<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[XBOX Adapter npm ERR Elifecycle]]></title><description><![CDATA[<p dir="auto">Ich probiere verzweifelt auf einem Pi3 den XBOX Adapter Version 0.5.8 zum laufen zu bekommen.<br />
Leider laufe ich jetzt in folgende Fehlermeldung und weiß mir nicht mehr zu helfen:</p>
<pre><code>sudo npm install iobroker.xbox@0.5.8 --unsafe-perm --loglevel error --prefix "/opt/iobroker"
&gt; iobroker.xbox@0.5.8 preinstall /opt/iobroker/node_modules/iobroker.xbox
&gt; apt install -y build-essential libssl-dev libffi-dev python3-dev || echo -e '[INFO] Cant install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage to install the packages by yourself. If you are not running on Linux, you can ignore this INFO.'
Reading package lists... Done
Building dependency tree
build-essential is already the newest version (12.3).
libffi-dev is already the newest version (3.2.1-6).
libssl-dev is already the newest version (1.1.0l-1~deb9u1).
python3-dev is already the newest version (3.5.3-1).
0 upgraded, 0 newly installed, 0 to remove and 45 not upgraded.
&gt; iobroker.xbox@0.5.8 install /opt/iobroker/node_modules/iobroker.xbox
&gt; npip install
No python_modules directory; installing pip locally if needed.
  Cache entry deserialization failed, entry ignored
  Could not find a version that satisfies the requirement pip (from versions: )
No matching distribution found for pip
Error: Exited with code 1.
    at ChildProcess.child.on.code (/opt/iobroker/node_modules/nopy/src/api.js:277:20)
    at emitTwo (events.js:126:13)
    at ChildProcess.emit (events.js:214:7)
    at maybeClose (internal/child_process.js:915:16)
    at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! iobroker.xbox@0.5.8 install: `npip install`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the iobroker.xbox@0.5.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
</code></pre>
<p dir="auto">Habe jetzt schon Python 3.5.2, alle möglichen build essential und pip3 sowie pip installiert.<br />
Deinstallieren klappt mit dem Papierkorb irgendwie auch nicht mehr :(, selbst in der Console bekomme ich eine Fehlermeldung das ich selber deinstallieren soll.</p>
<p dir="auto">Jemand noch eine Idee? Welches PIP fehlt da ?</p>
<p dir="auto">Danke schonmal...</p>
]]></description><link>https://forum.iobroker.net/topic/28649/xbox-adapter-npm-err-elifecycle</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 02:18:36 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/28649.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Jan 2020 17:26:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to XBOX Adapter npm ERR Elifecycle on Thu, 27 Feb 2020 18:34:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/r0b1zzle" aria-label="Profile: r0b1zZle">@<bdi>r0b1zZle</bdi></a> welches Problem denn genau?</p>
]]></description><link>https://forum.iobroker.net/post/385193</link><guid isPermaLink="true">https://forum.iobroker.net/post/385193</guid><dc:creator><![CDATA[foxriver76]]></dc:creator><pubDate>Thu, 27 Feb 2020 18:34:35 GMT</pubDate></item><item><title><![CDATA[Reply to XBOX Adapter npm ERR Elifecycle on Thu, 27 Feb 2020 18:08:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/smallfeuer" aria-label="Profile: Smallfeuer">@<bdi>Smallfeuer</bdi></a> hast du es mittlerweile hinbekommen? Habe einen ähnlichen Fehler und konnte bislang keine Lösung finden.</p>
]]></description><link>https://forum.iobroker.net/post/385180</link><guid isPermaLink="true">https://forum.iobroker.net/post/385180</guid><dc:creator><![CDATA[r0b1zZle]]></dc:creator><pubDate>Thu, 27 Feb 2020 18:08:48 GMT</pubDate></item><item><title><![CDATA[Reply to XBOX Adapter npm ERR Elifecycle on Wed, 08 Jan 2020 19:24:35 GMT]]></title><description><![CDATA[<p dir="auto">Keiner eine Idee???</p>
]]></description><link>https://forum.iobroker.net/post/354322</link><guid isPermaLink="true">https://forum.iobroker.net/post/354322</guid><dc:creator><![CDATA[Smallfeuer]]></dc:creator><pubDate>Wed, 08 Jan 2020 19:24:35 GMT</pubDate></item><item><title><![CDATA[Reply to XBOX Adapter npm ERR Elifecycle on Tue, 07 Jan 2020 18:51:45 GMT]]></title><description><![CDATA[<p dir="auto">hier noch der LOG dazu:</p>
<pre><code>1454 warn enoent ENOENT: no such file or directory, open '/home/pi/package.json'
1455 verbose enoent This is related to npm not being able to find a file.
1456 warn pi No description
1457 warn pi No repository field.
1458 warn pi No README data
1459 warn pi No license field.
1460 verbose stack Error: iobroker.xbox@0.5.11 install: `npip install`
1460 verbose stack Exit status 1
1460 verbose stack     at EventEmitter.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
1460 verbose stack     at emitTwo (events.js:126:13)
1460 verbose stack     at EventEmitter.emit (events.js:214:7)
1460 verbose stack     at ChildProcess.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
1460 verbose stack     at ChildProcess.emit (events.js:214:7)
1460 verbose stack     at maybeClose (internal/child_process.js:915:16)
1460 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
1461 verbose pkgid iobroker.xbox@0.5.11
1462 verbose cwd /home/pi
1463 verbose Linux 4.19.42-v7+
1464 verbose argv "/usr/bin/node" "/usr/bin/npm" "i" "iobroker.xbox" "--unsafe-perm"
1465 verbose node v8.16.0
1466 verbose npm  v6.4.1
1467 error code ELIFECYCLE
1468 error errno 1
1469 error iobroker.xbox@0.5.11 install: `npip install`
1469 error Exit status 1
1470 error Failed at the iobroker.xbox@0.5.11 install script.
1470 error This is probably not a problem with npm. There is likely additional logging output above.
1471 verbose exit [ 1, true ]
</code></pre>
]]></description><link>https://forum.iobroker.net/post/353643</link><guid isPermaLink="true">https://forum.iobroker.net/post/353643</guid><dc:creator><![CDATA[Smallfeuer]]></dc:creator><pubDate>Tue, 07 Jan 2020 18:51:45 GMT</pubDate></item></channel></rss>
