<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problemen bei JS Upgrade]]></title><description><![CDATA[<p dir="auto">Hallo.<br />
Ich bin neu hier....<br />
kriege bei JS Aktualisierung diese fehlermeldung:</p>
<pre><code>pi@raspberrypiiob:/opt/iobroker $ sudo iobroker upgrade self
Update js-controller from @2.1.1 to @3.1.6
NPM version: 6.14.8
npm install iobroker.js-controller@3.1.6 --unsafe-perm --loglevel error --prefix                  "/opt/iobroker" (System call)
npm ERR! code ETIMEDOUT
npm ERR! errno ETIMEDOUT
npm ERR! network request to https://registry.npmjs.org/iobroker.js-controller failed, reason: connect ETIMEDOUT 104.16.16.35:443
npm ERR! network This is a problem related to network connectivity.
npm ERR! network In most cases you are behind a proxy or have bad network settings.
npm ERR! network
npm ERR! network If you are behind a proxy, please make sure that the
npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
npm ERR!     /home/iobroker/.npm/_logs/2020-12-19T10_45_24_149Z-debug.log
Starting node restart.js
</code></pre>
<p dir="auto"><strong>MOD-Edit: Code in code-tags gesetzt!</strong></p>
]]></description><link>https://forum.iobroker.net/topic/39846/problemen-bei-js-upgrade</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 15:26:11 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/39846.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 19 Dec 2020 11:05:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 16:51:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meine-musik-k24" aria-label="Profile: meine-Musik-K24">@<bdi>meine-Musik-K24</bdi></a><br />
Das mag ja sein mit den vier Ports, das Netzwerk muss dann aber auch sauber aufgesetzt werden.<br />
Na wenn es nun läuft...</p>
]]></description><link>https://forum.iobroker.net/post/540416</link><guid isPermaLink="true">https://forum.iobroker.net/post/540416</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 19 Dec 2020 16:51:13 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 16:33:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a><br />
ich habe mehrere Switch im Netzwerk . SPS ....Modbus...... PV Wechselrichter...und dann normale Netzwerkteilnehmer wie Fernseher.<br />
Da reichen  die 4 Lan Anschlüsse nicht aus.<br />
Wollte mich an alle bedanken für die schnelle Hilfe. Upgrade hat funktioniert<img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
]]></description><link>https://forum.iobroker.net/post/540405</link><guid isPermaLink="true">https://forum.iobroker.net/post/540405</guid><dc:creator><![CDATA[meine Musik K24]]></dc:creator><pubDate>Sat, 19 Dec 2020 16:33:34 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 16:49:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meine-musik-k24" aria-label="Profile: meine-Musik-K24">@<bdi>meine-Musik-K24</bdi></a><br />
Und warum liegen die anderen clients alle auf LAN3 der FritzBox? Läuft da noch sowas wie Powerlan oder ähnliches in deinem Netz?<br />
Irgendwie sieht das alles furchtbar verfummelt aus.</p>
]]></description><link>https://forum.iobroker.net/post/540383</link><guid isPermaLink="true">https://forum.iobroker.net/post/540383</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 19 Dec 2020 16:49:25 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 16:04:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a><br />
Nein leider nicht</p>
]]></description><link>https://forum.iobroker.net/post/540377</link><guid isPermaLink="true">https://forum.iobroker.net/post/540377</guid><dc:creator><![CDATA[meine Musik K24]]></dc:creator><pubDate>Sat, 19 Dec 2020 16:04:17 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 16:03:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meine-musik-k24" aria-label="Profile: meine-Musik-K24">@<bdi>meine-Musik-K24</bdi></a> sagte in <a href="/post/540373">Problemen bei JS Upgrade</a>:</p>
<blockquote>
der fundiert als ein WiFi Repeater</p>
</blockquote>
<p dir="auto">Danke. Den binde ich vorerst aus.</p>
]]></description><link>https://forum.iobroker.net/post/540375</link><guid isPermaLink="true">https://forum.iobroker.net/post/540375</guid><dc:creator><![CDATA[meine Musik K24]]></dc:creator><pubDate>Sat, 19 Dec 2020 16:03:11 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 16:02:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meine-musik-k24" aria-label="Profile: meine-Musik-K24">@<bdi>meine-Musik-K24</bdi></a><br />
