<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Harmony Adapter spinnt]]></title><description><![CDATA[<p dir="auto">Mir macht mein Harmony derzeit kummer. Mal davon abgesehen, dass es eh der einzige Adapter bei mir ist, der ab und an einfach mal am spinnen ist, ist er im Moment zu gar nicht zu gebrauchen. Hier mal was dazu im Log steht:</p>
<pre><code>harmony.0	2018-03-04 18:32:00.018	error	exception by stop: Not running
harmony.0	2018-03-04 18:32:00.018	info	terminating
harmony.0	2018-03-04 18:32:00.017	error	Error: Not running at Socket._healthCheck (dgram.js:541:11) at Socket.close (dgram.js:422:8) at Ping.stop (/opt/iobroker/node_modules/iobroker.harmony/node_modules/harmonyhubjs-discover/li
harmony.0	2018-03-04 18:32:00.017	error	uncaught exception: Not running
harmony.0	2018-03-04 18:32:00.017	info	terminating
harmony.0	2018-03-04 18:32:00.016	info	Scheduled restart.
harmony.0	2018-03-04 18:31:00.020	error	exception by stop: Not running
harmony.0	2018-03-04 18:31:00.019	info	terminating
harmony.0	2018-03-04 18:31:00.014	error	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10)
harmony.0	2018-03-04 18:31:00.014	error	at Job.job (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4644:21)
harmony.0	2018-03-04 18:31:00.014	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4702:18)
harmony.0	2018-03-04 18:31:00.014	error	at Adapter.emit (events.js:188:7)
harmony.0	2018-03-04 18:31:00.014	error	at emitOne (events.js:96:13)
harmony.0	2018-03-04 18:31:00.014	error	at Adapter. (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:147:18)
harmony.0	2018-03-04 18:31:00.014	error	at Explorer.stop (/opt/iobroker/node_modules/iobroker.harmony/node_modules/harmonyhubjs-discover/lib/explorer.js:81:13)
harmony.0	2018-03-04 18:31:00.014	error	at Ping.stop (/opt/iobroker/node_modules/iobroker.harmony/node_modules/harmonyhubjs-discover/lib/ping.js:43:15)
harmony.0	2018-03-04 18:31:00.014	error	at Socket.close (dgram.js:422:8)
harmony.0	2018-03-04 18:31:00.014	error	at Socket._healthCheck (dgram.js:541:11)
harmony.0	2018-03-04 18:31:00.014	error	Error: Not running
harmony.0	2018-03-04 18:31:00.014	error	uncaught exception: Not running
</code></pre>
<p dir="auto">Kann da einer weiterhelfen?</p>
]]></description><link>https://forum.iobroker.net/topic/11330/harmony-adapter-spinnt</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 09:59:29 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/11330.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Mar 2018 17:41:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Harmony Adapter spinnt on Tue, 06 Mar 2018 17:40:09 GMT]]></title><description><![CDATA[<p dir="auto">Ja,</p>
<p dir="auto">das Problem ist das es nicht unbedingt die Entfernumg zur eigenen WLAN Station sein muss.</p>
<p dir="auto">Der Hub lässt sich auch gerne durch andere Netzwerke stören.</p>
]]></description><link>https://forum.iobroker.net/post/137682</link><guid isPermaLink="true">https://forum.iobroker.net/post/137682</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Tue, 06 Mar 2018 17:40:09 GMT</pubDate></item><item><title><![CDATA[Reply to Harmony Adapter spinnt on Tue, 06 Mar 2018 14:03:25 GMT]]></title><description><![CDATA[<p dir="auto">Meiner steht ohne Hindernis 4m von der Fritz weg und sollte somit wohl kein WLAN Problem haben.</p>
<p dir="auto">Im Moment läuft er immer noch ohne Fehler, schon den 2. Tag. Ich hatte gestern mal den npm Cach geleert, seit da kein Problem mehr gehabt. Ob's tatsächlich daran gelegen hat, kein Plan. War eben ein Strohalm und in einem der unzähligen Threads über Probleme mit dem Harmony Hub aufgeführt ;)</p>
