<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fehlermeldungen]]></title><description><![CDATA[<p dir="auto">Hallo,leider bekomme ich neuerdings Fehermeldungen mit denen ich nichts anfangen kann. Hat Jemand eine Idee wie ich das abstellen könnte? Danke für die Hilfe!</p>
<p dir="auto">host.HPMini301	2019-03-13 15:43:06.852	error	instance system.adapter.systeminfo.0 terminated with code 0 (OK)<br />
host.HPMini301	2019-03-13 15:43:06.839	error	Caught by controller[0]: at processImmediate (timers.js:658:5)<br />
host.HPMini301	2019-03-13 15:43:06.839	error	Caught by controller[0]: at tryOnImmediate (timers.js:676:5)<br />
host.HPMini301	2019-03-13 15:43:06.839	error	Caught by controller[0]: at runCallback (timers.js:705:18)<br />
host.HPMini301	2019-03-13 15:43:06.838	error	Caught by controller[0]: at Immediate.&lt;anonymous&gt; (C:\iobroker\node_modules\iobroker.js-controller\lib\adapter.js:3429:38)<br />
host.HPMini301	2019-03-13 15:43:06.838	error	Caught by controller[0]: at Adapter.emit (events.js:189:13)<br />
host.HPMini301	2019-03-13 15:43:06.838	error	Caught by controller[0]: at Adapter.adapter.on.on.on.on.on (C:\iobroker\node_modules\iobroker.systeminfo\myAdapter.js:121:98)<br />
host.HPMini301	2019-03-13 15:43:06.838	error	Caught by controller[0]: TypeError: Cannot read property 'then' of undefined</p>
]]></description><link>https://forum.iobroker.net/topic/20932/fehlermeldungen</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 20:29:09 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/20932.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Mar 2019 14:46:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fehlermeldungen on Wed, 13 Mar 2019 15:41:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nobissoft" aria-label="Profile: Nobissoft">@<bdi>Nobissoft</bdi></a> sagte in <a href="/post/241036">Fehlermeldungen</a>:</p>
<blockquote>
<p dir="auto">War vorab aber nicht</p>
</blockquote>
<p dir="auto">Wann vorher? Was gemacht?</p>
<p dir="auto">Der steht als Beispiel in der Config nach der Installation wenn ich mich nicht täusche.</p>
<p dir="auto">Löschen oder aus kommentieren</p>
<blockquote>
<p dir="auto">Einen HP_Photosmart_7520 habe ich nicht!</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/241056</link><guid isPermaLink="true">https://forum.iobroker.net/post/241056</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Wed, 13 Mar 2019 15:41:10 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen on Wed, 13 Mar 2019 15:39:17 GMT]]></title><description><![CDATA[<p dir="auto">Hier noch ein Auszug...</p>
<pre><code>systeminfo.0	2019-03-13 15:56:02.539	warn	Error TypeError: Cannot read property 'toString' of null in doPoll for HP_Photosmart_7520.[name/value]
systeminfo.0	2019-03-13 15:55:58.828	warn	Error Error: Unexpected close tag Line: 5 Column: 7 Char: &gt; in doPoll for Currency.[currency/rate]
systeminfo.0	2019-03-13 15:55:58.695	warn	Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Red
systeminfo.0	2019-03-13 15:55:58.694	warn	Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Green
systeminfo.0	2019-03-13 15:55:58.476	info	Startup Systeminfo Adapter systeminfo.0: { startup: '#\ngpio mode 1 output\n#rpi: echo none &gt;/sys/class/leds/led0/trigger\necho none &gt;/sys/class/leds/green_led/trigger', items: [ { name: 'System.