Offenbar falsch eingestellt. Direkt an die FritzBox kommst du nicht mit deinen Geräten?</p>
]]></description><link>https://forum.iobroker.net/post/540374</link><guid isPermaLink="true">https://forum.iobroker.net/post/540374</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 19 Dec 2020 16:02:51 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 16:01:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a><br />
]]></description><link>https://forum.iobroker.net/post/540373</link><guid isPermaLink="true">https://forum.iobroker.net/post/540373</guid><dc:creator><![CDATA[meine Musik K24]]></dc:creator><pubDate>Sat, 19 Dec 2020 16:01:57 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 15:58:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meine-musik-k24" aria-label="Profile: meine-Musik-K24">@<bdi>meine-Musik-K24</bdi></a><br />
Der TL-WR702N / Tragbarer 150Mbit/s-WLAN-Nano-Router<br />
darf nicht als Router fungieren. Jedenfalls nicht so wie der jetzt vermutlich aufgesetzt ist. Der routet offenbar in 'Nichts'.</p>
<p dir="auto">Der muss als 'doofer' AP oder Switch eingestellt werden. Wenn das geht.</p>
]]></description><link>https://forum.iobroker.net/post/540369</link><guid isPermaLink="true">https://forum.iobroker.net/post/540369</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 19 Dec 2020 15:58:17 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 15:52:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a><br />
das habe ich so nicht gesehen...<br />
Das verstehe ich nicht. Sieht Bild.<img src="/assets/uploads/files/1608393149490-netz.jpg" alt="netz.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/540366</link><guid isPermaLink="true">https://forum.iobroker.net/post/540366</guid><dc:creator><![CDATA[meine Musik K24]]></dc:creator><pubDate>Sat, 19 Dec 2020 15:52:38 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 13:00:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zahnheinrich" aria-label="Profile: zahnheinrich">@<bdi>zahnheinrich</bdi></a><br />
Nein, auch das Gastnetz nimmt die Route über die IP mit der 1 am Ende. Aber halt aus einem zweiten SubNetz:  192.168.17<strong>9</strong>.1<br />
Siehe:</p>
<pre><code>tracert 104.16.16.35
Tracing route to 104.16.16.35 over a maximum of 30 hops
  1     1 ms     1 ms    &lt;1 ms  fritz.box [192.168.179.1]
  2     *        *        *     Request timed out.
  3    10 ms    18 ms     8 ms  81.210.136.104
  4    16 ms    17 ms    16 ms  de-fra04d-rc1-ae-44-0.aorta.net [84.116.196.37]
  5    17 ms    23 ms    16 ms  de-fra03b-ri1-ae-5-0.aorta.net [84.116.133.118]
  6    15 ms    15 ms    16 ms  213.46.179.138.aorta.net [213.46.179.138]
  7    15 ms     *       17 ms  if-ae-45-2.tcore1.fr0-frankfurt.as6453.net [195.219.50.20]
  8    17 ms    15 ms    17 ms  if-ae-6-2.thar1.f2c-frankfurt.as6453.net [195.219.50.174]
  9    16 ms    26 ms    19 ms  195.219.148.122
 10    16 ms    16 ms    14 ms  104.16.16.35
Trace complete.
</code></pre>
<p dir="auto">Da ist aus meiner Sicht irgendwas im Netz des TE zerfummelt worden.<br />
Da kann aber nur <a class="plugin-mentions-user plugin-mentions-a" href="/user/meine-musik-k24" aria-label="Profile: meine-Musik-K24">@<bdi>meine-Musik-K24</bdi></a> mit näheren Informationen helfen.</p>
]]></description><link>https://forum.iobroker.net/post/540245</link><guid isPermaLink="true">https://forum.iobroker.net/post/540245</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 19 Dec 2020 13:00:52 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 12:41:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a><br />
192.168.178....  Sollte das Gast WLAN sein</p>
]]></description><link>https://forum.iobroker.net/post/540238</link><guid isPermaLink="true">https://forum.iobroker.net/post/540238</guid><dc:creator><![CDATA[zahnheinrich]]></dc:creator><pubDate>Sat, 19 Dec 2020 12:41:50 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 12:35:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meine-musik-k24" aria-label="Profile: meine-Musik-K24">@<bdi>meine-Musik-K24</bdi></a><br />
