<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bluetooth]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
ich habe immer noch das Problem, das mein Bluetooth Stick nicht mit<br />
hciconfig erkannt wird.<br />
Ich vermute es liegt an der Firmware. Wie kann ich diese Kontollieren?<br />
Ein Fehler  System does not support network plugin</p>
<p dir="auto">Der Stick ist in Ordung, hab Ihn in ein anderes System getestet.</p>
<pre><code>root@rock:~# sudo service bluetooth status
● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
   Active: active (running) since Tue 2020-05-05 10:39:18 CEST; 1s ago
     Docs: man:bluetoothd(8)
 Main PID: 12414 (bluetoothd)
   Status: "Running"
    Tasks: 1 (limit: 4746)
   Memory: 2.3M
   CGroup: /system.slice/bluetooth.service
           └─12414 /usr/lib/bluetooth/bluetoothd
Mai 05 10:39:17 rock systemd[1]: Starting Bluetooth service...
Mai 05 10:39:18 rock bluetoothd[12414]: Bluetooth daemon 5.50
Mai 05 10:39:18 rock systemd[1]: Started Bluetooth service.
Mai 05 10:39:18 rock bluetoothd[12414]: Starting SDP server
Mai 05 10:39:18 rock bluetoothd[12414]: kernel lacks bnep-protocol support
Mai 05 10:39:18 rock bluetoothd[12414]: System does not support network plugin
Mai 05 10:39:18 rock bluetoothd[12414]: Bluetooth management interface 1.14 initialized
</code></pre>
<pre><code>root@rock:~# lsusb | grep -i bluetooth
Bus 001 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
root@rock:~#
</code></pre>
<pre><code>sudo dmesg | egrep -i 'blue|firm'
[    0.000000] psci: PSCIv1.0 detected in firmware.
[  174.158325] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[  635.504557] Bluetooth: Core ver 2.22
[  635.504633] Bluetooth: HCI device and connection manager initialized
[  635.504649] Bluetooth: HCI socket layer initialized
[  635.504656] Bluetooth: L2CAP socket layer initialized
[  635.504673] Bluetooth: SCO socket layer initialized
root@rock:~#
</code></pre>
<p dir="auto">Was muss ich tun?</p>
]]></description><link>https://forum.iobroker.net/topic/33043/bluetooth</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 21:39:52 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/33043.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 May 2020 08:46:34 GMT</pubDate><ttl>60</ttl></channel></rss>
