<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fehlermeldung im LOG, finde keine Erklärung]]></title><description><![CDATA[<p dir="auto">Hallo, neu eingerichteter IOBroker, und im LOG begenet mir immer diese Meldung:</p>
<pre><code>host.IntelNUC	2020-02-15 11:45:55.423	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
host.IntelNUC	2020-02-15 11:45:55.423	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:90593)
host.IntelNUC	2020-02-15 11:45:55.423	error	Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
host.IntelNUC	2020-02-15 11:45:55.423	error	Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
host.IntelNUC	2020-02-15 11:45:55.423	error	Caught by controller[0]: at Array.forEach (&lt;anonymous&gt;)
host.IntelNUC	2020-02-15 11:45:55.423	error	Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
host.IntelNUC	2020-02-15 11:45:55.422	error	Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
host.IntelNUC	2020-02-15 11:45:55.422	error	Caught by controller[0]: at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
host.IntelNUC	2020-02-15 11:45:55.422	error	Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
host.IntelNUC	2020-02-15 11:45:55.422	error	Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
</code></pre>
<p dir="auto"><strong>MOD EDIT: Code in Code-Tags gesetzt</strong></p>
<p dir="auto">Leider finde ich nicht, woher das kommt? Kann mir jemand das erklären?</p>
]]></description><link>https://forum.iobroker.net/topic/30192/fehlermeldung-im-log-finde-keine-erklärung</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 12:40:55 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/30192.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Feb 2020 10:51:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fehlermeldung im LOG, finde keine Erklärung on Mon, 09 Mar 2020 07:54:58 GMT]]></title><description><![CDATA[<p dir="auto">@J-BORGER  das läuft bei mir auf einem Intel NUC PC Linux Ubuntu 18.4 LTS. Nun läuft es ja, da ich an den NUC meinen Monitor angeschlossen habe, und dort auf der Oberfläche IoBroker eingerichtet habe. Nun laufen alle Adapter wieder korrekt. Gehe allerdings wieder auf meinen Windows PC, kann ich noch immer nicht die Einrichtung vornehmen. Keine Ahnung, warum das nicht geht wie früher. Da hatte ich den IoBroker auf einem Asus Tinkerboard laufen.</p>
]]></description><link>https://forum.iobroker.net/post/391344</link><guid isPermaLink="true">https://forum.iobroker.net/post/391344</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 09 Mar 2020 07:54:58 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldung im LOG, finde keine Erklärung on Sun, 08 Mar 2020 14:35:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/boogie2005" aria-label="Profile: Boogie2005">@<bdi>Boogie2005</bdi></a></p>
<p dir="auto">Hallo habe auch das selbe Problem wie du. Im Forum von Qnap habe ich unter Container Station auch einen Beitrag aufgemacht. Dort befinden sich einige die den ibrocker auf Qnap laufen haben.</p>
<p dir="auto">Leider konnte mir da auch keine helfen... habe mal im Container nachgesehen ob die entsprechenden Ordner /opt/iobrocker…. ect. vorhanden sind.... Sie sind da.</p>
<p dir="auto">Es muss eigentlich selbst an der Instanz liegen... Da ich auch ein Newbie in dem Bereich bin, wäre ich trotzdem vorsichtig mit meinen Aussagen. Ist wie gesagt eine Vermutung das es an der Instanz liegt.</p>
<p dir="auto">Würde gerne helfen wenn ich könnte.</p>
<p dir="auto">Was meinst du mit  Kontroller(IP; BN, PW)?<br />
Noch eine Frage... hast du in auf RasperyPi oder auf Qnap?</p>
<p dir="auto">Ist es erlaubt auf meinen Beitrag im andern Forum zu verweisen? oder verstößt das gegen die Regeln hier?</p>
<p dir="auto">Hier im Forum gibt es auch noch einen Beitrag dazu:<br />
<a href="https://forum.iobroker.net/topic/30895/qts-4-3-6-ts-231p-1gb-iobrocker-instanz-info-0-l%C3%A4uft-nicht/3">https://forum.iobroker.net/topic/30895/qts-4-3-6-ts-231p-1gb-iobrocker-instanz-info-0-läuft-nicht/3</a></p>
]]></description><link>https://forum.iobroker.net/post/390928</link><guid isPermaLink="true">https://forum.iobroker.net/post/390928</guid><dc:creator><![CDATA[J.BORGER]]></dc:creator><pubDate>Sun, 08 Mar 2020 14:35:48 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldung im LOG, finde keine Erklärung on Sat, 07 Mar 2020 09:09:35 GMT]]></title><description><![CDATA[<p dir="auto">Wäre ja schöner, jemand hätte eine Lösung für mein Problem! Denn ich bekomme es einfach nicht weg: Kein Abspeichern von Daten in dem Kontroller(IP; BN, PW). In dem Adapter ist auch nur unter Objekte das Gäste WLAN drin, nicht das eigentliche WLAN. Somit auch keine HeizThermos verfügbar.</p>