Deine Fritzbox erreichst du über die IP 192.168.178.27 ?<br />
Das ist aber mehr als ungewöhnlich.<br />
Gewöhnlich liegt das gateway auf der 192.168.178.1<br />
Warum ändert man das?</p>
<p dir="auto">Normalerweise sieht das ungefähr so aus:</p>
<pre><code>pi@raspberrypi:~ $ traceroute 104.16.16.35
traceroute to 104.16.16.35 (104.16.16.35), 30 hops max, 60 byte packets
 1  fritz.box (192.168.178.1)  0.259 ms  0.197 ms  0.152 ms
 2  * * *
 3  81.210.136.104 (81.210.136.104)  14.139 ms  14.002 ms  13.930 ms
</code></pre>
]]></description><link>https://forum.iobroker.net/post/540232</link><guid isPermaLink="true">https://forum.iobroker.net/post/540232</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 19 Dec 2020 12:35:21 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 12:29:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> ```</p>
<pre><code>pi@raspberrypiiob:~ $ traceroute 104.16.16.35
 1  192.168.178.27 (192.168.178.27)  0.182 ms  0.096 ms  0.092 ms
 2  * * *
 3  * * *
 4  * * *
 5  * * *
 6  * * *
 7  * * *
 8  * * *
 9  * * *
10  * * *
11  * * *
12  * * *
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
</code></pre>
]]></description><link>https://forum.iobroker.net/post/540229</link><guid isPermaLink="true">https://forum.iobroker.net/post/540229</guid><dc:creator><![CDATA[meine Musik K24]]></dc:creator><pubDate>Sat, 19 Dec 2020 12:29:25 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 11:31:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meine-musik-k24" aria-label="Profile: meine-Musik-K24">@<bdi>meine-Musik-K24</bdi></a> Dann hast du wohl ein Problem in deinem Netzwerk.<br />
Oder das Routing klemmt irgendwo. Schau mal mit</p>
<pre><code>traceroute 104.16.16.35
</code></pre>
<p dir="auto">danach.</p>
]]></description><link>https://forum.iobroker.net/post/540201</link><guid isPermaLink="true">https://forum.iobroker.net/post/540201</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 19 Dec 2020 11:31:56 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 11:31:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meine-musik-k24" aria-label="Profile: meine-Musik-K24">@<bdi>meine-Musik-K24</bdi></a> sagte in <a href="/post/540198">Problemen bei JS Upgrade</a>:</p>
<blockquote>
Nein kommt nix zurück.</p>
</blockquote>
<p dir="auto">beim Fritz box ist auf unbeschränkt eingestellt.</p>
]]></description><link>https://forum.iobroker.net/post/540199</link><guid isPermaLink="true">https://forum.iobroker.net/post/540199</guid><dc:creator><![CDATA[meine Musik K24]]></dc:creator><pubDate>Sat, 19 Dec 2020 11:31:30 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 11:29:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a><br />
]]></description><link>https://forum.iobroker.net/post/540198</link><guid isPermaLink="true">https://forum.iobroker.net/post/540198</guid><dc:creator><![CDATA[meine Musik K24]]></dc:creator><pubDate>Sat, 19 Dec 2020 11:29:59 GMT</pubDate></item><item><title><![CDATA[Reply to Problemen bei JS Upgrade on Sat, 19 Dec 2020 11:08:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meine-musik-k24" aria-label="Profile: meine-Musik-K24">@<bdi>meine-Musik-K24</bdi></a> sagte in <a href="/post/540177">Problemen bei JS Upgrade</a>:<br />
Die IP 104.16.16.35 kann nicht erreicht werden.<br />
Kannst du die anpingen?<br />
Hier geht es:</p>
<pre><code>pi@raspberrypi:~ $ ping 104.16.16.35
PING 104.16.16.35 (104.16.16.35) 56(84) bytes of data.
64 bytes from 104.16.16.35: icmp_seq=1 ttl=56 time=23.7 ms
64 bytes from 104.16.16.35: icmp_seq=2 ttl=56 time=14.6 ms
64 bytes from 104.16.16.35: icmp_seq=3 ttl=56 time=12.9 ms
64 bytes from 104.16.16.35: icmp_seq=4 ttl=56 time=14.1 ms
^C
--- 104.16.16.35 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 9ms
rtt min/avg/max/mdev = 12.922/16.344/23.710/4.299 ms
</code></pre>
<p dir="auto">Bitte Konsolenausgaben als Text in CodeTags setzen. Wie bei mir.</p>
]]></description><link>https://forum.iobroker.net/post/540178</link><guid isPermaLink="true">https://forum.iobroker.net/post/540178</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 19 Dec 2020 11:08:12 GMT</pubDate></item></channel></rss>