]]></description><link>https://forum.iobroker.net/post/137652</link><guid isPermaLink="true">https://forum.iobroker.net/post/137652</guid><dc:creator><![CDATA[Jan1]]></dc:creator><pubDate>Tue, 06 Mar 2018 14:03:25 GMT</pubDate></item><item><title><![CDATA[Reply to Harmony Adapter spinnt on Mon, 05 Mar 2018 20:47:46 GMT]]></title><description><![CDATA[<p dir="auto">Von diesem Problem ist das Forum glaube ich voll.</p>
<p dir="auto">Liegt oft am WLAN da der Harmony Hub da richtig schlecht ist.</p>
]]></description><link>https://forum.iobroker.net/post/137510</link><guid isPermaLink="true">https://forum.iobroker.net/post/137510</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Mon, 05 Mar 2018 20:47:46 GMT</pubDate></item><item><title><![CDATA[Reply to Harmony Adapter spinnt on Mon, 05 Mar 2018 17:46:12 GMT]]></title><description><![CDATA[<p dir="auto">V6.13.0</p>
<p dir="auto">3.10.10</p>
<p dir="auto">und bis auf diesen kleinen Fehler läuft der Adapter im Moment:</p>
<pre><code>harmony.0	2018-03-05 18:05:17.842	info	synced hub config
harmony.0	2018-03-05 18:05:16.817	info	connected to Harmony Hub
harmony.0	2018-03-05 18:05:13.536	info	connecting to Harmony Hub
harmony.0	2018-03-05 18:05:13.430	info	discovered Harmony Hub
harmony.0	2018-03-05 18:04:38.223	warn	lost Harmony Hub
harmony.0	2018-03-05 18:04:35.515	info	client ended: Harmony_Hub
harmony.0	2018-03-05 18:04:35.482	info	keep alive failed: Error: Timed out after 5000 ms
</code></pre>
]]></description><link>https://forum.iobroker.net/post/137440</link><guid isPermaLink="true">https://forum.iobroker.net/post/137440</guid><dc:creator><![CDATA[Jan1]]></dc:creator><pubDate>Mon, 05 Mar 2018 17:46:12 GMT</pubDate></item><item><title><![CDATA[Reply to Harmony Adapter spinnt on Mon, 05 Mar 2018 16:42:17 GMT]]></title><description><![CDATA[<p dir="auto">Welche Node und NPM Versionen hast du installiert?</p>
<pre><code>node -v
</code></pre>
<pre><code>npm -v
</code></pre>
]]></description><link>https://forum.iobroker.net/post/137428</link><guid isPermaLink="true">https://forum.iobroker.net/post/137428</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Mon, 05 Mar 2018 16:42:17 GMT</pubDate></item><item><title><![CDATA[Reply to Harmony Adapter spinnt on Mon, 05 Mar 2018 14:49:22 GMT]]></title><description><![CDATA[<p dir="auto">Wenn ich direkt aus dem IOBroker raus installieren möchte, dann steht das im Log:</p>
<pre><code>iobroker	2018-03-05 15:32:31.575	info	upload [0] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/harmony.png harmony.png image/png
iobroker	2018-03-05 15:32:31.446	info	upload [1] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index.html index.html text/html
iobroker	2018-03-05 15:32:31.418	info	got /opt/iobroker/node_modules/iobroker.harmony/admin
iobroker	2018-03-05 15:32:05.092	info	WARN deprecated node-xmpp-jid@2.3.0: use @xmpp/jid package
iobroker	2018-03-05 15:32:05.086	info	npm
iobroker	2018-03-05 15:31:53.281	info	WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
iobroker	2018-03-05 15:31:53.278	info	npm
iobroker	2018-03-05 15:31:48.615	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.harmony"
iobroker	2018-03-05 15:31:48.605	info	host.RaspberryPi install adapter harmony
iobroker	2018-03-05 15:30:48.043	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
</code></pre>
<p dir="auto">Das ist ja schon mal ein Anhaltspunkt. Bevor ich jetzt weiter mache, wäre mal gut zu wissen, wie ich diese 2Paket aktuell bekomme.</p>
<p dir="auto">Der Harmony Adapter ist jetzt wieder am Laufen und bis jetzt auch ohne Fehler im Log. Mal gespannt wie lange noch :D</p>
