<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IoBroker nach Neuinstallation nicht erreichbar]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">leider musste ich mein System neu aufsetzen.<br />
Ich habe es eigentlich wie beim letzten Mal gemacht.</p>
<p dir="auto">Doch leider lässt sich die Weboberfläche nicht aufrufen.<br />
ERR_CONNECTION_TIMED_OUT</p>
<p dir="auto">Hier meine installation:</p>
<pre><code>login as: pi
pi@192.168.22.200's password:
Linux iobroker 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40 BST 2020 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Aug 20 12:54:41 2020
pi@iobroker:~ $ node -v
-bash: node: Kommando nicht gefunden.
pi@iobroker:~ $ nodejs -v
-bash: nodejs: Kommando nicht gefunden.
pi@iobroker:~ $ npm -v
-bash: npm: Kommando nicht gefunden.
pi@iobroker:~ $ curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
## Installing the NodeSource Node.js 10.x repo...
## Populating apt-get cache...
+ apt-get update
OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
OK:2 http://archive.raspberrypi.org/debian buster InRelease
## Confirming "buster" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_10.x/dists/buster/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
OK
## Creating apt sources list file for the NodeSource Node.js 10.x repo...
+ echo 'deb https://deb.nodesource.com/node_10.x buster main' &gt; /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src https://deb.nodesource.com/node_10.x buster main' &gt;&gt; /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
Holen:3 https://deb.nodesource.com/node_10.x buster InRelease [4.584 B]
Holen:4 https://deb.nodesource.com/node_10.x buster/main armhf Packages [765 B]
Es wurden 5.349 B in 1 s geholt (3.678 B/s).
## Run `sudo apt-get install -y nodejs` to install Node.js 10.x and npm
## You may also need development tools to build native addons:
     sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
     curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
     echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
     sudo apt-get update &amp;&amp; sudo apt-get install yarn
pi@iobroker:~ $ sudo apt install -y nodejs
Die folgenden NEUEN Pakete werden installiert:
  nodejs
0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Es müssen 14,6 MB an Archiven heruntergeladen werden.
Nach dieser Operation werden 77,5 MB Plattenplatz zusätzlich benutzt.
Holen:1 https://deb.nodesource.com/node_10.x buster/main armhf nodejs armhf 10.22.0-1nodesource1 [14,6 MB]
Es wurden 14,6 MB in 2 s geholt (8.518 kB/s).
Vormals nicht ausgewähltes Paket nodejs wird gewählt.
(Lese Datenbank ... 93827 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../nodejs_10.22.0-1nodesource1_armhf.deb ...
Entpacken von nodejs (10.22.0-1nodesource1) ...
nodejs (10.22.0-1nodesource1) wird eingerichtet ...
Trigger für man-db (2.8.5-2) werden verarbeitet ...
pi@iobroker:~ $ sudo reboot
login as: pi
Last login: Mon Aug 31 09:26:00 2020 from 192.168.22.238
v10.22.0
v10.22.0
6.14.6
pi@iobroker:~ $ curl -sL https://iobroker.net/install.sh | bash -
library: loaded
Library version=2020-06-12
    Welcome to the ioBroker installer!
    Installer version: 2020-06-12
    You might need to enter your password a couple of times.
    Installing prerequisites (1/4)
OK:3 https://deb.nodesource.com/node_10.x buster InRelease
Changing npm registry to https://registry.npmjs.org
Installed acl
Installed gcc-c++
Installed libavahi-compat-libdnssd-dev
Installed libudev-dev
Installed libpam0g-dev
    Creating ioBroker user and directory (2/4)
User iobroker created
Created /etc/sudoers.d/iobroker
Directory /opt/iobroker created
    Installing ioBroker (3/4)
In file included from ../src/main.cpp:3:
../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     , reinterpret_cast&lt;uv_after_work_cb&gt;(AsyncExecuteComplete)
In file included from ../../nan/nan.h:56,
../src/main.cpp: At global scope:
/home/pi/.cache/node-gyp/10.22.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local&lt;v8::Object&gt;)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local&lt;v8::Object&gt;, v8::Local&lt;v8::Value&gt;, void*)’} [-Wcast-function-type]
       (node::addon_register_func) (regfunc),                          \
/home/pi/.cache/node-gyp/10.22.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
 NODE_MODULE(diskusage, Init)
In file included from /home/pi/.cache/node-gyp/10.22.0/include/node/node.h:63,
/home/pi/.cache/node-gyp/10.22.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase&lt;T&gt;::SetWeak(P*, typename v8::WeakCallbackInfo&lt;P&gt;::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo&lt;P&gt;::Callback = void (*)(const v8::WeakCallbackInfo&lt;node::ObjectWrap&gt;&amp;)]’:
/home/pi/.cache/node-gyp/10.22.0/include/node/node_object_wrap.h:84:78:   required from here
/home/pi/.cache/node-gyp/10.22.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo&lt;node::ObjectWrap&gt;::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo&lt;node::ObjectWrap&gt;&amp;)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo&lt;void&gt;&amp;)’} [-Wcast-function-type]
                reinterpret_cast&lt;Callback&gt;(callback), type);
/home/pi/.cache/node-gyp/10.22.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase&lt;T&gt;::SetWeak(P*, typename v8::WeakCallbackInfo&lt;P&gt;::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo&lt;P&gt;::Callback = void (*)(const v8::WeakCallbackInfo&lt;Nan::ObjectWrap&gt;&amp;)]’:
../../nan/nan_object_wrap.h:65:61:   required from here
/home/pi/.cache/node-gyp/10.22.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo&lt;Nan::ObjectWrap&gt;::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo&lt;Nan::ObjectWrap&gt;&amp;)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo&lt;void&gt;&amp;)’} [-Wcast-function-type]
In file included from ../src/unix_dgram.cc:5:
../src/unix_dgram.cc: At global scope:
../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
 NODE_MODULE(unix_dgram, Initialize)
In file included from ../src/./serialport.h:6,
                 from ../src/serialport.cpp:1:
../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
../src/serialport.cpp: At global scope:
../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
 SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local&lt;v8::String&gt;&amp; v8str)) {
../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
 SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
In file included from ../../../nan/nan.h:56,
/home/pi/.cache/node-gyp/10.22.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local&lt;v8::Object&gt;)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local&lt;v8::Object&gt;, v8::Local&lt;v8::Value&gt;, void*)’} [-Wcast-function-type]
../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
 NODE_MODULE(serialport, init);
../../../nan/nan_object_wrap.h:65:61:   required from here
In file included from ../src/serialport.h:6,
                 from ../src/serialport_unix.cpp:2:
../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
     snprintf(data-&gt;errorString, sizeof(data-&gt;errorString), "Error %s Cannot open %s", strerror(errno), data-&gt;path);
../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
     snprintf(data-&gt;errorString, sizeof(data-&gt;errorString), "Error: %s, cannot open %s", strerror(errno), data-&gt;path);
../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
In file included from ../src/poller.cpp:1:
ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
ioBroker wants to make sure to deliver the most stable smart home system.
