<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Hilfe Iobroker nach Js-Controller upgrade defekt]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/18103/gel%C3%B6st-hilfe-nach-update-js-controller-nicht-installierbar">[GELÖST] HILFE - Nach update js-controller nicht installierbar</a></p>
<p dir="auto">nach dem ich den iobroker gestoppt hatte und das update und upgrade ausgeführt hatte, ließ sich der Iobroker nicht mehr starten.<br />
Hier mein letzter Versuch etwas zu retten.</p>
<pre><code>sudo npm install iobroker.js-controller –unsafe-perm
npm ERR! code EINVALIDTAGNAME
npm ERR! Invalid tag name "–unsafe-perm": Tags may not have any characters that encodeURIComponent encodes.
npm ERR!     /Users/kathrindinter/.npm/_logs/2020-06-20T20_12_54_630Z-debug.log
kathrindinter@Kathrins-iMac iobroker % sudo npm install iobroker.js-controller
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
&gt; iobroker.js-controller@3.1.6 preinstall /usr/local/iobroker/node_modules/iobroker.js-controller
&gt; node lib/preinstallCheck.js
NPM version: 6.14.4
&gt; osx-temperature-sensor@1.0.7 install /usr/local/iobroker/node_modules/osx-temperature-sensor
&gt; node-gyp rebuild
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir '/usr/local/iobroker/node_modules/osx-temperature-sensor/build'
gyp ERR! System Darwin 19.4.0
gyp ERR! command "/usr/local/Cellar/node/14.4.0/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /usr/local/iobroker/node_modules/osx-temperature-sensor
gyp ERR! node -v v14.4.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
&gt; iobroker.js-controller@3.1.6 install /usr/local/iobroker/node_modules/iobroker.js-controller
&gt; node iobroker.js setup first
Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/usr/local/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/usr/local/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/usr/local/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
internal/fs/utils.js:259
    throw err;
Error: EACCES: permission denied, mkdir '/usr/local/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
    at Object.mkdirSync (fs.js:940:3)
    at Setup.setup (/usr/local/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:780:16)
    at processCommand (/usr/local/iobroker/node_modules/iobroker.js-controller/lib/setup.js:264:23)
    at Object.module.exports.execute (/usr/local/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2601:5)
    at Object.&lt;anonymous&gt; (/usr/local/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
    at Module._compile (internal/modules/cjs/loader.js:1200:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1220:10)
    at Module.load (internal/modules/cjs/loader.js:1049:32)
    at Function.Module._load (internal/modules/cjs/loader.js:937:14)
    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12) {
  errno: -13,
  syscall: 'mkdir',
  code: 'EACCES',
  path: '/usr/local/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 install: `node-gyp rebuild`
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! iobroker.js-controller@3.1.6 install: `node iobroker.js setup first`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the iobroker.js-controller@3.1.6 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR!     /Users/kathrindinter/.npm/_logs/2020-06-20T20_13_29_242Z-debug.log
kathrindinter@Kathrins-iMac iobroker % iobroker start
kathrindinter@Kathrins-iMac iobroker % iobroker status
internal/modules/cjs/loader.js:1032
  throw err;
Error: Cannot find module '/usr/local/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:1029:15)
    at Function.Module._load (internal/modules/cjs/loader.js:898:27)
    at internal/main/run_main_module.js:17:47 {
  code: 'MODULE_NOT_FOUND',
  requireStack: []
</code></pre>
<p dir="auto">ich bin auf einem Imac unterwegs</p>
<p dir="auto">wenn ich</p>
<pre><code>curl -sL https://iobroker.net/install.sh | bash -
</code></pre>
<p dir="auto">ausführe, passiert nichts! es kommt nicht einmal eine Fehlermeldung.</p>
]]></description><link>https://forum.iobroker.net/topic/34586/hilfe-iobroker-nach-js-controller-upgrade-defekt</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 01:13:49 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/34586.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Jun 2020 20:17:31 GMT</pubDate><ttl>60</ttl></channel></rss>
