<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ioBroker startet laufend neu]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
ich bin dabei ioBroker auszuprobieren bzw. wollte es mir mal etwas näher anschauen. Scheinbar scheitere ich schon bei der Installation :(<br />
Hab eine frische Ubuntu VM auf der ich es installieren wollte. Direkt mit dem Installscript von github...</p>
<p dir="auto">node version: v8.10.0<br />
npm version: 3.5.2</p>
<p dir="auto">Initional installation didn't work at all. iobroker threw just errors about missing modules. Reinstalled via<br />
<code>npm install iobroker.js-controller</code></p>
<p dir="auto">After this I was able to start the service and reach the webinterface, except it tried to reload every 10 seconds and was barley usable.</p>
<p dir="auto">syslog is repeating this error:</p>
<pre><code class="language-bash">May  2 12:46:16 iobroker systemd[1]: Started ioBroker Server.
May  2 12:46:16 iobroker bash[5851]: host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
May  2 12:46:17 iobroker bash[5851]: Send diag info: {"uuid":"9b5b7bdc-1551-074b-1b69-28986d0dd3b6","language":"en","country":"Germany","hosts":[{"version":"1.5.7","platform":"Javascript/Node.js","type":"linux"}],"node":"v8.10.0","arch":"x64","adapters":{"admin":{"version":"3.6.0","platform":"Javascript/Node.js"}},"model":"Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz","cpus":1,"mem":8121348096,"ostype":"Linux","city":"Germaringen"}
May  2 12:46:29 iobroker systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
May  2 12:46:30 iobroker systemd[1]: iobroker.service: Failed with result 'exit-code'.
May  2 12:46:30 iobroker systemd[1]: iobroker.service: Service hold-off time over, scheduling restart.
May  2 12:46:30 iobroker systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 10.
May  2 12:46:30 iobroker systemd[1]: Stopped ioBroker Server.
May  2 12:46:30 iobroker systemd[1]: iobroker.service: Failed to reset devices.list: Operation not permitted
</code></pre>
<p dir="auto">Ist der fehler bekannt? Was mache ich falsch? Womöglich nur ein peinlicher anfängerfehler. Aber wie gesagt, ist das erste mal das ich mich mit diesem Projekt auseinandersetze. Danke schonmal :)</p>
]]></description><link>https://forum.iobroker.net/topic/22170/iobroker-startet-laufend-neu</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 23:29:52 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/22170.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 May 2019 14:32:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ioBroker startet laufend neu on Thu, 02 May 2019 15:43:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a><br />
DANKE</p>
<p dir="auto">Ich habe die Anleitung von hier genommen aus den Docs (Schnellstart Linux ...)<br />
Nochmal durchgelesen und festgestellt das es da sogar drinnen steht mit der Version. Sollte die Sachen vielleicht nicht immer so schnell überfliegen. Da es in der Anleitung ebenfalls erwähnt wird...<br />
gehe ich davon aus das node 10.xx auch einwandfrei funktioniert? Habe es jetzt erstmal mit der 8.16 probiert und es sieht soweit ganz gut aus. Im Moment läuft es :)</p>
<p dir="auto">Danke für die schnelle Hilfe.</p>
]]></description><link>https://forum.iobroker.net/post/257572</link><guid isPermaLink="true">https://forum.iobroker.net/post/257572</guid><dc:creator><![CDATA[Amari]]></dc:creator><pubDate>Thu, 02 May 2019 15:43:12 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker startet laufend neu on Thu, 02 May 2019 15:10:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amari" aria-label="Profile: Amari">@<bdi>Amari</bdi></a><br />
Nach welcher Anleitung gehst du vor?</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amari" aria-label="Profile: Amari">@<bdi>Amari</bdi></a> sagte in <a href="/post/257559">ioBroker startet laufend neu</a>:</p>
<blockquote>
<p dir="auto">node 8.10.0 scheint ja die default version zu sein</p>
</blockquote>
<p dir="auto">Die hat ein Speicherleck</p>
]]></description><link>https://forum.iobroker.net/post/257562</link><guid isPermaLink="true">https://forum.iobroker.net/post/257562</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Thu, 02 May 2019 15:10:26 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker startet laufend neu on Thu, 02 May 2019 15:03:51 GMT]]></title><description><![CDATA[<p dir="auto">Ich habe per script installiert. Aber da, da wohl irgendwas schiefgelaufen ist den Controller nochmal mit npm neu. War vielleicht wirklich nicht so gut. Ich teste gerade nochmal auf einem frischen system.</p>
<p dir="auto">Bin dabei gerade nochmal auf das hier aufmerksam geworden. node 8.10.0 scheint ja die default version zu sein wenn ich per apt installiere. Muss ich eine bestimmte Version erzwingen?</p>
<pre><code>WARN engine iobroker@2.0.3: wanted: {"node":"&gt;=8.12"} (current: {"node":"8.10.0","npm":"3.5.2"})
ioBroker needs at least Node.JS 8.12. You have installed 8.10.0
Please update your Node.JS version!
npm ERR! Linux 4.15.18-12-pve
npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "i" "iobroker" "--loglevel" "error" "--unsafe-perm"
npm ERR! node v8.10.0
npm ERR! npm  v3.5.2
npm ERR! code ELIFECYCLE
npm ERR! iobroker@2.0.3 install: `node lib/checkVersions.js`
npm ERR! Exit status 2
</code></pre>
]]></description><link>https://forum.iobroker.net/post/257559</link><guid isPermaLink="true">https://forum.iobroker.net/post/257559</guid><dc:creator><![CDATA[Amari]]></dc:creator><pubDate>Thu, 02 May 2019 15:03:51 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker startet laufend neu on Thu, 02 May 2019 14:47:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amari" aria-label="Profile: Amari">@<bdi>Amari</bdi></a> sagte in <a href="/post/257553">ioBroker startet laufend neu</a>:</p>
<blockquote>
<p dir="auto">Ist der fehler bekannt? Was mache ich falsch? Womöglich nur ein peinlicher anfängerfehler. Aber wie gesagt, ist das erste mal das ich mich mit diesem Projekt auseinandersetze. Danke schonmal</p>
</blockquote>
<p dir="auto">wie hast du den jetzt installiert, per script oder dem NPM Befehl ?</p>
<p dir="auto">Wen du beides gemacht hast sind da jetzt aber Sachen durcheinander, dan empfehle ich dir die machine nochmal neu zu machen und die schritte hintereinander aus zu führen das dürfte keinerlei Probleme geben.<br />
Wen doch bitte direkt wieder melden und nicht mit anderen befehlen die Verzeichnissen umbauen :)</p>
<p dir="auto">Ich habe selber dieses script auf 8 ubuntu Installationen (16.04 und 18.04) erfolgreich ausführen können</p>
<p dir="auto">Greetz,</p>
<p dir="auto">Dutch</p>
]]></description><link>https://forum.iobroker.net/post/257555</link><guid isPermaLink="true">https://forum.iobroker.net/post/257555</guid><dc:creator><![CDATA[Dutchman]]></dc:creator><pubDate>Thu, 02 May 2019 14:47:02 GMT</pubDate></item></channel></rss>
