<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[nach iobroker-update verliert instanz verbindung]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
nachdem ich meinen iobroker geupdatet hab, verliert meine Ecovacs-instanz immer die Verbindung, er stellt die Verbindung her, verliert sie aber nach 3-4 Sekunden wieder.<br />
Vll ist ja jemandem diese Problem bekannt und kann mir helfen?!</p>
<pre><code>2020-09-14 22:10:55.479 - error: ecovacs-deebot.0 (12728) uncaught exception: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 64. This version of Node.js requires
NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
2020-09-14 22:10:55.480 - error: ecovacs-deebot.0 (12728) Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
at Object.Module._extensions..node (internal/modules/cjs/loader.js:1187:18)
at Module.load (internal/modules/cjs/loader.js:985:32)
at Function.Module._load (internal/modules/cjs/loader.js:878:14)
at Module.require (internal/modules/cjs/loader.js:1025:19)
at require (internal/modules/cjs/helpers.js:72:18)
at Object. (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
at Module._compile (internal/modules/cjs/loader.js:1137:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
2020-09-14 22:10:55.483 - info: ecovacs-deebot.0 (12728) cleaned everything up...
</code></pre>
<p dir="auto">Danke schon mal für die Hilfe.</p>
]]></description><link>https://forum.iobroker.net/topic/36810/nach-iobroker-update-verliert-instanz-verbindung</link><generator>RSS for Node</generator><lastBuildDate>Sat, 12 Sep 2026 22:24:36 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/36810.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Sep 2020 20:13:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Sun, 03 Jan 2021 10:37:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stefanmc" aria-label="Profile: StefanMc">@<bdi>StefanMc</bdi></a><br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a></p>
<p dir="auto">wovon redet ihr?<br />
Thomas redet von sudo:<br />
<a href="https://forum.iobroker.net/topic/17109/wichtige-hinweise-bei-neueren-npm-versionen-und-sudo">https://forum.iobroker.net/topic/17109/wichtige-hinweise-bei-neueren-npm-versionen-und-sudo</a></p>
]]></description><link>https://forum.iobroker.net/post/549912</link><guid isPermaLink="true">https://forum.iobroker.net/post/549912</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 03 Jan 2021 10:37:25 GMT</pubDate></item><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Sun, 03 Jan 2021 10:35:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a><br />
Hallo Thomas,<br />
nein, eben nicht, ich habe mir den Beitrag genau durchgelesen und es probiert, jedoch ohne Erfolg, deswegen auch mein Post.</p>
]]></description><link>https://forum.iobroker.net/post/549909</link><guid isPermaLink="true">https://forum.iobroker.net/post/549909</guid><dc:creator><![CDATA[StefanMc]]></dc:creator><pubDate>Sun, 03 Jan 2021 10:35:11 GMT</pubDate></item><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Sun, 03 Jan 2021 10:37:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stefanmc" aria-label="Profile: StefanMc">@<bdi>StefanMc</bdi></a> Auch hier leitet man npm nicht per sudo ein.</p>
<p dir="auto">Ein</p>
<pre><code>npm rebuild canvas
</code></pre>
<p dir="auto">im entsprechenden Ordner hätte es auch getan.</p>
<p dir="auto">Lass den Fixer jetzt nochmal auf das System los:</p>
<pre><code>iobroker stop
iobroker fix
</code></pre>
]]></description><link>https://forum.iobroker.net/post/549864</link><guid isPermaLink="true">https://forum.iobroker.net/post/549864</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 03 Jan 2021 10:37:15 GMT</pubDate></item><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Sun, 03 Jan 2021 10:00:21 GMT]]></title><description><![CDATA[<p dir="auto">falls mal wer das selbe Problem hat:</p>
<p dir="auto">Nach Systemupdate auf:</p>
<pre><code>Plattform: linux
Betriebssystem: linux
Die Architektur: x64
CPUs: 4
Geschwindigkeit: 639 MHz
Modell: Intel(R) Atom(TM) x5-Z8350 CPU @ 1.44GHz
RAM: 3.7 GB
System-Betriebszeit: 00:23:08
Node.js: v12.20.0
Datenträgergröße: 52.7 GiB
Datenträger verfügbar: 45.0 GiB
Adapter-Anzahl: 322
NPM: v6.14.10
Betriebszeit: 00:11:01
Aktive Instanzen: 15
</code></pre>
<p dir="auto">bekam ich folgende Fehlermeldung:</p>
<p dir="auto">ecovacs-deebot.0	2021-01-02 20:35:51.518	error	(27734) uncaught exception: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 64. This version of Node.js requires NODE_MODULE_VERSION 72. Please try re-compiling or re-installing the module (for instance, using <code>npm rebuild</code> or <code>npm install</code>).</p>
