<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wieso diese Warnung &quot;SKIPPING OPTIONAL DEPENDENCY:&quot;]]></title><description><![CDATA[<p dir="auto">Moin Community,</p>
<p dir="auto">gestern Abend habe ich den DWD Adapter deinstalliert und im Logfenster wurde ein paar Warnungen geloggt, wieso kommt es dazu und was hat der DWD-Adapter mit Zigbee zu tun? Ich wäre sehr dankbar wenn mir jemand den Zusammenhang erklären könnte.</p>
<pre><code>2021-01-17 23:19:43.011 - info: host.raspberrypi4-ioB iobroker npm
2021-01-17 23:19:43.013 - info: host.raspberrypi4-ioB iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.1 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
2021-01-17 23:19:43.047 - info: host.raspberrypi4-ioB iobroker npm
2021-01-17 23:19:43.049 - info: host.raspberrypi4-ioB iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
2021-01-17 23:19:43.075 - info: host.raspberrypi4-ioB iobroker npm
2021-01-17 23:19:43.077 - info: host.raspberrypi4-ioB iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
2021-01-17 23:19:43.113 - info: host.raspberrypi4-ioB iobroker npm
2021-01-17 23:19:43.115 - info: host.raspberrypi4-ioB iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
2021-01-17 23:19:43.141 - info: host.raspberrypi4-ioB iobroker npm
2021-01-17 23:19:43.144 - info: host.raspberrypi4-ioB iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
2021-01-17 23:19:43.177 - info: host.raspberrypi4-ioB iobroker npm
2021-01-17 23:19:43.179 - info: host.raspberrypi4-ioB iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
</code></pre>
<p dir="auto">Das ist der komplette Inhalt des Logs, der Adapter wurde deinstalliert und iobroker scheint problemlose zu laufen, ich kann nur nicht verstehen wieso es zu den Warnungen gekommen ist?</p>
<pre><code>2021-01-17 23:19:13.434 - info: host.raspberrypi4-ioB iobroker del dwd
2021-01-17 23:19:15.193 - info: host.raspberrypi4-ioB iobroker Delete adapter "dwd"
2021-01-17 23:19:15.206 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB Counted 1 instances of dwd
2021-01-17 23:19:15.213 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB Counted 1 meta of dwd
2021-01-17 23:19:15.218 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB Counted 1 adapter for dwd
2021-01-17 23:19:15.229 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB Counted 2 channels of dwd
2021-01-17 23:19:15.237 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB Counted 20 states of dwd
2021-01-17 23:19:15.244 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB Counted 15 states of system.adapter.dwd
2021-01-17 23:19:15.250 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB Counted 20 states (io.dwd.*) from states
2021-01-17 23:19:15.262 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB Counted 13 states (system.adapter.dwd.*) from states
2021-01-17 23:19:15.918 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB Counted 1 objects of dwd
2021-01-17 23:19:15.966 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB file vis/widgets/dwd deleted
2021-01-17 23:19:15.970 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB file vis/widgets/dwd.html deleted
2021-01-17 23:19:15.975 - warn: readDir will not read this directory () in future versions: dwd is not an object of type "meta"
2021-01-17 23:19:15.992 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB file dwd.admin deleted
2021-01-17 23:19:16.002 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB object dwd.admin deleted
2021-01-17 23:19:16.005 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB Deleting 41 object(s).
2021-01-17 23:19:17.000 - error: host.raspberrypi4-ioB Cannot write files: /opt/iobroker/iobroker-data/files/dwd.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/files/dwd.admin/_data.json'
2021-01-17 23:19:17.332 - info: host.raspberrypi4-ioB object deleted system.adapter.dwd.0
2021-01-17 23:19:17.334 - info: host.raspberrypi4-ioB stopInstance system.adapter.dwd.0 (force=false, process=false)
2021-01-17 23:19:17.335 - info: host.raspberrypi4-ioB stopInstance canceled schedule system.adapter.dwd.0
2021-01-17 23:19:17.386 - info: host.raspberrypi4-ioB iobroker host.raspberrypi4-ioB Deleting 33 state(s).