systeminfo.0	2019-03-13 15:55:54.141	info	starting. Version 0.2.2 in C:/iobroker/node_modules/iobroker.systeminfo, node: v10.15.2
host.HPMini301	2019-03-13 15:55:52.588	info	instance system.adapter.systeminfo.0 started with pid 5604
host.HPMini301	2019-03-13 15:55:47.302	info	Restart adapter system.adapter.sonoff.0 because enabled
host.HPMini301	2019-03-13 15:55:47.302	error	instance system.adapter.sonoff.0 terminated with code 0 (OK)
host.HPMini301	2019-03-13 15:55:47.302	error	Caught by controller[0]: port: 1883 }
host.HPMini301	2019-03-13 15:55:47.302	error	Caught by controller[0]: address: '0.0.0.0',
host.HPMini301	2019-03-13 15:55:47.302	error	Caught by controller[0]: syscall: 'listen',
host.HPMini301	2019-03-13 15:55:47.302	error	Caught by controller[0]: errno: 'EADDRINUSE',
host.HPMini301	2019-03-13 15:55:47.302	error	Caught by controller[0]: code: 'EADDRINUSE',
host.HPMini301	2019-03-13 15:55:47.302	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
host.HPMini301	2019-03-13 15:55:47.302	error	Caught by controller[0]: at doListen (net.js:1458:7)
host.HPMini301	2019-03-13 15:55:47.302	error	Caught by controller[0]: at listenInCluster (net.js:1325:12)
host.HPMini301	2019-03-13 15:55:47.302	error	Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1277:14)
host.HPMini301	2019-03-13 15:55:47.301	error	Caught by controller[0]: { Error: listen EADDRINUSE: address already in use 0.0.0.0:1883
sonoff.0	2019-03-13 15:55:47.253	error	Error: listen EADDRINUSE: address already in use 0.0.0.0:1883 at Server.setupListenHandle [as _listen2] (net.js:1277:14) at listenInCluster (net.js:1325:12) at doListen (net.js:1458:7)
sonoff.0	2019-03-13 15:55:47.252	error	uncaught exception: listen EADDRINUSE: address already in use 0.0.0.0:1883
sonoff.0	2019-03-13 15:55:46.997	info	starting. Version 2.2.2 in C:/iobroker/node_modules/iobroker.sonoff, node: v10.15.2
host.HPMini301	2019-03-13 15:55:46.104	info	instance system.adapter.sonoff.0 started with pid 6100
host.HPMini301	2019-03-13 15:55:22.580	info	Restart adapter system.adapter.systeminfo.0 because enabled
host.HPMini301	2019-03-13 15:55:22.580	error	instance system.adapter.systeminfo.0 terminated with code 0 (OK)
Caught	2019-03-13 15:55:22.580	error	by controller[0]: at processImmediate (timers.js:658:5)
Caught	2019-03-13 15:55:22.580	error	by controller[0]: at tryOnImmediate (timers.js:676:5)
Caught	2019-03-13 15:55:22.580	error	by controller[0]: at runCallback (timers.js:705:18)
Caught	2019-03-13 15:55:22.579	error	by controller[0]: at Immediate.&lt;anonymous&gt; (C:\iobroker\node_modules\iobroker.js-controller\lib\adapter.js:3429:38)
Caught	2019-03-13 15:55:22.579	error	by controller[0]: at Adapter.emit (events.js:189:13)
Caught	2019-03-13 15:55:22.579	error	by controller[0]: at Adapter.adapter.on.on.on.on.on (C:\iobroker\node_modules\iobroker.systeminfo\myAdapter.js:121:98)
Caught	2019-03-13 15:55:22.579	error	by controller[0]: TypeError: Cannot read property 'then' of undefined
</code></pre>
]]></description><link>https://forum.iobroker.net/post/241038</link><guid isPermaLink="true">https://forum.iobroker.net/post/241038</guid><dc:creator><![CDATA[Nobissoft]]></dc:creator><pubDate>Wed, 13 Mar 2019 15:39:17 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen on Wed, 13 Mar 2019 15:38:03 GMT]]></title><description><![CDATA[<p dir="auto">systeminfo schmeisst auch Fehlermldungen. War vorab aber nicht</p>
<p dir="auto">host.HPMini301	2019-03-13 15:51:23.305	error	instance system.adapter.systeminfo.0 terminated with code 3 (Adapter disabled or invalid config)</p>
<p dir="auto">Hier mal ein Auszug</p>
<pre><code>fritzdect.0	2019-03-13 15:52:03.102	error	Did not get session id- invalid username or password?
fritzdect.0	2019-03-13 15:52:03.102	error	fritzbox returned this "0000000000000000"
fritzdect.0	2019-03-13 15:52:02.857	error	Did not get session id- invalid username or password?
fritzdect.0	2019-03-13 15:52:02.857	error	fritzbox returned this "0000000000000000"
fritzdect.0	2019-03-13 15:52:02.598	error	Did not get session id- invalid username or password?