<p dir="auto">Lösung:</p>
<p dir="auto">sudo npm uninstall canvas<br />
sudo npm install canvas --unsafe-perm=true</p>
]]></description><link>https://forum.iobroker.net/post/549859</link><guid isPermaLink="true">https://forum.iobroker.net/post/549859</guid><dc:creator><![CDATA[StefanMc]]></dc:creator><pubDate>Sun, 03 Jan 2021 10:00:21 GMT</pubDate></item><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Tue, 15 Sep 2020 18:56:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1983" aria-label="Profile: Chris1983">@<bdi>Chris1983</bdi></a><br />
npm wird (wenn im Verzeichnis /opt/iobroker ausgeführt) ohnehin im richtigen User-Kontext ausgeführt. Das ist für den Befehl so definiert worden.</p>
]]></description><link>https://forum.iobroker.net/post/489339</link><guid isPermaLink="true">https://forum.iobroker.net/post/489339</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 15 Sep 2020 18:56:12 GMT</pubDate></item><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Tue, 15 Sep 2020 18:14:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> Ok, ich bin leider nicht so der Iobroker Profi, bin noch recht neu bei der Sache und stelle hier wahrscheinlich die "Was ist ein Abseits"-Frage, aber warum nicht mit sudo? Lese das sehr häufig bei Befehlen.</p>
]]></description><link>https://forum.iobroker.net/post/489326</link><guid isPermaLink="true">https://forum.iobroker.net/post/489326</guid><dc:creator><![CDATA[Chris1983]]></dc:creator><pubDate>Tue, 15 Sep 2020 18:14:26 GMT</pubDate></item><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Tue, 15 Sep 2020 18:06:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1983" aria-label="Profile: Chris1983">@<bdi>Chris1983</bdi></a><br />
Dann wirf noch ein</p>
<pre><code>iobroker fix
</code></pre>
<p dir="auto">hinterher, npm sollte man nicht per sudo einleiten.<br />
(Auch wenn ich das in dem besagten Thread vielleicht so geschrieben habe).</p>
]]></description><link>https://forum.iobroker.net/post/489322</link><guid isPermaLink="true">https://forum.iobroker.net/post/489322</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 15 Sep 2020 18:06:13 GMT</pubDate></item><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Tue, 15 Sep 2020 18:01:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> An diese Stelle: VIELEN DANK!!!</p>
<p dir="auto">Das mit dem "cd /opt/iobroker/node_modules<br />
npm rebuild canvas" hat mich auf die richtige Spur gebracht. Deine hier vorgeschlagene lösung hat anfangs nicht funktioniert, bin aber auf einen älteren topic (<a href="https://forum.iobroker.net/topic/34945/too-many-symbolic-links-encountered-access-canvas/7">https://forum.iobroker.net/topic/34945/too-many-symbolic-links-encountered-access-canvas/7</a>) gestoßen bei dem Du auch schon in die richtung gegangen bist. Habe dann noch den Tipp des Hilfesuchenden genutzt und auf der Pi selbst canvas gelöscht, danach</p>
<p dir="auto">/opt/iobroker/node_modules sudo npm rebuild canvas</p>
<p dir="auto">ausgeführt und da hat es funktioniert. Instanzen wieder installiert und alles läuft wieder.</p>
<p dir="auto">Also nochmals: Vielen Dank für die schnelle Hilfe!</p>
]]></description><link>https://forum.iobroker.net/post/489316</link><guid isPermaLink="true">https://forum.iobroker.net/post/489316</guid><dc:creator><![CDATA[Chris1983]]></dc:creator><pubDate>Tue, 15 Sep 2020 18:01:59 GMT</pubDate></item><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Tue, 15 Sep 2020 16:45:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1983" aria-label="Profile: Chris1983">@<bdi>Chris1983</bdi></a> Dann war es vermutlich das falsche Verzeichnis.</p>
]]></description><link>https://forum.iobroker.net/post/489269</link><guid isPermaLink="true">https://forum.iobroker.net/post/489269</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 15 Sep 2020 16:45:07 GMT</pubDate></item><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Tue, 15 Sep 2020 16:12:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> Ok, hab ich jetzt probiert, jetzt kann ich nicht mal mehr den Adapter installieren, er bricht die Installation ab mit dem Text:</p>
<pre><code>$ ./iobroker add ecovacs-deebot  --host raspberrypi
NPM version: 6.14.8
npm install iobroker.ecovacs-deebot@1.0.3 --loglevel error --prefix "/opt/iobroker" (System call)
npm
ERR! code
 ELOOPnpm
 ERR!
