Rollosteuerung
Ich bin seit einer Woche neu bei ioBroker und hab das erste Problem
mit dem meinem Programm.
Mein Rollo fährt alle Minute nach unten, kann mir einer helfen.
[spoiler<xml 1999/xmlns="<URL url=" http:/www.w3.org/xhtml"="">http://www.w3.org/1999/xhtml">
<block type="schedule" id="vVGiNXb%+2gtBz#!nYj!" x="-1813" y="-1088"><field name="SCHEDULE">*/1 * * * *</field>
<statement name="STATEMENT"><block type="variables_set" id="H?K%FS!H1KWN?o~hc:BE"><field name="VAR">tmpVar</field>
<value name="VALUE"><block type="math_arithmetic" id="VTY/n[lUUW#(Vj|0Ynf)" inline="false"><field name="OP">ADD</field>
<value name="A"><shadow type="math_number" id="~l^aI8a3}!=VAgd:Sop1"><field name="NUM">1</field></shadow>
<block type="time_get" id=",+W%E7*^NcqRU(29_ahJ"><mutation format="false" language="false"></mutation>
<field name="OPTION">m</field></block></value>
<value name="B"><shadow type="math_number" id="M_(XsL,pqedMFtkdBmzf"><field name="NUM">1</field></shadow>
<block type="math_arithmetic" id="WM%b_D:H}:omQapC*@dP"><field name="OP">MULTIPLY</field>
<value name="A"><shadow type="math_number" id="O)k}t%PQ@LFIbTz!9kvE"><field name="NUM">60</field></shadow></value>
<value name="B"><shadow type="math_number" id="K]d96jp+dotc+:*{OnVQ"><field name="NUM">1</field></shadow>
<block type="time_get" id="PyW{g1{c/)c=^uqaS4?F"><mutation format="false" language="false"></mutation>
<field name="OPTION">h</field></block></value></block></value></block></value>
<next><block type="controls_if" id="=)@o%prK5~F4vWKU~y{6"><mutation else="1"></mutation>
<value name="IF0"><block type="logic_compare" id="92R0Eg|iiU_Y;0kR4ltq"><field name="OP">GT</field>
<value name="A"><block type="variables_get" id="CNA)3)^qESy7(S~V[C{;"><field name="VAR">tmpVar</field></block></value>
<value name="B"><block type="math_number" id="TdkQ43kNKi~(/VatNz%m"><field name="NUM">720</field></block></value></block></value>
<statement name="DO0"><block type="comment" id="vI=#hS-u2IRkF^zU[+6@"><field name="COMMENT">Es geht Richtung Sonnenuntergang</field>
<next><block type="controls_if" id="Kv9Vz_es2+CO;84;n1?g"><value name="IF0"><block type="logic_compare" id="`Vj03xcM9QXdD,3G^OR^"><field name="OP">NEQ</field>
<value name="A"><block type="get_value" id="peIY;XzJz(d|e#Jj)eO*"><field name="ATTR">val</field>
<field name="OID">javascript.0.MinutenSA</field></block></value>
<value name="B"><block type="math_number" id="{Dx^.4n8YxvfO{uRww"><field name="NUM">999</field></block></value></block></value>
<statement name="DO0"><block type="control" id="Ref/|.A#+S[4FOpy!@V+"><mutation delay_input="false"></mutation>
<value name="VALUE"><block type="math_number" id="uMoOUwf)MArjx{bh[UA{"><field name="NUM">999</field></block></value></block></statement>
<next><block type="variables_set" id="73%n,jcZT#5v4UhyMokT"><field name="VAR">tmpVar</field>
<value name="VALUE"><block type="math_arithmetic" id="iw{^B8#6Te[P+8hlz%H!" inline="false"><field name="OP">ADD</field>
<block type="convert_from_date" id="8cA=fum%HkUbz,d,HW2i"><mutation format="false" language="false"></mutation>
<value name="VALUE"><block type="time_astro" id="pyHR=)S0b4-N}}j:|znf"><field name="TYPE">sunset</field>
<field name="OFFSET">0</field></block></value></block></value>
<block type="math_arithmetic" id="d(`jk,nMUkIvoDnNbA)A"><field name="OP">MULTIPLY</field>
<value name="A"><shadow type="math_number" id="Le{m.eM1MnJmG9U=_mP-"><field name="NUM">60</field></shadow></value>
<block type="convert_from_date" id="dU8
E#!{4:UE#UMYwQX
"><mutation format="false" language="false"></mutation><field name="OPTION">h</field>
<value name="VALUE"><block type="time_astro" id="P5CuN,Lp;9|kAnjH]#9r"><field name="TYPE">sunset</field>
<field name="OFFSET">0</field></block></value></block></value></block></value></block></value>
<next><block type="variables_set" id="j6YPcIQeQh@U*ci,A~Vo"><field name="VAR">tmpVar</field>
<value name="VALUE"><block type="math_arithmetic" id="p{)7LYAaH3!|]@uK!f;+" inline="false"><field name="OP">MINUS</field>
<value name="A"><shadow type="math_number" id="rMo/U|,([_+]z-~s,MGy"><field name="NUM">1</field></shadow>
<block type="variables_get" id="GQ1[nGycK0,8b2XvO8AS"><field name="VAR">tmpVar</field></block></value>
<value name="B"><shadow type="math_number" id="My!mMfHGw..Fd%(I[%A1"><field name="NUM">1</field></shadow>
<block type="math_arithmetic" id="8X}}xjrJKyit2iAnC_h`"><field name="OP">ADD</field>
