<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ioBroker Installation defekt]]></title><description><![CDATA[<p dir="auto">Ich habe mir scheinbar eine meiner ioBroker Installationen zerschossen und kann einige Adapter nicht mehr installieren. Z.B. backitup:</p>
<pre><code>$ ./iobroker add backitup  --host ioBroker
NPM version: 6.9.0
npm install iobroker.backitup@1.1.4 --production --save --prefix "/opt/iobroker" (System call)
Unhandled rejection Error: EACCES: permission denied, mkdir '/home/iobroker'npm ERR! cb() never called!
npm ERR! This is an error with npm itself. Please report this error at:
npm ERR!     &lt;https://npm.community&gt;
host.ioBroker install adapter backitup
NPM version: 6.9.0
npm
NPM version: 6.9.0
ERROR: host.ioBroker Cannot install backitup
ERROR: process exited with code 13
</code></pre>
<p dir="auto">Den Installationsfixer habe ich versucht.</p>
<pre><code>curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/fix_installation.sh | bash -
</code></pre>
<p dir="auto">Hat jemand eine Idee, was zu tun ist?</p>
]]></description><link>https://forum.iobroker.net/topic/23446/iobroker-installation-defekt</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 13:49:01 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/23446.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Jun 2019 12:11:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ioBroker Installation defekt on Tue, 25 Jun 2019 13:43:59 GMT]]></title><description><![CDATA[<p dir="auto">@tom57 Ok dann muss ich mal weiter suchen...</p>
]]></description><link>https://forum.iobroker.net/post/275185</link><guid isPermaLink="true">https://forum.iobroker.net/post/275185</guid><dc:creator><![CDATA[AlCalzone]]></dc:creator><pubDate>Tue, 25 Jun 2019 13:43:59 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker Installation defekt on Tue, 25 Jun 2019 13:42:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alcalzone" aria-label="Profile: AlCalzone">@<bdi>AlCalzone</bdi></a><br />
Habe beim Fixer keine Fehler gesehen. User iobroker wurde angelegt, das home-Verzeichnis nicht.<br />
Ich hatte die npm-Version unter Verdacht und habe verschiedene Versionen ausprobiert. Lag aber nicht daran.</p>
<p dir="auto">Was bei mir nicht funktioniert ist der Umstieg von node 8.14.0 auf 10.14.0 -- jede Menge gyp Fehler !!</p>
]]></description><link>https://forum.iobroker.net/post/275184</link><guid isPermaLink="true">https://forum.iobroker.net/post/275184</guid><dc:creator><![CDATA[tp1de]]></dc:creator><pubDate>Tue, 25 Jun 2019 13:42:46 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker Installation defekt on Tue, 25 Jun 2019 13:36:34 GMT]]></title><description><![CDATA[<pre><code>Linux ioBroker 4.9.0-7-amd64 #1 SMP Debian 4.9.110-3+deb9u2 (2018-08-13) x86_64
</code></pre>
<p dir="auto">Debian-Lite unter Virtual Machine Manager der Synology Diskstation.</p>
]]></description><link>https://forum.iobroker.net/post/275178</link><guid isPermaLink="true">https://forum.iobroker.net/post/275178</guid><dc:creator><![CDATA[tp1de]]></dc:creator><pubDate>Tue, 25 Jun 2019 13:36:34 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker Installation defekt on Tue, 25 Jun 2019 13:36:41 GMT]]></title><description><![CDATA[<p dir="auto">@tom57 sagte in <a href="/post/275173">ioBroker Installation defekt</a>:</p>
<blockquote>
<p dir="auto">Der Fixer hat bei mir den neuen user iobroker angelegt, aber nicht das dazugehörige Home-Verzeichnis !</p>
</blockquote>
<p dir="auto">Was für ein OS hast du?<br />
Im Fixer steht: <code>useradd -m -s /usr/sbin/nologin "$username"</code>, wobei <code>-m</code> dafür sorgt, dass das Home-Verzeichnis angelegt wird. Oder gab es ggf. einen Fehler?</p>
]]></description><link>https://forum.iobroker.net/post/275175</link><guid isPermaLink="true">https://forum.iobroker.net/post/275175</guid><dc:creator><![CDATA[AlCalzone]]></dc:creator><pubDate>Tue, 25 Jun 2019 13:36:41 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker Installation defekt on Tue, 25 Jun 2019 13:32:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alcalzone" aria-label="Profile: AlCalzone">@<bdi>AlCalzone</bdi></a></p>
<p dir="auto">Danke - habe ich geändert. chmod mit 755 - das ist bei einer neueren ioBroker-Instanz auch so (habe ich gerade verglichen).<br />
Einen User iobroker gab es nicht - nur root.</p>
<p dir="auto">Der Fixer hat bei mir den neuen user iobroker angelegt, aber nicht das dazugehörige Home-Verzeichnis !<br />
Danke, das sollte nun auf der Altinstallation wieder ok sein.</p>