fritzdect.0	2019-03-13 15:52:02.598	error	fritzbox returned this "0000000000000000"
host.HPMini301	2019-03-13 15:51:23.305	info	Do not restart adapter system.adapter.systeminfo.0 because disabled or deleted
host.HPMini301	2019-03-13 15:51:02.674	info	"system.adapter.systeminfo.0" disabled
host.HPMini301	2019-03-13 15:51:02.674	info	object change system.adapter.systeminfo.0
host.HPMini301	2019-03-13 15:50:51.470	info	Restart adapter system.adapter.systeminfo.0 because enabled
host.HPMini301	2019-03-13 15:50:51.470	error	instance system.adapter.systeminfo.0 terminated with code 0 (OK)
Caught	2019-03-13 15:50:51.470	error	by controller[0]: at processImmediate (timers.js:658:5)
Caught	2019-03-13 15:50:51.470	error	by controller[0]: at tryOnImmediate (timers.js:676:5)
Caught	2019-03-13 15:50:51.470	error	by controller[0]: at runCallback (timers.js:705:18)
Caught	2019-03-13 15:50:51.470	error	by controller[0]: at Immediate.&lt;anonymous&gt; (C:\iobroker\node_modules\iobroker.js-controller\lib\adapter.js:3429:38)
Caught	2019-03-13 15:50:51.470	error	by controller[0]: at Adapter.emit (events.js:189:13)
Caught	2019-03-13 15:50:51.470	error	by controller[0]: at Adapter.adapter.on.on.on.on.on (C:\iobroker\node_modules\iobroker.systeminfo\myAdapter.js:121:98)
Caught	2019-03-13 15:50:51.470	error	by controller[0]: TypeError: Cannot read property 'then' of undefined
systeminfo.0	2019-03-13 15:50:51.387	error	at processImmediate (timers.js:658:5)
systeminfo.0	2019-03-13 15:50:51.387	error	at tryOnImmediate (timers.js:676:5)
systeminfo.0	2019-03-13 15:50:51.387	error	at runCallback (timers.js:705:18)
systeminfo.0	2019-03-13 15:50:51.387	error	at Immediate.&lt;anonymous&gt; (C:\iobroker\node_modules\iobroker.js-controller\lib\adapter.js:3429:38)
systeminfo.0	2019-03-13 15:50:51.387	error	at Adapter.emit (events.js:189:13)
systeminfo.0	2019-03-13 15:50:51.387	error	at Adapter.adapter.on.on.on.on.on (C:\iobroker\node_modules\iobroker.systeminfo\myAdapter.js:121:98)
systeminfo.0	2019-03-13 15:50:51.387	error	TypeError: Cannot read property 'then' of undefined
systeminfo.0	2019-03-13 15:50:51.387	error	uncaught exception: Cannot read property 'then' of undefined
mqtt.0	2019-03-13 15:50:51.389	info	send2Server systeminfo.0.System.Network.Connections.tcp:[2003:e5:83c7:d900:5ce0:6ada:7006:9aff]:61915[systeminfo/0/System/Network/Connections/tcp:[2003:e5:83c7:d900:5ce0:6ada:7006:9aff]:61915]
systeminfo.0	2019-03-13 15:50:41.746	warn	Error TypeError: Cannot read property 'toString' of null in doPoll for HP_Photosmart_7520.[name/value]
systeminfo.0	2019-03-13 15:50:37.908	warn	Char: &gt; in doPoll for Currency.[currency/rate]
systeminfo.0	2019-03-13 15:50:37.908	warn	Column: 7
systeminfo.0	2019-03-13 15:50:37.908	warn	Line: 5
systeminfo.0	2019-03-13 15:50:37.908	warn	Error Error: Unexpected close tag
systeminfo.0	2019-03-13 15:50:37.824	warn	Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Red
systeminfo.0	2019-03-13 15:50:37.823	warn	Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Green
</code></pre>
<p dir="auto">Leider läuft auch die sonoff Instanz nur mit Fehlern.</p>
]]></description><link>https://forum.iobroker.net/post/241036</link><guid isPermaLink="true">https://forum.iobroker.net/post/241036</guid><dc:creator><![CDATA[Nobissoft]]></dc:creator><pubDate>Wed, 13 Mar 2019 15:38:03 GMT</pubDate></item><item><title><![CDATA[Reply to Fehlermeldungen on Wed, 13 Mar 2019 14:49:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nobissoft" aria-label="Profile: Nobissoft">@<bdi>Nobissoft</bdi></a> sagte in <a href="/post/241029">Fehlermeldungen</a>:</p>
<blockquote>
<p dir="auto">systeminfo</p>
</blockquote>
<p dir="auto">Sieht für mich so aus als kommen die vom systeminfo Adapter.</p>
<p dir="auto">Den im ersten Schritt mal deaktivieren und schauen ob es dann aufhört.</p>
]]></description><link>https://forum.iobroker.net/post/241032</link><guid isPermaLink="true">https://forum.iobroker.net/post/241032</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Wed, 13 Mar 2019 14:49:57 GMT</pubDate></item></channel></rss>
