<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[(Error) ioBroker kurze Zeit nicht erreichbar]]></title><description><![CDATA[<p dir="auto">Hallo <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
<p dir="auto">dachte schon der Raspi4 wäre abgestürzt und wollte schon den Stecker ziehen, da ist ioBroker wieder gekommen. Per Telegram erhalte ich eine Info sollte ioBroker restarten bzw. gestartet werden, das kam nicht, dh nur ioBroker hatte ein Problem.<br />
hier das Log:</p>
<pre><code>2021-03-01 11:23:02.517 - warn: modbus.0 (809) Poll error count: 1 code: "App Timeout"
2021-03-01 11:23:03.004 - warn: modbus.0 (809) Error: undefined
2021-03-01 11:23:03.005 - error: modbus.0 (809) Request timed out.
2021-03-01 11:23:03.005 - error: modbus.0 (809) Client in error state.
2021-03-01 11:23:04.006 - info: modbus.0 (809) Disconnected from slave 192.168.0.9
2021-03-01 11:23:06.255 - warn: modbus.1 (828) Error: undefined
2021-03-01 11:23:06.256 - error: modbus.1 (828) Request timed out.
2021-03-01 11:23:06.256 - error: modbus.1 (828) Client in error state.
2021-03-01 11:23:06.258 - warn: modbus.1 (828) Poll error count: 1 code: {"err":"timeout","timeout":5000}
2021-03-01 11:23:07.256 - info: modbus.1 (828) Disconnected from slave 192.168.0.98
2021-03-01 11:23:12.748 - error: shelly.0 (776) Error in function state.coap.http_cmd for state SHPLG-S#EED8F9#1.Relay0.Switch and request{"url":"http://192.168.0.80/relay/0","timeout":5000,"qs":{"turn":"off","timer":0}} for 192.168.0.80 (shellyplug-s / shellyplug-s-EED8F9 / SHPLG-S#EED8F9#1) (Error: ETIMEDOUT)
2021-03-01 11:23:21.020 - info: mqtt.0 (607) Client [AMIS] connection closed: timeout
2021-03-01 11:23:21.111 - error: cloud.0 (669) Ping timeout
2021-03-01 11:23:21.112 - info: cloud.0 (669) Connection changed: Ping timeout
2021-03-01 11:23:21.112 - info: cloud.0 (669) Connection lost
2021-03-01 11:23:21.113 - info: cloud.0 (669) Restart adapter by disconnect
2021-03-01 11:23:31.116 - warn: cloud.0 (669) Terminated (-100): Without reason
2021-03-01 11:23:31.647 - info: cloud.0 (669) Connection changed: io client disconnect
2021-03-01 11:23:31.807 - info: host.raspi4iobrokerpv instance system.adapter.cloud.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2021-03-01 11:23:31.808 - info: host.raspi4iobrokerpv Restart adapter system.adapter.cloud.0 because enabled
2021-03-01 11:23:32.872 - info: host.raspi4iobrokerpv instance system.adapter.cloud.0 started with pid 7580
2021-03-01 11:23:34.623 - info: cloud.0 (7580) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.21.0, js-controller: 3.2.16
2021-03-01 11:23:34.697 - info: cloud.0 (7580) Connecting with https://iobroker.net:10555 with "richard.nussdorfer@gmail.com_65a2cba0-c435-11ea-b03c-2dda666d26a"
2021-03-01 11:23:34.851 - info: cloud.0 (7580) Trying to connect as system.user.admin
2021-03-01 11:23:40.353 - error: modbus.1 (828) Socket Error
2021-03-01 11:23:40.354 - error: modbus.1 (828) Client in error state.
2021-03-01 11:23:40.355 - warn: modbus.1 (828) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
2021-03-01 11:23:44.846 - error: cloud.0 (7580) Error while connecting to cloud: Error: websocket error
2021-03-01 11:24:07.153 - error: modbus.0 (809) Socket Error
2021-03-01 11:24:07.154 - error: modbus.0 (809) Client in error state.
2021-03-01 11:24:07.155 - warn: modbus.0 (809) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.9","port":502}
2021-03-01 11:24:14.511 - error: modbus.1 (828) Socket Error
2021-03-01 11:24:14.512 - error: modbus.1 (828) Client in error state.
