<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Backitup Problem]]></title><description><![CDATA[<p dir="auto">Hallo, bin Anfänger !<br />
Habe Backitup nach YT installiert.<br />
Möchte Backup auf USB-Stick machen(gesteckt)<br />
USB Stick in Linux integriert.<br />
Backup wird LOKAL erzeugt aber NICHT auf USBStick abgelegt.<br />
Fehlermeldung siehe unten....<br />
Danke vorab !!!</p>
<p dir="auto">![alt text](<img src="/assets/uploads/files/1559713158351-b3fd77b9-3730-4979-a732-a19cecf3ba12-grafik.png" alt="b3fd77b9-3730-4979-a732-a19cecf3ba12-grafik.png" class=" img-fluid img-markdown" /> image url)</p>
<p dir="auto">Gestartet...<br />
Gestartet...<br />
[DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"192.xxxxxxx","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:xx","wolTime":"25","smb":"vers=1.0","sudo":false,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/media/usbdisk/iobroker/standard","dirMinimal":"/media/usbdisk/iobroker/standard","dirTotal":"/media/usbdisk/iobroker/komplett","user":"root","pass":"****"}<br />
[ERROR] [mount] - [undefined mount: only root can use "--options" option</p>
<p dir="auto">[ERROR] [mount] - [IGNORED] Error: Command failed: mount -t cifs -o username=root,password=xxxxxxx,rw,file_mode=0777,dir_mode=0777 <a href="//192.xxxxxxx/media/usbdisk/iobroker/standard" rel="nofollow ugc">//192.xxxxxxx/media/usbdisk/iobroker/standard</a> /opt/iobroker/backups<br />
]]></description><link>https://forum.iobroker.net/topic/22947/backitup-problem</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 03:13:28 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/22947.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Jun 2019 05:50:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Backitup Problem on Mon, 10 Jun 2019 09:03:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hartiman" aria-label="Profile: hartiman">@<bdi>hartiman</bdi></a><br />
Wenn du es auf einen Stick kopieren willst, der lokal an deinem System hängt, muss du in der NAS Einstellungen von backitup nicht cifs sondern copy einstellen.<br />
Im Anschluss noch den direkten Lokalen Pfad zu deinem vom System gemouteten Stick eintragen.<br />
Also als Beispiel /mnt/usbstick/</p>
<p dir="auto">Wichtig ist, das auch Schreibrechte für deinen iobroker User auf dem Stick existieren</p>
]]></description><link>https://forum.iobroker.net/post/269772</link><guid isPermaLink="true">https://forum.iobroker.net/post/269772</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Mon, 10 Jun 2019 09:03:12 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup Problem on Sat, 08 Jun 2019 21:30:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hartiman" aria-label="Profile: hartiman">@<bdi>hartiman</bdi></a> sagte in <a href="/post/268026">Backitup Problem</a>:</p>
<p dir="auto">Hallo, das ist ein wenig untergegangen... In Deinem Log steht ja eigentlich das Problem</p>
<blockquote>
<p dir="auto">mount: only root can use "--options" option</p>
</blockquote>
<p dir="auto">Geh in die Einstellungen des backitup-Adapters, unter dem Punkt "NAS/Copy Einstellungen" den Haken bei "Mount als Root (sudo)" reinmachen. Dann sollte es laufen.</p>
]]></description><link>https://forum.iobroker.net/post/269339</link><guid isPermaLink="true">https://forum.iobroker.net/post/269339</guid><dc:creator><![CDATA[XxJooO]]></dc:creator><pubDate>Sat, 08 Jun 2019 21:30:47 GMT</pubDate></item></channel></rss>