2021-01-17 23:19:17.514 - info: host.raspberrypi4-ioB iobroker npm uninstall iobroker.dwd --error --prefix "/opt/iobroker" (System call)
2021-01-17 23:20:04.152 - info: host.raspberrypi4-ioB iobroker exit 0
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/41086/wieso-diese-warnung-skipping-optional-dependency</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 05:09:51 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/41086.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Jan 2021 07:21:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wieso diese Warnung &quot;SKIPPING OPTIONAL DEPENDENCY:&quot; on Mon, 18 Jan 2021 08:27:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/unclesam" aria-label="Profile: unclesam">@<bdi>unclesam</bdi></a> Also doch ein Fehler von mir, dass kann so nicht bleiben. Der Mac Pro ist bestellt und sobald der da ist nutze ich das Teil nur für IoBroker <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f602.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--joy" style="height:23px;width:auto;vertical-align:middle" title=":joy:" alt="😂" /></p>
]]></description><link>https://forum.iobroker.net/post/560953</link><guid isPermaLink="true">https://forum.iobroker.net/post/560953</guid><dc:creator><![CDATA[Borio85]]></dc:creator><pubDate>Mon, 18 Jan 2021 08:27:31 GMT</pubDate></item><item><title><![CDATA[Reply to Wieso diese Warnung &quot;SKIPPING OPTIONAL DEPENDENCY:&quot; on Mon, 18 Jan 2021 08:09:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/borio85" aria-label="Profile: borio85">@<bdi>borio85</bdi></a> sagte in <a href="/post/560936">Wieso diese Warnung "SKIPPING OPTIONAL DEPENDENCY:"</a>:</p>
<blockquote>
<p dir="auto">erwartet Darwin findet aber Linux. Habe aber gedacht das ich das Problem sei bzw. das ich beim Aufsetzten irgendwo einen Fehler gemacht hätte</p>
</blockquote>
<p dir="auto">Ja, der Fehler war, dass du ein Linux und nicht einen Mac aufgesetzt hast <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f923.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--rolling_on_the_floor_laughing" style="height:23px;width:auto;vertical-align:middle" title=":rolling_on_the_floor_laughing:" alt="🤣" /><br />
"Darwin" ist der Codename von MacOS.</p>
]]></description><link>https://forum.iobroker.net/post/560941</link><guid isPermaLink="true">https://forum.iobroker.net/post/560941</guid><dc:creator><![CDATA[UncleSam]]></dc:creator><pubDate>Mon, 18 Jan 2021 08:09:03 GMT</pubDate></item><item><title><![CDATA[Reply to Wieso diese Warnung &quot;SKIPPING OPTIONAL DEPENDENCY:&quot; on Mon, 18 Jan 2021 07:54:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Vielen Dank, dann bin ich ja beruhigt.</p>
<p dir="auto">Ich habe mir schon sowas gedacht weil am Ende ja wanted und current steht, der iobroker erwartet Darwin findet aber Linux. Habe aber gedacht das ich das Problem sei bzw. das ich beim Aufsetzten irgendwo einen Fehler gemacht hätte :)</p>
]]></description><link>https://forum.iobroker.net/post/560936</link><guid isPermaLink="true">https://forum.iobroker.net/post/560936</guid><dc:creator><![CDATA[Borio85]]></dc:creator><pubDate>Mon, 18 Jan 2021 07:54:41 GMT</pubDate></item><item><title><![CDATA[Reply to Wieso diese Warnung &quot;SKIPPING OPTIONAL DEPENDENCY:&quot; on Mon, 18 Jan 2021 07:27:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/borio85" aria-label="Profile: borio85">@<bdi>borio85</bdi></a> Die Module sind nicht für dein System gedacht und werden daher übersprungen. Kein Grund zur Sorge</p>
]]></description><link>https://forum.iobroker.net/post/560918</link><guid isPermaLink="true">https://forum.iobroker.net/post/560918</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 18 Jan 2021 07:27:52 GMT</pubDate></item></channel></rss>