2021-03-01 11:24:14.512 - warn: modbus.1 (828) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
2021-03-01 11:24:34.718 - info: cloud.0 (7580) Trying to connect as system.user.admin
2021-03-01 11:24:44.714 - error: cloud.0 (7580) Error while connecting to cloud: Error: websocket error
2021-03-01 11:24:44.997 - error: iot.0 (684) Error by device connection: "premature close"
2021-03-01 11:24:45.000 - info: iot.0 (684) Connection changed: disconnect
2021-03-01 11:24:45.001 - info: iot.0 (684) Connection lost
2021-03-01 11:24:48.671 - error: modbus.1 (828) Socket Error
2021-03-01 11:24:48.672 - error: modbus.1 (828) Client in error state.
2021-03-01 11:24:48.673 - warn: modbus.1 (828) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
2021-03-01 11:25:10.024 - error: iot.0 (684) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
2021-03-01 11:25:10.025 - error: iot.0 (684) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
2021-03-01 11:25:10.028 - error: iot.0 (684) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
2021-03-01 11:25:10.029 - error: iot.0 (684) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
2021-03-01 11:25:10.030 - info: iot.0 (684) Connection changed: disconnect
2021-03-01 11:25:11.311 - error: modbus.0 (809) Socket Error
2021-03-01 11:25:11.313 - error: modbus.0 (809) Client in error state.
2021-03-01 11:25:11.313 - warn: modbus.0 (809) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.9","port":502}
2021-03-01 11:25:20.049 - error: iot.0 (684) Error by device connection: "premature close"
2021-03-01 11:25:20.051 - info: iot.0 (684) Connection changed: disconnect
2021-03-01 11:25:20.080 - error: iot.0 (684) Error by device connection: "premature close"
2021-03-01 11:25:20.081 - warn: iot.0 (684) Looks like your connection certificates are invalid. Please renew them via configuration dialog.
2021-03-01 11:25:20.082 - info: iot.0 (684) Connection changed: disconnect
2021-03-01 11:25:22.831 - error: modbus.1 (828) Socket Error
2021-03-01 11:25:22.832 - error: modbus.1 (828) Client in error state.
2021-03-01 11:25:22.832 - warn: modbus.1 (828) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
2021-03-01 11:25:34.714 - info: cloud.0 (7580) Trying to connect as system.user.admin
2021-03-01 11:25:44.713 - error: cloud.0 (7580) Error while connecting to cloud: Error: websocket error
2021-03-01 11:25:50.094 - error: iot.0 (684) Error by device connection: "premature close"
2021-03-01 11:25:50.095 - info: iot.0 (684) Connection changed: disconnect
2021-03-01 11:25:56.991 - error: modbus.1 (828) Socket Error
2021-03-01 11:25:56.992 - error: modbus.1 (828) Client in error state.
2021-03-01 11:25:56.992 - warn: modbus.1 (828) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
2021-03-01 11:26:15.117 - error: iot.0 (684) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
2021-03-01 11:26:15.118 - error: iot.0 (684) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
2021-03-01 11:26:15.119 - error: iot.0 (684) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
2021-03-01 11:26:15.120 - error: iot.0 (684) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
2021-03-01 11:26:15.121 - info: iot.0 (684) Connection changed: disconnect
2021-03-01 11:26:15.471 - error: modbus.0 (809) Socket Error
2021-03-01 11:26:15.471 - error: modbus.0 (809) Client in error state.
2021-03-01 11:26:15.472 - warn: modbus.0 (809) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.9","port":502}
2021-03-01 11:26:25.132 - error: iot.0 (684) Error by device connection: "premature close"
2021-03-01 11:26:25.133 - info: iot.0 (684) Connection changed: disconnect
2021-03-01 11:26:25.202 - error: iot.0 (684) Error by device connection: "premature close"
2021-03-01 11:26:25.203 - warn: iot.0 (684) Looks like your connection certificates are invalid. Please renew them via configuration dialog.
