<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Landroid Adapter - Unexpected token N in JSON at position 0]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">beim Starten des Landroid Adapters bekomme ich immer diese Fehlermeldung.</p>
<pre><code>host.DietPi	2019-04-12 15:23:52.919	info	Restart adapter system.adapter.landroid-s.0 because enabled
host.DietPi	2019-04-12 15:23:52.919	error	instance system.adapter.landroid-s.0 terminated with code 0 (OK)
Caught	2019-04-12 15:23:52.919	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
Caught	2019-04-12 15:23:52.918	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:139:11)
Caught	2019-04-12 15:23:52.918	error	by controller[0]: at endReadableNT (_stream_readable.js:1064:12)
Caught	2019-04-12 15:23:52.918	error	by controller[0]: at IncomingMessage.emit (events.js:208:7)
Caught	2019-04-12 15:23:52.918	error	by controller[0]: at emitNone (events.js:111:20)
Caught	2019-04-12 15:23:52.917	error	by controller[0]: at IncomingMessage.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.landroid-s/lib/mqttCloud.js:278:45)
Caught	2019-04-12 15:23:52.917	error	by controller[0]: at JSON.parse (&lt;anonymous&gt;)
Caught	2019-04-12 15:23:52.917	error	by controller[0]: SyntaxError: Unexpected token N in JSON at position 0
landroid-s.0	2019-04-12 15:23:52.894	info	terminating
landroid-s.0	2019-04-12 15:23:52.883	info	cleaned everything up...
landroid-s.0	2019-04-12 15:23:52.881	error	at process._tickCallback (internal/process/next_tick.js:181:9)
landroid-s.0	2019-04-12 15:23:52.881	error	at _combinedTickCallback (internal/process/next_tick.js:139:11)
landroid-s.0	2019-04-12 15:23:52.881	error	at endReadableNT (_stream_readable.js:1064:12)
landroid-s.0	2019-04-12 15:23:52.881	error	at IncomingMessage.emit (events.js:208:7)
landroid-s.0	2019-04-12 15:23:52.881	error	at emitNone (events.js:111:20)
landroid-s.0	2019-04-12 15:23:52.881	error	at IncomingMessage.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.landroid-s/lib/mqttCloud.js:278:45)
landroid-s.0	2019-04-12 15:23:52.881	error	at JSON.parse (&lt;anonymous&gt;)
landroid-s.0	2019-04-12 15:23:52.881	error	SyntaxError: Unexpected token N in JSON at position 0
landroid-s.0	2019-04-12 15:23:52.880	error	uncaught exception: Unexpected token N in JSON at position 0
landroid-s.0	2019-04-12 15:23:52.568	info	starting. Version 2.5.4 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v8.15.1
landroid-s.0	2019-04-12 15:23:52.288	info	States connected to redis: 127.0.0.1:6379
host.DietPi	2019-04-12 15:23:50.838	info	instance system.adapter.landroid-s.0 started with pid 23132
host.DietPi	2019-04-12 15:23:50.814	info	"system.adapter.landroid-s.0" enabled
host.DietPi	2019-04-12 15:23:50.812	info	object change system.adapter.landroid-s.0
</code></pre>
<p dir="auto">Hintergrundinfos:<br />
Adapter lief letztes Jahr auf dem Pi. Vor kurzem bin ich auf ein Rock64 umgezogen.<br />
Vermute es liegt an dieser Sache "Unexpected token N in JSON at position 0", scheint mir auch nicht spezifisch zu dem Landroid Adapter zu sein.</p>
<p dir="auto">Kann ich das irgendwie fixen?</p>
<p dir="auto">ciao<br />
Martin</p>
]]></description><link>https://forum.iobroker.net/topic/21726/landroid-adapter-unexpected-token-n-in-json-at-position-0</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 13:11:06 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/21726.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Apr 2019 14:39:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Landroid Adapter - Unexpected token N in JSON at position 0 on Sat, 13 Apr 2019 14:52:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/martinschm" aria-label="Profile: martinschm">@<bdi>martinschm</bdi></a> Schau mal hier:</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/21616/landroid-s-adapter-bleibt-rot-gel%C3%B6%C3%9Ft">https://forum.iobroker.net/topic/21616/landroid-s-adapter-bleibt-rot-gelößt</a></p>
<p dir="auto">Gruß</p>
<p dir="auto">Hans-Jürgen</p>
]]></description><link>https://forum.iobroker.net/post/252862</link><guid isPermaLink="true">https://forum.iobroker.net/post/252862</guid><dc:creator><![CDATA[Jack01]]></dc:creator><pubDate>Sat, 13 Apr 2019 14:52:56 GMT</pubDate></item></channel></rss>
