<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[EMS-ESP MQTT Verbindung]]></title><description><![CDATA[<p dir="auto">Hallo Freunde,<br />
ich habe eine EMS-ESP interface vom BBQ Kees am laufen. Ich kann in der Interface die Werte sehen aber schaffe den MQTT-Client mit dem Iobroker MQTT-Server zu verbinden.<br />
Meine Einstellungen im EMS -ESP sind:</p>
<p dir="auto">"MQTT": {<br />
"enabled": "on",<br />
"host": "192.168.0.22",<br />
"port": 1886,<br />
"username": "mqttuser",<br />
"client_id": "ems-esp",<br />
"keep_alive": 60,<br />
"clean_session": "off",<br />
"max_topic_length": 128,<br />
"publish_time_boiler": 10,<br />
"publish_time_thermostat": 10,<br />
"publish_time_solar": 10,<br />
"publish_time_mixer": 10,<br />
"publish_time_other": 10,<br />
"publish_time_sensor": 10,<br />
"mqtt_format": 3,<br />
"mqtt_qos": 1,<br />
"mqtt_retain": "on"<br />
},</p>
]]></description><link>https://forum.iobroker.net/topic/38598/ems-esp-mqtt-verbindung</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 23:48:17 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/38598.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Nov 2020 22:12:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to EMS-ESP MQTT Verbindung on Fri, 13 Nov 2020 05:33:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geo-ioan" aria-label="Profile: geo-ioan">@<bdi>geo-ioan</bdi></a> Hi,<br />
was hast du denn beim mqtt Adapter bei Verbindung eingestellt?</p>
<p dir="auto">Hast du vielleicht noch was auf Port 1886 laufen? Sonoff-Adapter?</p>
]]></description><link>https://forum.iobroker.net/post/520243</link><guid isPermaLink="true">https://forum.iobroker.net/post/520243</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 13 Nov 2020 05:33:56 GMT</pubDate></item><item><title><![CDATA[Reply to EMS-ESP MQTT Verbindung on Thu, 12 Nov 2020 22:15:45 GMT]]></title><description><![CDATA[<p dir="auto">Fehler lautet : TCP Disconnected</p>
]]></description><link>https://forum.iobroker.net/post/520211</link><guid isPermaLink="true">https://forum.iobroker.net/post/520211</guid><dc:creator><![CDATA[geo-ioan]]></dc:creator><pubDate>Thu, 12 Nov 2020 22:15:45 GMT</pubDate></item><item><title><![CDATA[Reply to EMS-ESP MQTT Verbindung on Thu, 12 Nov 2020 22:14:38 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1605219268221-3ca7d254-0074-4e39-9239-b13fd287ea15-image.png" alt="3ca7d254-0074-4e39-9239-b13fd287ea15-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/520210</link><guid isPermaLink="true">https://forum.iobroker.net/post/520210</guid><dc:creator><![CDATA[geo-ioan]]></dc:creator><pubDate>Thu, 12 Nov 2020 22:14:38 GMT</pubDate></item></channel></rss>