2021-03-01 11:26:25.204 - info: iot.0 (684) Connection changed: disconnect
2021-03-01 11:26:31.152 - error: modbus.1 (828) Socket Error
2021-03-01 11:26:31.153 - error: modbus.1 (828) Client in error state.
2021-03-01 11:26:31.154 - warn: modbus.1 (828) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
2021-03-01 11:26:34.719 - info: cloud.0 (7580) Trying to connect as system.user.admin
2021-03-01 11:26:44.711 - error: cloud.0 (7580) Error while connecting to cloud: Error: websocket error
2021-03-01 11:26:55.214 - error: iot.0 (684) Error by device connection: "premature close"
2021-03-01 11:26:55.215 - info: iot.0 (684) Connection changed: disconnect
2021-03-01 11:26:57.733 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:26:58.034 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:26:58.334 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:26:58.635 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:26:58.936 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:26:59.237 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:26:59.537 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:26:59.837 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:00.137 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:00.220 - error: iot.0 (684) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
2021-03-01 11:27:00.221 - error: iot.0 (684) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
2021-03-01 11:27:00.222 - error: iot.0 (684) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
2021-03-01 11:27:00.223 - error: iot.0 (684) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
2021-03-01 11:27:00.224 - info: iot.0 (684) Connection changed: disconnect
2021-03-01 11:27:00.437 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:00.738 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:01.038 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:01.338 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:01.638 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:01.938 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:02.156 - error: modbus.1 (828) Socket Error
2021-03-01 11:27:02.157 - error: modbus.1 (828) Client in error state.
2021-03-01 11:27:02.157 - warn: modbus.1 (828) On error: {"errno":"ENETUNREACH","code":"ENETUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
2021-03-01 11:27:02.239 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:02.539 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:02.839 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:03.140 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:03.439 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:03.740 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:04.041 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:04.341 - warn: kecontact.0 (592) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
2021-03-01 11:27:08.655 - info: mqtt.0 (607) Client [H,] connected with secret 1614594428653_9692
2021-03-01 11:27:10.233 - error: iot.0 (684) Error by device connection: "premature close"
2021-03-01 11:27:10.233 - info: iot.0 (684) Connection changed: disconnect
2021-03-01 11:27:10.254 - error: iot.0 (684) Error by device connection: "premature close"
2021-03-01 11:27:10.256 - warn: iot.0 (684) Looks like your connection certificates are invalid. Please renew them via configuration dialog.
2021-03-01 11:27:10.257 - info: iot.0 (684) Connection changed: disconnect
2021-03-01 11:27:10.698 - info: iot.0 (684) Connection changed: connect
2021-03-01 11:27:16.496 - info: modbus.0 (809) Connected to slave 192.168.0.9
2021-03-01 11:27:33.164 - info: modbus.1 (828) Connected to slave 192.168.0.98
2021-03-01 11:27:34.710 - info: cloud.0 (7580) Trying to connect as system.user.admin
2021-03-01 11:27:35.080 - info: cloud.0 (7580) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
2021-03-01 11:27:35.082 - info: cloud.0 (7580) Connection changed: io client disconnect
2021-03-01 11:28:35.089 - info: cloud.0 (7580) Trying to connect as system.user.admin
2021-03-01 11:28:35.419 - info: cloud.0 (7580) Connection changed: connect
