<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Gelöst: RING Adapter Fehlermeldung]]></title><description><![CDATA[<p dir="auto">Hallo habe seit langen die aktuellste Version vom RING-Adapter laufen.<br />
Seit kurzem will er nicht mehr.<br />
Anbei die Einträge aus dem LOG:</p>
<pre><code>ring.0	2020-10-27 14:55:10.712	error	(1908) Error: Could not get devices in getAllRingsDevices(). Error: Could not get all doorbell devices in getAllRingsDeviceObjects(). Error: Could not get device instance in method getDevices(). Error
ring.0	2020-10-27 14:54:56.866	debug	(1908) system.adapter.admin.0: logging true
ring.0	2020-10-27 14:54:55.549	error	(1908) Error: Could not get devices in getAllRingsDevices(). Error: Could not get all doorbell devices in getAllRingsDeviceObjects(). Error: Could not get device instance in method getDevices(). Erro
ring.0	2020-10-27 14:54:55.225	info	(1908) Starting Adapter ring.0 in version 1.1.4
ring.0	2020-10-27 14:54:55.219	info	(1908) starting. Version 1.1.4 in C:/iobroker/SmartHome/node_modules/iobroker.ring, node: v12.18.4, js-controller: 3.1.6
ring.0	2020-10-27 14:54:55.142	debug	(1908) Plugin sentry Initialize Plugin (enabled=true)
ring.0	2020-10-27 14:54:54.763	debug	(1908) statesDB connected
ring.0	2020-10-27 14:54:54.762	debug	(1908) States connected to redis: 127.0.0.1:9000
ring.0	2020-10-27 14:54:54.749	debug	(1908) States create System PubSub Client
ring.0	2020-10-27 14:54:54.748	debug	(1908) States create User PubSub Client
ring.0	2020-10-27 14:54:54.740	debug	(1908) Redis States: Use Redis connection: 127.0.0.1:9000
ring.0	2020-10-27 14:54:54.739	debug	(1908) objectDB connected
ring.0	2020-10-27 14:54:54.736	debug	(1908) Objects connected to redis: 127.0.0.1:9001
ring.0	2020-10-27 14:54:54.721	debug	(1908) Objects client initialize lua scripts
ring.0	2020-10-27 14:54:54.721	debug	(1908) Objects create User PubSub Client
ring.0	2020-10-27 14:54:54.720	debug	(1908) Objects create System PubSub Client
ring.0	2020-10-27 14:54:54.719	debug	(1908) Objects client ready ... initialize now
ring.0	2020-10-27 14:54:54.704	debug	(1908) Redis Objects: Use Redis connection: 127.0.0.1:9001
ring.0	2020-10-27 14:54:51.027	info	(6008) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
ring.0	2020-10-27 14:54:51.027	info	(6008) terminating
ring.0	2020-10-27 14:54:51.027	info	(6008) Closing Adapter
ring.0	2020-10-27 14:54:51.026	info	(6008) Got terminate signal TERMINATE_YOURSELF
ring.0	2020-10-27 14:54:45.763	error	(6008) Error: Could not get devices in getAllRingsDevices(). Error: Could not get all doorbell devices in getAllRingsDeviceObjects(). Error: Could not get device instance in method getDevices(). Erro
ring.0	2020-10-27 14:53:45.209	error	(6008) Error: Could not get devices in getAllRingsDevices(). Error: Could not get all doorbell devices in getAllRingsDeviceObjects(). Error: Could not get device instance in method getDevices(). Erro
ring.0	2020-10-27 14:52:44.938	error	(6008) Error: Could not get devices in getAllRingsDevices(). Error: Could not get all doorbell devices in getAllRingsDeviceObjects(). Error: Could not get device instance in method getDevices(). Erro
</code></pre>
<p dir="auto">Hat jemand einen Tip für mich?<br />
Michael</p>
<p dir="auto">EDIT: Die TWO WAY AUTH war strubbelig. Man kann die erneuen, indem man in der Konsole folgendes eingibt:<br />
npx -p ring-client-api ring-auth-cli.<br />
Gruß Michael</p>
]]></description><link>https://forum.iobroker.net/topic/38036/gelöst-ring-adapter-fehlermeldung</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 01:16:19 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/38036.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Oct 2020 14:00:35 GMT</pubDate><ttl>60</ttl></channel></rss>