 syscall access
npm
ERR! path
npm ERR! errno -40
npm
 ERR! ELOOP: too many symbolic links encountered, access '/opt/iobroker/node_modules/canvas'
npm
ERR! A complete log of this run can be found in:npm
 ERR!
     /home/iobroker/.npm/_logs/2020-09-15T16_08_20_190Z-debug.log
ERROR: host.raspberrypi Cannot install iobroker.ecovacs-deebot@1.0.3: 216
</code></pre>
<p dir="auto">und den log legt er leider auch nicht an, der Ordner ist leer.</p>
]]></description><link>https://forum.iobroker.net/post/489255</link><guid isPermaLink="true">https://forum.iobroker.net/post/489255</guid><dc:creator><![CDATA[Chris1983]]></dc:creator><pubDate>Tue, 15 Sep 2020 16:12:40 GMT</pubDate></item><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Tue, 15 Sep 2020 15:12:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1983" aria-label="Profile: Chris1983">@<bdi>Chris1983</bdi></a></p>
<p dir="auto">Vorab: Node nach dem Update desselben noch sauber?</p>
<pre><code>whoami &amp;&amp; who -r &amp;&amp; which nodejs &amp;&amp; nodejs -v &amp;&amp; which node &amp;&amp; node -v &amp;&amp; which npm &amp;&amp; npm -v &amp;&amp; apt policy nodejs
</code></pre>
<p dir="auto">Ich bin nicht sicher, ob das so funktioniert:</p>
<pre><code>cd /opt/iobroker
iobroker rebuild canvas
</code></pre>
<p dir="auto">Alternativ mal so:</p>
<pre><code>cd /opt/iobroker/node_modules
npm rebuild canvas
</code></pre>
]]></description><link>https://forum.iobroker.net/post/489208</link><guid isPermaLink="true">https://forum.iobroker.net/post/489208</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 15 Sep 2020 15:12:19 GMT</pubDate></item><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Tue, 15 Sep 2020 14:54:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> Danke für die Antwort. mit dem Canvas hab ich mehrfach probiert, hilft nicht. Oder wie bau ich das neu?  Das sind die Schritte die ich gemacht habe:</p>
<pre><code>sudo apt-get update
sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
</code></pre>
]]></description><link>https://forum.iobroker.net/post/489195</link><guid isPermaLink="true">https://forum.iobroker.net/post/489195</guid><dc:creator><![CDATA[Chris1983]]></dc:creator><pubDate>Tue, 15 Sep 2020 14:54:45 GMT</pubDate></item><item><title><![CDATA[Reply to nach iobroker-update verliert instanz verbindung on Mon, 14 Sep 2020 20:19:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1983" aria-label="Profile: Chris1983">@<bdi>Chris1983</bdi></a><br />
canvas neubauen.<br />
Bitte Textausgaben in CodeTags setzen.</p>
]]></description><link>https://forum.iobroker.net/post/488897</link><guid isPermaLink="true">https://forum.iobroker.net/post/488897</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 14 Sep 2020 20:19:24 GMT</pubDate></item></channel></rss>
