<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Radar2 Adapter Fehler nach Umzug]]></title><description><![CDATA[<p dir="auto">Nach dem Umzug vom raspberry3B+ auf den 4B hatte ich folgende Meldung im Logfile:</p>
<pre><code>radar2.0	2020-01-24 20:33:38.837	warn	(12681) node-bluetooth not found!
2020-01-24 19:16:49.802 - warn: radar2.0 (790) Noble not available, Error: Error: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 57. This version of Node.js requiresNODE_MODULE_VERSION 64. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)at Module.load (internal/modules/cjs/loader.js:653:32)at tryModuleLoad (internal/modules/cjs/loader.js:593:12)at Function.Module._load (internal/modules/cjs/loader.js:585:3)at Module.require (internal/modules/cjs/loader.js:692:17)at require (internal/modules/cjs/helpers.js:25:18)at Object. (/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/native.js:6:15)at Module._compile (internal/modules/cjs/loader.js:778:30)at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)at Module.load (internal/modules/cjs/loader.js:653:32)
</code></pre>
<p dir="auto">Prinzipiell verstehe ich ja die Meldung:<br />
"...was compiled against a different Node.js version usingNODE_MODULE_VERSION 57. This version of Node.js requiresNODE_MODULE_VERSION 64. ..."</p>
<p dir="auto">Mir ist auch klar, dass ich die Anweisung bekommen habe das Modul neu zu compilieren.<br />
"...Please try re-compiling or re-installingthe module (for instance, using <code>npm rebuild</code> or <code>npm install</code>).at Object.Module._extensions..node..."</p>
<p dir="auto">Nur hilft mir diese Meldung absolut nicht weiter, da ich nicht weiß wie der genaue Befehl lautet. Kann mir jemand vielleicht weiterhelfen bzw. die genaue Befehlsstruktur angeben?</p>
<p dir="auto">Ich habe zwar schon mit dem Befehl:<br />
"sudo apt-get purge libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools"</p>
<p dir="auto">alle Pakete gelöscht und nochmals mit<br />
"sudo apt-get install libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools"</p>
<p dir="auto">nochmals installiert. Hat aber leider auch nicht geholfen.</p>
<p dir="auto">Danke!</p>
]]></description><link>https://forum.iobroker.net/topic/29330/radar2-adapter-fehler-nach-umzug</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 21:01:17 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/29330.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Jan 2020 19:50:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Radar2 Adapter Fehler nach Umzug on Fri, 24 Jan 2020 20:10:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a> sagte in <a href="/post/364308">Radar2 Adapter Fehler nach Umzug</a>:</p>
<blockquote>
<p dir="auto">rebuild</p>
</blockquote>
<p dir="auto">Danke, das hab ich jetzt gemacht. und da bekomme ich folgende Fehlermeldung:</p>
<pre><code>&gt; @abandonware/bluetooth-hci-socket@0.5.3-3 install /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
&gt; node-pre-gyp install --fallback-to-build
sh: 1: node-pre-gyp: Permission denied
npm ERR! code ELIFECYCLE
npm ERR! errno 126
npm ERR! @abandonware/bluetooth-hci-socket@0.5.3-3 install: `node-pre-gyp install --fallback-to-build`
npm ERR! Exit status 126
npm ERR!
npm ERR! Failed at the @abandonware/bluetooth-hci-socket@0.5.3-3 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR!     /home/iobroker/.npm/_logs/2020-01-24T20_01_31_815Z-debug.log
</code></pre>
<p dir="auto">Und was mache ich jetzt?</p>
<p dir="auto">Im Log bekomme ich immer noch:</p>
<pre><code>2020-01-24 21:05:14.951 - warn: radar2.0 (23826) Noble not available, Error: Error: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 57. This version of Node.js requiresNODE_MODULE_VERSION 64. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)at Module.load (internal/modules/cjs/loader.js:653:32)at tryModuleLoad (internal/modules/cjs/loader.js:593:12)at Function.Module._load (internal/modules/cjs/loader.js:585:3)at Module.require (internal/modules/cjs/loader.js:692:17)at require (internal/modules/cjs/helpers.js:25:18)at Object. (/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/native.js:6:15)at Module._compile (internal/modules/cjs/loader.js:778:30)at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)at Module.load (internal/modules/cjs/loader.js:653:32)
</code></pre>
]]></description><link>https://forum.iobroker.net/post/364312</link><guid isPermaLink="true">https://forum.iobroker.net/post/364312</guid><dc:creator><![CDATA[Mauflo]]></dc:creator><pubDate>Fri, 24 Jan 2020 20:10:09 GMT</pubDate></item><item><title><![CDATA[Reply to Radar2 Adapter Fehler nach Umzug on Fri, 24 Jan 2020 19:55:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mauflo" aria-label="Profile: Mauflo">@<bdi>Mauflo</bdi></a> sagte in <a href="/post/364304">Radar2 Adapter Fehler nach Umzug</a>:</p>
<blockquote>
<p dir="auto">da ich nicht weiß wie der genaue Befehl lautet.</p>
</blockquote>
<p dir="auto">du sagst es doch:</p>
<blockquote>
<p dir="auto">using npm rebuild</p>
</blockquote>
<blockquote>
<p dir="auto">nach dem Umzug...</p>
</blockquote>
<p dir="auto">auf eine andere Hardware und/oder nodejs Main Version muss ¸npm rebuild¸ im ioBroker Installationsordner (üblicherweise /opt/iobroker ausgeführt werden, damit alle Pakete an die geänderten Bedingungen compiliert werden können</p>
]]></description><link>https://forum.iobroker.net/post/364308</link><guid isPermaLink="true">https://forum.iobroker.net/post/364308</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 24 Jan 2020 19:55:05 GMT</pubDate></item></channel></rss>