</code></pre>
<p dir="auto">danach läuft alles wie gehabt.</p>
<pre><code>Datenträger verfügbar: 76.7 %, gesamte RAM-Nutzung: 1142 MB / Frei: 63% = 1.177 MB [Host: raspi4iobrokerpv - 16 Prozesse]
</code></pre>
<p dir="auto">kann man das besser beobachten bzw. protokollieren, was bei einem verschlucker passiert? bzw. rausfinden wo der Hund begragen ist?</p>
<p dir="auto">raspi4iobrokerpv<br />
Platform<br />
linux<br />
Betriebssystem<br />
linux<br />
Architektur<br />
arm<br />
CPUs<br />
4<br />
Geschwindigkeit<br />
800 MHz<br />
Modell<br />
ARMv7 Processor rev 3 (v7l)<br />
RAM<br />
1.82 GB<br />
System Betriebszeit<br />
03:01:06<br />
Node.js<br />
v12.21.0<br />
NPM<br />
6.14.11<br />
Festplatte Größe<br />
14.05 GB<br />
Festplatte frei<br />
10.78 GB<br />
Anzahl der Adapter<br />
332<br />
Betriebszeit<br />
03:24:49<br />
Aktive Instanzen<br />
15<br />
Hostname<br />
raspi4iobrokerpv</p>
]]></description><link>https://forum.iobroker.net/topic/42793/error-iobroker-kurze-zeit-nicht-erreichbar</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 02:23:39 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/42793.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Mar 2021 10:33:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to (Error) ioBroker kurze Zeit nicht erreichbar on Thu, 04 Mar 2021 10:44:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/humidor" aria-label="Profile: humidor">@<bdi>humidor</bdi></a></p>
<p dir="auto">Zum "Speicherfehler" gibt es einen eigenen Thread. Das ist wenn du ein Blockly speichern willst, das aber nicht funktioniert und alle Änderungen rückgängig gemacht werden.</p>
]]></description><link>https://forum.iobroker.net/post/592053</link><guid isPermaLink="true">https://forum.iobroker.net/post/592053</guid><dc:creator><![CDATA[saeft_2003]]></dc:creator><pubDate>Thu, 04 Mar 2021 10:44:16 GMT</pubDate></item><item><title><![CDATA[Reply to (Error) ioBroker kurze Zeit nicht erreichbar on Thu, 04 Mar 2021 10:43:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saeft_2003" aria-label="Profile: saeft_2003">@<bdi>saeft_2003</bdi></a> bitte eigenen Thread aufmachen - das verwirrt hier.<br />
Ich lösche gleich die "sachfremden" Posts</p>
]]></description><link>https://forum.iobroker.net/post/592052</link><guid isPermaLink="true">https://forum.iobroker.net/post/592052</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Thu, 04 Mar 2021 10:43:11 GMT</pubDate></item><item><title><![CDATA[Reply to (Error) ioBroker kurze Zeit nicht erreichbar on Thu, 04 Mar 2021 10:41:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arteck" aria-label="Profile: arteck">@<bdi>arteck</bdi></a></p>
<p dir="auto">Ich nutze doch überhaupt kein WLAN... jetzt bin ich verwirrt. Du hast gesagt es liegt bei mir am Netwerkkartentreiber.</p>
]]></description><link>https://forum.iobroker.net/post/592051</link><guid isPermaLink="true">https://forum.iobroker.net/post/592051</guid><dc:creator><![CDATA[saeft_2003]]></dc:creator><pubDate>Thu, 04 Mar 2021 10:41:42 GMT</pubDate></item><item><title><![CDATA[Reply to (Error) ioBroker kurze Zeit nicht erreichbar on Thu, 04 Mar 2021 10:13:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/humidor" aria-label="Profile: humidor">@<bdi>humidor</bdi></a> sagte in <a href="/post/590159">(Error) ioBroker kurze Zeit nicht erreichbar</a>:</p>
<blockquote>
<p dir="auto">und wollte schon den Stecker ziehen</p>
</blockquote>
<p dir="auto">Steckerziehverbot!<br />
Abwarten hilft meist. Kann auch geraume Zeit dauern. Ist aber immer noch besser als die Kiste hart vom Strom zu nehmen.</p>
]]></description><link>https://forum.iobroker.net/post/592035</link><guid isPermaLink="true">https://forum.iobroker.net/post/592035</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 04 Mar 2021 10:13:36 GMT</pubDate></item><item><title><![CDATA[Reply to (Error) ioBroker kurze Zeit nicht erreichbar on Thu, 04 Mar 2021 09:53:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saeft_2003" aria-label="Profile: saeft_2003">@<bdi>saeft_2003</bdi></a> na ja WLAN ist nicht zu 100% stabiel was dein System aber erwartet.. ist die unterbrechung auch nur ganz kurz kommt das system durcheinandner</p>