]]></description><link>https://forum.iobroker.net/post/275173</link><guid isPermaLink="true">https://forum.iobroker.net/post/275173</guid><dc:creator><![CDATA[tp1de]]></dc:creator><pubDate>Tue, 25 Jun 2019 13:32:42 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker Installation defekt on Tue, 25 Jun 2019 13:18:44 GMT]]></title><description><![CDATA[<p dir="auto">@tom57 sagte in <a href="/post/275142">ioBroker Installation defekt</a>:</p>
<blockquote>
<p dir="auto">ch habe gerade mal das Verzeichnis /home/iobroker als root angelegt und mit chmod -R 777 /home/iobroker alle Rechte manuell vergeben.<br />
Der Fixer scheint dieses Verzeichnis nicht anzulegen bzw. die Rechte zu vergeben. Bisher lief ioBroker ja als root.</p>
</blockquote>
<p dir="auto">Doch tut er. Außer du hattest vorher schon einen User <code>iobroker</code> auf dem System angelegt ohne Home-Verzeichnis.<br />
In <code>/home/iobroker</code> sollte nur der User selbst Zugriff haben:</p>
<pre><code>sudo chown -R iobroker:iobroker /home/iobroker
sudo chmod -R 750 /home/iobroker
</code></pre>
<p dir="auto">Bei 750 bin ich mir nicht ganz sicher, aber das gibt <code>iobroker</code> Vollzugrif, der sekundären Gruppe Lesezugriff und allen anderen wird der Zugriff verboten. Oft wird auch standardmäßig 755 vergeben.</p>
]]></description><link>https://forum.iobroker.net/post/275163</link><guid isPermaLink="true">https://forum.iobroker.net/post/275163</guid><dc:creator><![CDATA[AlCalzone]]></dc:creator><pubDate>Tue, 25 Jun 2019 13:18:44 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker Installation defekt on Tue, 25 Jun 2019 13:11:32 GMT]]></title><description><![CDATA[<p dir="auto">zumindest temporär durch npm - oder?<br />
Es werden Vereichnisse /.npm und .npm/cache angelegt ....</p>
<p dir="auto">ls -al zeigt folgendes Ergebnis im /home Verzeichnis:</p>
<pre><code>drwxrwxrwx  4 root    root    4096 Jun 25 14:31 iobroker
</code></pre>
<p dir="auto">D.h. ich sollte Beitzer und Rechte ändern. Der Fixer macht das nicht.<br />
Wie mach ich das manuell richtig?</p>
]]></description><link>https://forum.iobroker.net/post/275146</link><guid isPermaLink="true">https://forum.iobroker.net/post/275146</guid><dc:creator><![CDATA[tp1de]]></dc:creator><pubDate>Tue, 25 Jun 2019 13:11:32 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker Installation defekt on Tue, 25 Jun 2019 12:51:35 GMT]]></title><description><![CDATA[<p dir="auto">@tom57 sagte in <a href="/post/275142">ioBroker Installation defekt</a>:</p>
<blockquote>
<p dir="auto">Was genau wird nun im (neuen) Home-Verzeichnis des Users iobroker abgelegt?</p>
</blockquote>
<p dir="auto">nichts</p>
<p dir="auto">Der User ist wichtig und die Rechte die er bekommt.</p>
<blockquote>
<p dir="auto">/home/iobroker als root angelegt und mit chmod -R 777 /home/iobroker alle Rechte manuell vergeben.</p>
</blockquote>
<p dir="auto">Das untergräbt die Versuche des Fixers ioBroker sicher zu machen und kann später zu Problemen führen</p>
]]></description><link>https://forum.iobroker.net/post/275144</link><guid isPermaLink="true">https://forum.iobroker.net/post/275144</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Tue, 25 Jun 2019 12:51:35 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker Installation defekt on Tue, 25 Jun 2019 12:45:15 GMT]]></title><description><![CDATA[<p dir="auto">Installationsfixer ist ohne Fehlermeldungen durchgelaufen. Das ist eine alte (&gt; 2 Jahre) ioBroker Installation im Virtual Machine Manager der Diskstation.<br />
Scheint ein Rechte-Problem zu sein.</p>
<p dir="auto">Ich habe gerade mal das Verzeichnis /home/iobroker als root angelegt und mit chmod -R 777 /home/iobroker alle Rechte manuell vergeben.<br />
<p dir="auto">Nun laufen die Adapter-Installationen wieder. <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /></p>
<p dir="auto">Was genau wird nun im (neuen) Home-Verzeichnis des Users iobroker abgelegt? Muss dies gesichert werden, oder bleibt es bei /opt/iobroker ?</p>
]]></description><link>https://forum.iobroker.net/post/275142</link><guid isPermaLink="true">https://forum.iobroker.net/post/275142</guid><dc:creator><![CDATA[tp1de]]></dc:creator><pubDate>Tue, 25 Jun 2019 12:45:15 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker Installation defekt on Tue, 25 Jun 2019 12:33:06 GMT]]></title><description><![CDATA[<p dir="auto">@tom57 sagte in <a href="/post/275125">ioBroker Installation defekt</a>:</p>
<blockquote>
<p dir="auto">Ich habe mir scheinbar eine meiner ioBroker Installationen zerschossen</p>
</blockquote>
<p dir="auto">im worst Case ist die SD-Card defekt.</p>
<blockquote>
</blockquote>
<p dir="auto">Was hat der denn erzählt?</p>
]]></description><link>https://forum.iobroker.net/post/275132</link><guid isPermaLink="true">https://forum.iobroker.net/post/275132</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Tue, 25 Jun 2019 12:33:06 GMT</pubDate></item></channel></rss>
