<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Alexa-Adapter macht seit heute Probleme]]></title><description><![CDATA[<p dir="auto">Es funktionieren nichts mehr was über den Adapter gesteuert werden soll. So sieht der Log aus:</p>
<pre><code>alexa2.0	2020-12-04 17:23:40.487	error	(2411148) The "Echo-Devices.4ef3eac568084e87b685217aad18f590.Music-Provider." is invalid. Ids are not allowed to end in "." at Adapter.setObject (/opt/iobroker/node_modules/iobroker.js-controller/
alexa2.0	2020-12-04 17:23:28.881	error	at processImmediate (internal/timers.js:461:21)
alexa2.0	2020-12-04 17:23:28.881	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2354:71)
alexa2.0	2020-12-04 17:23:28.881	error	at /opt/iobroker/node_modules/iobroker.alexa2/main.js:352:25
alexa2.0	2020-12-04 17:23:28.881	error	at Adapter.setObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1817:40)
alexa2.0	2020-12-04 17:23:28.881	error	(2411148) The "Echo-Devices.G090LF0964830QFN.Music-Provider." is invalid. Ids are not allowed to end in "."
alexa2.0	2020-12-04 17:23:28.056	info	(2411148) Alexa-Push-Connection established. Disable Polling
alexa2.0	2020-12-04 17:23:22.475	info	(2411148) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v12.19.1, js-controller: 3.1.6
alexa2.0	2020-12-04 17:23:28.881	error	(2411148) The "Echo-Devices.G090LF0964830QFN.Music-Provider." is invalid. Ids are not allowed to end in "." at Adapter.setObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1
</code></pre>
<p dir="auto">Installiert ist die Version 3.3.1, Node.js v12.19.1.<br />
Ich habe bereits iobroker neu gestartet, vorher den fixer laufen lassen und auch den Objekt Ordner gelöscht. Hat nix genutzt.<br />
Hat jemand eine Idee was ich da noch machen könnte?</p>
]]></description><link>https://forum.iobroker.net/topic/39349/alexa-adapter-macht-seit-heute-probleme</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 21:10:42 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/39349.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Dec 2020 16:36:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Alexa-Adapter macht seit heute Probleme on Fri, 04 Dec 2020 16:58:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/winni" aria-label="Profile: Winni">@<bdi>Winni</bdi></a></p>
<p dir="auto">Dazu gibt es die PN.<br />
Immer raus damit.</p>
]]></description><link>https://forum.iobroker.net/post/531478</link><guid isPermaLink="true">https://forum.iobroker.net/post/531478</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Fri, 04 Dec 2020 16:58:47 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa-Adapter macht seit heute Probleme on Fri, 04 Dec 2020 16:57:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/haselchen" aria-label="Profile: haselchen">@<bdi>haselchen</bdi></a> ja, wenn man die passenden Suchbegriffe eingibt. Aber egal, mit der 3.3.5 gehts wieder und noch ein Tipp an dich, man muss nicht auf jeden Post antworten und es gibt Leute die können Oberlehrer auf den Tod nicht ausstehen. Für mich ist das Thema erledigt, würde ich jetzt noch alles schreiben was ich mir denke, wäre das wirklich dem Foren-Klima sehr abträglich.</p>
]]></description><link>https://forum.iobroker.net/post/531476</link><guid isPermaLink="true">https://forum.iobroker.net/post/531476</guid><dc:creator><![CDATA[Winni]]></dc:creator><pubDate>Fri, 04 Dec 2020 16:57:42 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa-Adapter macht seit heute Probleme on Fri, 04 Dec 2020 16:48:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/winni" aria-label="Profile: Winni">@<bdi>Winni</bdi></a></p>
<p dir="auto">Die Antwort ist aber gerechtfertigt.<br />
Den 1.Thread bekommst du sogar schon auf der 1. Seite.<br />
Wenns ums Klima geht, dann eher wegen xfacher Doppelthreads.</p>
]]></description><link>https://forum.iobroker.net/post/531471</link><guid isPermaLink="true">https://forum.iobroker.net/post/531471</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Fri, 04 Dec 2020 16:48:17 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa-Adapter macht seit heute Probleme on Fri, 04 Dec 2020 16:40:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/haselchen" aria-label="Profile: haselchen">@<bdi>haselchen</bdi></a> nun, sehr hilfreich ist die Antwort nicht. Solche Antworten tragen nicht zu einem guten Forenklima bei und nur der Vollständigkeit halber, natürlich habe ich die Suche benutzt, nur nicht extra im Post erwähnt.</p>
]]></description><link>https://forum.iobroker.net/post/531465</link><guid isPermaLink="true">https://forum.iobroker.net/post/531465</guid><dc:creator><![CDATA[Winni]]></dc:creator><pubDate>Fri, 04 Dec 2020 16:40:31 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa-Adapter macht seit heute Probleme on Fri, 04 Dec 2020 16:37:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/winni" aria-label="Profile: Winni">@<bdi>Winni</bdi></a></p>
<p dir="auto">Ich habe sogar 1000 Ideen.<br />
Eine davon ist die Forensuche.<br />
Sorry, aber da musste durch.</p>
<p dir="auto">Gibt gefühlt 100 Threads zu dem Thema.</p>
]]></description><link>https://forum.iobroker.net/post/531462</link><guid isPermaLink="true">https://forum.iobroker.net/post/531462</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Fri, 04 Dec 2020 16:37:35 GMT</pubDate></item></channel></rss>