To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
If you want to disable the error reporting you can use the command
'iobroker plugin disable sentry'
This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
    Finalizing installation (4/4)
Enabling autostart...
Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
Autostart enabled!
    ioBroker was installed successfully
    Open http://192.168.22.200:8081 in a browser and start configuring!
You need to re-login before doing anything else on the console!
</code></pre>
<p dir="auto">iobroker status meint, dass alles okay ist.</p>
<pre><code>pi@iobroker:~ $ iobroker status
Objects type: file
States  type: file
pi@iobroker:~ $
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/36442/iobroker-nach-neuinstallation-nicht-erreichbar</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 06:05:11 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/36442.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 Aug 2020 07:46:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IoBroker nach Neuinstallation nicht erreichbar on Mon, 31 Aug 2020 08:14:15 GMT]]></title><description><![CDATA[<p dir="auto">@David-G sagte in <a href="/post/482178">IoBroker nach Neuinstallation nicht erreichbar</a>:</p>
<blockquote>
<p dir="auto">Das hätte ich nicht vermutet .........</p>
</blockquote>
<p dir="auto">Ist eine der häufigsten Ursachen bei Fehlern nach Änderungen</p>
]]></description><link>https://forum.iobroker.net/post/482181</link><guid isPermaLink="true">https://forum.iobroker.net/post/482181</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Mon, 31 Aug 2020 08:14:15 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker nach Neuinstallation nicht erreichbar on Mon, 31 Aug 2020 08:10:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a></p>
<p dir="auto">Der Cache war es.<br />
Vielen Dank.</p>
]]></description><link>https://forum.iobroker.net/post/482178</link><guid isPermaLink="true">https://forum.iobroker.net/post/482178</guid><dc:creator><![CDATA[David G.]]></dc:creator><pubDate>Mon, 31 Aug 2020 08:10:50 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker nach Neuinstallation nicht erreichbar on Mon, 31 Aug 2020 08:07:13 GMT]]></title><description><![CDATA[<p dir="auto">@David-G sagte in <a href="/post/482164">IoBroker nach Neuinstallation nicht erreichbar</a>:</p>
<blockquote>
<p dir="auto">Open <a href="http://192.168.22.200:8081" rel="nofollow ugc">http://192.168.22.200:8081</a> in a browser</p>
</blockquote>
<p dir="auto">Du hast es auch unter der IP versucht?</p>
<p dir="auto">Auch schon mal browsercache gelöscht?</p>
]]></description><link>https://forum.iobroker.net/post/482175</link><guid isPermaLink="true">https://forum.iobroker.net/post/482175</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Mon, 31 Aug 2020 08:07:13 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker nach Neuinstallation nicht erreichbar on Mon, 31 Aug 2020 07:58:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a></p>
<pre><code>pi@iobroker:~ $ iobroker list instances
+ system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.discovery.0             : discovery             -  enabled
+ system.adapter.info.0                  : info                  -  enabled
+ instance is alive
</code></pre>
]]></description><link>https://forum.iobroker.net/post/482169</link><guid isPermaLink="true">https://forum.iobroker.net/post/482169</guid><dc:creator><![CDATA[David G.]]></dc:creator><pubDate>Mon, 31 Aug 2020 07:58:54 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker nach Neuinstallation nicht erreichbar on Mon, 31 Aug 2020 07:48:35 GMT]]></title><description><![CDATA[<p dir="auto">@David-G sagte in <a href="/post/482164">IoBroker nach Neuinstallation nicht erreichbar</a>:</p>
<blockquote>
<p dir="auto">You need to re-login before doing anything else on the console!</p>
</blockquote>
<p dir="auto">Und dann</p>
<p dir="auto"><code>iobroker list instances</code></p>
<p dir="auto">Output bitte hier posten</p>
]]></description><link>https://forum.iobroker.net/post/482166</link><guid isPermaLink="true">https://forum.iobroker.net/post/482166</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Mon, 31 Aug 2020 07:48:35 GMT</pubDate></item></channel></rss>
