<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Probleme Multihost neue Instanzen von Adaptern]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">bei der Installation beliebiger Adapter/Instanzen auf meinem Multihost slave bekomme ich folgenden Fehler:</p>
<pre><code>$ ./iobroker add ble  --host ioBroker-RasPi-zero
NPM version: 6.10.1
npm install iobroker.ble@0.7.2 --production --save --prefix "/opt/iobroker" (System call)
npm
ERR!
 Unexpected token :
npm
 ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-07-17T18_37_11_377Z-debug.log
host.ioBroker-RasPi-zero create instance ble
ERROR: host.ioBroker-RasPi-zero error: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json'
ERROR: process exited with code 20
</code></pre>
<p dir="auto">Master:</p>
<pre><code>pi@ioBroker-RasPi:~ $ npm -v
node -v6.10.1
pi@ioBroker-RasPi:~ $ node -v
v8.14.0
pi@ioBroker-RasPi:~ $ iobroker -v
1.5.11
</code></pre>
<p dir="auto">Slave</p>
<pre><code>pi@ioBroker-RasPi-zero:/etc/init.d $ npm -v
node -v6.10.1
pi@ioBroker-RasPi-zero:/etc/init.d $ node -v
v8.12.0
pi@ioBroker-RasPi-zero:/etc/init.d $ iobroker -v
1.5.11
</code></pre>
<p dir="auto">Der Adminadapter ließ sich über den Master-Admin ohne Probleme auf dem Slave installieren. Das ganze schlägt auch z.B. für den "Ping" Adapter fehl.</p>
<pre><code>pi@ioBroker-RasPi-zero:/etc/init.d $ cat /home/iobroker/.npm/_logs/2019-07-17T18_37_11_377Z-debug.log
0 info it worked if it ends with ok
1 verbose cli [ '/usr/local/bin/node',
1 verbose cli   '/usr/local/bin/npm',
1 verbose cli   'install',
1 verbose cli   'iobroker.ble@0.7.2',
1 verbose cli   '--production',
1 verbose cli   '--save',
1 verbose cli   '--prefix',
1 verbose cli   '/opt/iobroker' ]
2 info using npm@6.10.1
3 info using node@v8.12.0
4 verbose npm-session 66abdd2015cf483b
5 verbose stack /usr/local/lib/node_modules/npm/node_modules/worker-farm/lib/index.js:2
5 verbose stack   "_from": "npm-bundled@^1.0.1",
5 verbose stack          ^
5 verbose stack
5 verbose stack SyntaxError: Unexpected token :
5 verbose stack     at createScript (vm.js:80:10)
5 verbose stack     at Object.runInThisContext (vm.js:139:10)
5 verbose stack     at Module._compile (module.js:617:28)
5 verbose stack     at Object.Module._extensions..js (module.js:664:10)
5 verbose stack     at Module.load (module.js:566:32)
5 verbose stack     at tryModuleLoad (module.js:506:12)
5 verbose stack     at Function.Module._load (module.js:498:3)
5 verbose stack     at Module.require (module.js:597:17)
5 verbose stack     at require (internal/module.js:11:18)
5 verbose stack     at Object.&lt;anonymous&gt; (/usr/local/lib/node_modules/npm/lib/install/action/extract.js:18:20)
5 verbose stack     at Module._compile (module.js:653:30)
6 verbose cwd /
7 verbose Linux 4.19.57+
8 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.ble@0.7.2" "--production" "--save" "--prefix" "/opt/iobroker"
9 verbose node v8.12.0
10 verbose npm  v6.10.1
11 error Unexpected token :
12 verbose exit [ 1, true ]
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/23887/probleme-multihost-neue-instanzen-von-adaptern</link><generator>RSS for Node</generator><lastBuildDate>Thu, 23 Apr 2026 16:47:44 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/23887.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 Jul 2019 18:43:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Probleme Multihost neue Instanzen von Adaptern on Wed, 17 Jul 2019 19:14:05 GMT]]></title><description><![CDATA[<p dir="auto">Ja, habe ich.</p>
<p dir="auto">Die Instanzen habe ich über den Admin des Masters hinzufügen wollen bzw. auf beide wegen probiert - immer selbe Fehlermeldung.</p>
<p dir="auto">Meine aktuelle Vermutung ist die andere node version (8.12.0 vs 8.14.0).</p>
<p dir="auto"><strong>Edit:</strong> Nach wechsel auf node 8.14.0 auf dem slave scheint die Fehlermeldung verschwunden.</p>
<p dir="auto"><strong>Edit2:</strong> Funktioniert nun wunderbar. Lag also an node 8.12.0 .. bei dem ganzen node-wirr-warr kann man nur verrückt werden ..</p>
]]></description><link>https://forum.iobroker.net/post/282173</link><guid isPermaLink="true">https://forum.iobroker.net/post/282173</guid><dc:creator><![CDATA[cimba007]]></dc:creator><pubDate>Wed, 17 Jul 2019 19:14:05 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme Multihost neue Instanzen von Adaptern on Wed, 17 Jul 2019 18:57:25 GMT]]></title><description><![CDATA[<p dir="auto">Hast du <a href="https://www.iobroker.net/docu/index-24.htm?page_id=3068&amp;lang=de" rel="nofollow ugc">das</a> gelesen?<br />
Ein Slave wird nur mit der Minimalkonfiguration Admin und js-controller erstellt.<br />
Nachdem die Verbindung steht ist der Slave nicht mehr über die IP Adresse erreichbar und nur noch über den Admin des Masters werden Adapter auf dem Slave installiert.</p>
]]></description><link>https://forum.iobroker.net/post/282170</link><guid isPermaLink="true">https://forum.iobroker.net/post/282170</guid><dc:creator><![CDATA[FredF]]></dc:creator><pubDate>Wed, 17 Jul 2019 18:57:25 GMT</pubDate></item></channel></rss>
