo: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.923	info	(4640) bf248fabbc07a96606wg3e: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.903	info	(4640) 53231408a4cf12cb0e66: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.815	info	(4640) bf93a9466706db6685mtff: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.796	info	(4640) bf3962297fe4816323cxzk: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.718	info	(4640) bf1db16bd4c7cc2132mbpx: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.717	info	(4640) bf3fc4ada92398abf39bay: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.717	info	(4640) 88008560d8f15bd1d73c: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.716	info	(4640) 11622547bcddc28ede36: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.715	info	(4640) bf93a9466706db6685mtff: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.656	info	(4640) 26504734ecfabc4b5445: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.655	info	(4640) bf3962297fe4816323cxzk: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.548	info	(4640) 348587205002916279b9: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.313	info	(4640) bf0babf38073437b8exhto: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:48.312	info	(4640) 348587205002916279b9: None of the discovered devices matches :-(
tuya.0	2021-03-13 13:16:47.126	warn	(4640) State "tuya.0.bf1db16bd4c7cc2132mbpx.online" has no existing object, this might lead to an error in future versions
tuya.0	2021-03-13 13:16:47.126	warn	(4640) State "tuya.0.bfbf68d5d56d8cf0d8ri0j.online" has no existing object, this might lead to an error in future versions
tuya.0	2021-03-13 13:16:47.122	warn	(4640) State "tuya.0.bf0babf38073437b8exhto.online" has no existing object, this might lead to an error in future versions
tuya.0	2021-03-13 13:16:47.121	warn	(4640) State "tuya.0.bf3fc4ada92398abf39bay.online" has no existing object, this might lead to an error in future versions
tuya.0	2021-03-13 13:16:33.910	error	at TCP.&lt;anonymous&gt; (net.js:675:12)
tuya.0	2021-03-13 13:16:33.910	error	at Socket.EventEmitter.emit (domain.js:483:12)
tuya.0	2021-03-13 13:16:33.910	error	at Socket.emit (events.js:314:20)
tuya.0	2021-03-13 13:16:33.910	error	at Object.onceWrapper (events.js:421:26)
tuya.0	2021-03-13 13:16:33.910	error	at Socket.done (_tls_wrap.js:568:7)
tuya.0	2021-03-13 13:16:33.910	error	at net.js:675:12
tuya.0	2021-03-13 13:16:33.910	error	at TLSSocket.EventEmitter.emit (domain.js:483:12)
tuya.0	2021-03-13 13:16:33.910	error	at TLSSocket.emit (events.js:326:22)
tuya.0	2021-03-13 13:16:33.910	error	at TLSSocket.onSocketClose (_tls_wrap.js:1063:23)
tuya.0	2021-03-13 13:16:33.910	error	at connResetException (internal/errors.js:609:14)
tuya.0	2021-03-13 13:16:33.910	error	(4640) Error: socket hang up
tuya.0	2021-03-13 13:16:33.891	error	(4640) SSL-Proxy ERROR: Error: socket hang up
tuya.0	2021-03-13 13:16:23.754	info	(4640) SSL-Proxy ready to receive requests
tuya.0	2021-03-13 13:16:18.206	info	(4640) Listen for encrypted local Tuya devices on port 6667
tuya.0	2021-03-13 13:16:18.196	info	(4640) Listen for local Tuya devices on port 6666
tuya.0	2021-03-13 13:16:18.189	info	(4640) Existing devices initialized
tuya.0	2021-03-13 13:16:18.112	info	(4640) starting. Version 3.5.6 in C:/iobroker/SmartHome/node_modules/iobroker.tuya, node: v12.20.2, js-controller: 3.2.16
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/43209/tuya-adapter-bleibt-gelb</link><generator>RSS for Node</generator><lastBuildDate>Fri, 22 May 2026 06:13:25 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/43209.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Mar 2021 12:23:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TUYA Adapter bleibt gelb on Sun, 14 Mar 2021 00:14:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michihorn" aria-label="Profile: michihorn">@<bdi>michihorn</bdi></a> Error: socket hang up<br />
Ist das plötzlich passiert? Nach einem Update? Was wurde upgedatet?<br />
Schon mal den Web-Adapter neu gestartet? Oder am besten ioBroker mit dem System komplett neu starten?</p>
]]></description><link>https://forum.iobroker.net/post/597938</link><guid isPermaLink="true">https://forum.iobroker.net/post/597938</guid><dc:creator><![CDATA[MCU]]></dc:creator><pubDate>Sun, 14 Mar 2021 00:14:41 GMT</pubDate></item></channel></rss>