]]></description><link>https://forum.iobroker.net/post/390227</link><guid isPermaLink="true">https://forum.iobroker.net/post/390227</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sat, 07 Mar 2020 09:09:35 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldung im LOG, finde keine Erklärung on Fri, 06 Mar 2020 18:11:39 GMT]]></title><description><![CDATA[<p dir="auto">@J-BORGER said in <a href="/post/389482">Fehlermeldung im LOG, finde keine Erklärung</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/boogie2005" aria-label="Profile: Boogie2005">@<bdi>Boogie2005</bdi></a> said in <a href="/post/378581">Fehlermeldung im LOG, finde keine Erklärung</a>:</p>
<blockquote>
<p dir="auto">Habe jetzt mal nach einigen Lesen auf Latest gestellt. Da wurden mir gleich 12 Adapter mit Updates gezeigt. Jetzt ist alles up to date, aber es taucht ein neues Problem auf: Fritzdetec Adapter liefert jetzt auf einmal Fehler:<br />
Falscher Benutzer oder Passwort. In den Einstellungen ist das leer. Trage ich die richtigen Daten ein, kann ich nicht speichern.<br />
Was ist das wieder???</p>
</blockquote>
<p dir="auto">Wo stelle ich auf Latest um? Bzw. wo wird die Version umgestellt?</p>
</blockquote>
<p dir="auto">Ganz Oben in der blauen Titelleiste des iobrokers ist ein Gabelschlüssel (system).<br />
Dort auf Speicherort von default auf latest.</p>
<p dir="auto">Es empfiehlt sich aber dann auch nur die Adapter zu aktualisieren, wenn was nicht funktioniert und dann wieder auf default umzustellen.<br />
So mache ich es jedenfalls.</p>
]]></description><link>https://forum.iobroker.net/post/389749</link><guid isPermaLink="true">https://forum.iobroker.net/post/389749</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Fri, 06 Mar 2020 18:11:39 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldung im LOG, finde keine Erklärung on Fri, 06 Mar 2020 10:04:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/boogie2005" aria-label="Profile: Boogie2005">@<bdi>Boogie2005</bdi></a> said in <a href="/post/378581">Fehlermeldung im LOG, finde keine Erklärung</a>:</p>
<blockquote>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/389482</link><guid isPermaLink="true">https://forum.iobroker.net/post/389482</guid><dc:creator><![CDATA[J.BORGER]]></dc:creator><pubDate>Fri, 06 Mar 2020 10:04:21 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldung im LOG, finde keine Erklärung on Sun, 16 Feb 2020 11:15:33 GMT]]></title><description><![CDATA[<p dir="auto">Habe jetzt mal nach einigen Lesen auf Latest gestellt. Da wurden mir gleich 12 Adapter mit Updates gezeigt. Jetzt ist alles up to date, aber es taucht ein neues Problem auf: Fritzdetec Adapter liefert jetzt auf einmal Fehler:<br />
]]></description><link>https://forum.iobroker.net/post/378581</link><guid isPermaLink="true">https://forum.iobroker.net/post/378581</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 16 Feb 2020 11:15:33 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldung im LOG, finde keine Erklärung on Sun, 16 Feb 2020 10:42:28 GMT]]></title><description><![CDATA[<p dir="auto">Bei mir auch die 1.56. Es wird auch kein Update angeboten.</p>
]]></description><link>https://forum.iobroker.net/post/378563</link><guid isPermaLink="true">https://forum.iobroker.net/post/378563</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 16 Feb 2020 10:42:28 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldung im LOG, finde keine Erklärung on Sun, 16 Feb 2020 08:35:30 GMT]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
bekomme auch diese Meldungen und weiß nicht woran es liegt??<br />
Habe die Info Version 1.5.6<br />
Auch ich würde mich sehr über eine Hilfe freuen.<br />
DANKE !!</p>
]]></description><link>https://forum.iobroker.net/post/378461</link><guid isPermaLink="true">https://forum.iobroker.net/post/378461</guid><dc:creator><![CDATA[jokerjo1000]]></dc:creator><pubDate>Sun, 16 Feb 2020 08:35:30 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldung im LOG, finde keine Erklärung on Sat, 15 Feb 2020 11:31:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/boogie2005" aria-label="Profile: Boogie2005">@<bdi>Boogie2005</bdi></a> sagte in <a href="/post/378011">Fehlermeldung im LOG, finde keine Erklärung</a>:</p>
<blockquote>
<p dir="auto"><a href="http://iobroker.info" rel="nofollow ugc">iobroker.info</a></p>
</blockquote>
<p dir="auto">Welche Version von <a href="http://iobroker.info" rel="nofollow ugc">iobroker.info</a> ?</p>
]]></description><link>https://forum.iobroker.net/post/378034</link><guid isPermaLink="true">https://forum.iobroker.net/post/378034</guid><dc:creator><![CDATA[sigi234]]></dc:creator><pubDate>Sat, 15 Feb 2020 11:31:58 GMT</pubDate></item></channel></rss>