]]></description><link>https://forum.iobroker.net/post/592017</link><guid isPermaLink="true">https://forum.iobroker.net/post/592017</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Thu, 04 Mar 2021 09:53:26 GMT</pubDate></item><item><title><![CDATA[Reply to (Error) ioBroker kurze Zeit nicht erreichbar on Thu, 04 Mar 2021 09:46:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saeft_2003" aria-label="Profile: saeft_2003">@<bdi>saeft_2003</bdi></a> was ist der Speicherfehler? hatte bis vor kurzem noch Fehler beim öffnen eines Blockly und manchmal ging auch gar nichts im Script zu verändern. Das hat sich aber von selbst behoben??</p>
]]></description><link>https://forum.iobroker.net/post/592010</link><guid isPermaLink="true">https://forum.iobroker.net/post/592010</guid><dc:creator><![CDATA[Humidor]]></dc:creator><pubDate>Thu, 04 Mar 2021 09:46:59 GMT</pubDate></item><item><title><![CDATA[Reply to (Error) ioBroker kurze Zeit nicht erreichbar on Thu, 04 Mar 2021 09:46:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arteck" aria-label="Profile: arteck">@<bdi>arteck</bdi></a></p>
<p dir="auto">OK krass… Ist das ein bekanntes Problem, weil du das aus der Ferne so sicher sagen kannst? Kannst du auch sagen ob das mit dem Speicherfehler in blockly was zu tun hat? Da würde ich einiges dafür geben um diesen los zu werden...</p>
]]></description><link>https://forum.iobroker.net/post/592009</link><guid isPermaLink="true">https://forum.iobroker.net/post/592009</guid><dc:creator><![CDATA[saeft_2003]]></dc:creator><pubDate>Thu, 04 Mar 2021 09:46:34 GMT</pubDate></item><item><title><![CDATA[Reply to (Error) ioBroker kurze Zeit nicht erreichbar on Thu, 04 Mar 2021 08:34:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saeft_2003" aria-label="Profile: saeft_2003">@<bdi>saeft_2003</bdi></a> du hast ein anderes problem.. der mit dem NUC Netzwerkkartetreiber liegt...</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/humidor" aria-label="Profile: Humidor">@<bdi>Humidor</bdi></a> dann hast du das Problem schon selbst erkannt.. WLAN..</p>
]]></description><link>https://forum.iobroker.net/post/591967</link><guid isPermaLink="true">https://forum.iobroker.net/post/591967</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Thu, 04 Mar 2021 08:34:18 GMT</pubDate></item><item><title><![CDATA[Reply to (Error) ioBroker kurze Zeit nicht erreichbar on Thu, 04 Mar 2021 08:21:36 GMT]]></title><description><![CDATA[<p dir="auto">das "Problem" kenne. Kommt bei mir aber nur sehr selten vor. Ich nutze einen NUC der am LAN hängt, deshalb vermute ich das es nicht an der Hardware liegt.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/humidor" aria-label="Profile: Humidor">@<bdi>Humidor</bdi></a> Hast du zufällig auch den blockly Speicherfehler?</p>
]]></description><link>https://forum.iobroker.net/post/591961</link><guid isPermaLink="true">https://forum.iobroker.net/post/591961</guid><dc:creator><![CDATA[saeft_2003]]></dc:creator><pubDate>Thu, 04 Mar 2021 08:21:36 GMT</pubDate></item><item><title><![CDATA[Reply to (Error) ioBroker kurze Zeit nicht erreichbar on Thu, 04 Mar 2021 08:02:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arteck" aria-label="Profile: arteck">@<bdi>arteck</bdi></a> WLan</p>
]]></description><link>https://forum.iobroker.net/post/591947</link><guid isPermaLink="true">https://forum.iobroker.net/post/591947</guid><dc:creator><![CDATA[Humidor]]></dc:creator><pubDate>Thu, 04 Mar 2021 08:02:26 GMT</pubDate></item><item><title><![CDATA[Reply to (Error) ioBroker kurze Zeit nicht erreichbar on Mon, 01 Mar 2021 11:25:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/humidor" aria-label="Profile: humidor">@<bdi>humidor</bdi></a> hängt der pi am lan oder wlan?</p>
]]></description><link>https://forum.iobroker.net/post/590184</link><guid isPermaLink="true">https://forum.iobroker.net/post/590184</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Mon, 01 Mar 2021 11:25:21 GMT</pubDate></item></channel></rss>