]]></description><link>https://forum.iobroker.net/post/137411</link><guid isPermaLink="true">https://forum.iobroker.net/post/137411</guid><dc:creator><![CDATA[Jan1]]></dc:creator><pubDate>Mon, 05 Mar 2018 14:49:22 GMT</pubDate></item><item><title><![CDATA[Reply to Harmony Adapter spinnt on Sun, 04 Mar 2018 19:11:53 GMT]]></title><description><![CDATA[<p dir="auto">Im iobroker logfile steht eigentlich die installation mit drin.</p>
<p dir="auto">Bei mir läuft er zum Glück nach Optimierung des WLAN's zuverlässig.</p>
]]></description><link>https://forum.iobroker.net/post/137205</link><guid isPermaLink="true">https://forum.iobroker.net/post/137205</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Sun, 04 Mar 2018 19:11:53 GMT</pubDate></item><item><title><![CDATA[Reply to Harmony Adapter spinnt on Sun, 04 Mar 2018 19:06:54 GMT]]></title><description><![CDATA[<p dir="auto">Gute Frage, wo wird das denn mit geloggt?</p>
<p dir="auto">Hattest Du mit dem Adapter auch schon Probleme? Ganz sauber lief der bei mir noch nie. Normal hängt er sich einfach auf und reagiert nicht mehr, dass er so viele Fehler produziert ist eher neu.</p>
<p dir="auto">Ich steure damit eigentlich nur mein TV samt Sat und AV Receiver über die im Hub vordefinierte Aktion "Fernsehen". Die wiederum habe ich über Alex in zwei Routinen drin. So hab ich bis jetzt immer gemerkt, wenn der Adapter mal wieder hängt. Alexa schaltet brav alles aus oder an, nur eben den TV nicht. Hier hat dann einfach ein Neustart des Adapter gereicht und er lief wieder eine Weile. Ich hab ihn deshalb schon auf automatisches Neustarten gestellt, hat auch geklappt und lief besser. Dann wollte ich ihn neu installieren und seit dem wird es immer schlimmer.</p>
<p dir="auto">Unterm Strich lief er noch nie wirklich zuverlässig bei mir, nur so schlecht wie jetzt ist eben neu.</p>
]]></description><link>https://forum.iobroker.net/post/137200</link><guid isPermaLink="true">https://forum.iobroker.net/post/137200</guid><dc:creator><![CDATA[Jan1]]></dc:creator><pubDate>Sun, 04 Mar 2018 19:06:54 GMT</pubDate></item><item><title><![CDATA[Reply to Harmony Adapter spinnt on Sun, 04 Mar 2018 18:57:18 GMT]]></title><description><![CDATA[<p dir="auto">Wie sah oder sieht denn das Installations log aus?</p>
<p dir="auto">Ich habe den vor ewigkeiten direkt über iobroker installiert.</p>
]]></description><link>https://forum.iobroker.net/post/137192</link><guid isPermaLink="true">https://forum.iobroker.net/post/137192</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Sun, 04 Mar 2018 18:57:18 GMT</pubDate></item><item><title><![CDATA[Reply to Harmony Adapter spinnt on Sun, 04 Mar 2018 18:53:08 GMT]]></title><description><![CDATA[<p dir="auto">Das sind die Fehler nach der letzten Neuinstallation :lol:</p>
<p dir="auto">Hatte ich mir auch gedacht, da alle anderen Adapter nicht ein Fehler loggen und nur der Harmony rum zickt. Ich hab jetzt mal deinstalliert und mach den morgen wieder drauf. Vielleicht hat er da bessere Laune und läuft mal wieder ein paar Tage ohne ein einzigen Fehler im Log.</p>
<p dir="auto">Zur Neuinstallation, welche Quelle wird hier empfohlen, direkt im IOBroker oder von GitHub?</p>
]]></description><link>https://forum.iobroker.net/post/137187</link><guid isPermaLink="true">https://forum.iobroker.net/post/137187</guid><dc:creator><![CDATA[Jan1]]></dc:creator><pubDate>Sun, 04 Mar 2018 18:53:08 GMT</pubDate></item><item><title><![CDATA[Reply to Harmony Adapter spinnt on Sun, 04 Mar 2018 18:47:46 GMT]]></title><description><![CDATA[<p dir="auto">ich würde den mal löschen und neu installieren.</p>
]]></description><link>https://forum.iobroker.net/post/137179</link><guid isPermaLink="true">https://forum.iobroker.net/post/137179</guid><dc:creator><![CDATA[wendy2702]]></dc:creator><pubDate>Sun, 04 Mar 2018 18:47:46 GMT</pubDate></item></channel></rss>