<value name="A"><shadow type="math_number" id="L]]T.y?4xyb|Kw*BT0G7"><field name="NUM">1</field></shadow>
<block type="time_get" id="}n#KTx5=s`@X^S.k6kBR"><mutation format="false" language="false"></mutation>
<value name="B"><shadow type="math_number" id="`Gii1#:=nuCc_%/LwG!m"><field name="NUM">1</field></shadow>
<block type="math_arithmetic" id="83w/4UoLSiURmG1G2N!S"><field name="OP">MULTIPLY</field>
<value name="A"><shadow type="math_number" id="/tkCg?]P4I]r2}m]0)H}"><field name="NUM">60</field></shadow></value>
<value name="B"><shadow type="math_number" id="%dev1yG{WJ{m(0[yTx?z"><field name="NUM">1</field></shadow>
<block type="time_get" id="NaEM`|RE6f:X~?U%?*{f"><mutation format="false" language="false"></mutation>
<field name="OPTION">h</field></block></value></block></value></block></value></block></value>
<next><block type="control" id=",]HLi9UL4?{PDxqY5#+,"><mutation delay_input="false"></mutation>
<field name="OID">javascript.0.MinutenSU</field>
<value name="VALUE"><block type="variables_get" id="|2H*w|X+^cZ^y]]05E3#"><field name="VAR">tmpVar</field></block></value>
<next><block type="controls_if" id=":Rk7e|zp:k|HjB,Klfxm"><value name="IF0"><block type="logic_operation" id="[{CrD%z#Sr~mo1mjmI#Z" inline="false"><field name="OP">AND</field>
<value name="A"><block type="logic_compare" id="u;?`R6fNBun^[z9R)dZ|"><field name="OP">EQ</field>
<value name="A"><block type="get_value" id="8mnt6.FVK8e)fEG;I`^P"><field name="ATTR">val</field>
<field name="OID">piface.0.SW_EG_AUTO</field></block></value>
<value name="B"><block type="logic_boolean" id="a%R0z/J`BY=;Uk=j5@bO"><field name="BOOL">TRUE</field></block></value></block></value>
<value name="B"><block type="logic_operation" id="a|bZRvb?~@hC#`wN{*5/" inline="false"><field name="OP">AND</field>
<value name="A"><block type="logic_compare" id="YutnG8C3wb]{q;XV95Qb"><field name="OP">EQ</field>
<value name="A"><block type="get_value" id="i#^L#o(N].Fwhzr^Y@38"><field name="ATTR">val</field>
<field name="OID">piface.0.OUT1</field></block></value>
<value name="B"><block type="logic_boolean" id="=Cp/;xV!jt*xvTRP7+2V"><field name="BOOL">FALSE</field></block></value></block></value>
<value name="B"><block type="logic_compare" id="T7E8WRVClsiMtQ8oZ=ne"><field name="OP">EQ</field>
<value name="A"><block type="get_value" id="?M4c-0jbggWS%=wlgZgo"><field name="ATTR">val</field>
<field name="OID">piface.0.OUT0</field></block></value>
<value name="B"><block type="logic_boolean" id="Z0|uwXl1Fq4s1YU%s^"><field name="BOOL">FALSE</field></block></value></block></value></block></value></block></value>
<statement name="DO0"><block type="control" id=",xE99l/yclYdJ)57]NE_"><mutation delay_input="false"></mutation>
<value name="VALUE"><block type="logic_boolean" id="~YU;sFTS]cp+d^tUN1m5"><field name="BOOL">TRUE</field></block></value>
<next><block type="control" id="*[Y8SeF(hxHS-4T]2Ob^"><mutation delay_input="true"></mutation>
<field name="DELAY_MS">20</field>
<field name="CLEAR_RUNNING">TRUE</field>
<value name="VALUE"><block type="logic_boolean" id="E[K!hhCz+-Xi-}|V4xEN"><field name="BOOL">FALSE</field></block></value>
<next><block type="email" id="2]WKNLGmO-benvMZ.6]M"><field name="IS_HTML">FALSE</field>
<value name="TO</field></shadow></value>
<value name="TEXT"><shadow type="text" id="4x9V-+r3dY.?sp{]giOK"><field name="TEXT">Rollo ZU EG</field></shadow></value>
<value name="SUBJECT"><shadow type="text" id="R:lki~i9rN!{Fbb)+1"><field name="TEXT">Hausautomation</field></shadow></value></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block></next></block></statement>
<statement name="ELSE"><block type="comment" id="2;aVyVfs/@Rm`vz7(3lW"><field name="COMMENT">Es geht Richtung Sonnenaufgang</field>
<next><block type="controls_if" id="N^;]Z=S2,tiR#A-GsPsQ"><value name="IF0"><block type="logic_compare" id="0:yF^_8V+hV~~),`(k96"><field name="OP">NEQ</field>
<value name="A"><block type="get_value" id="rnw{5e)9q+rqIxRJ[jCt"><field name="ATTR">val</field>
<field name="OID">javascript.0.MinutenSU</field></block></value>
<value name="B"><block type="math_number" id="1AaL1SJ(by.q~0GF~T8y"><field name="NUM">999</field></block></value></block></value>
<statement name="DO0"><block type="control" id="|U+jeT{^16)(S5/x-IZX"><mutation delay_input="false"></mutation>
<value name="VALUE"><block type="math_number" id="?s_-ddzS,(Zx}=^v,rz="><field name="NUM">999</field></block></value></block></statement>
<next><block type="variables_set" id="+Bt:J8ktjNo^pdEc%[7G"><field name="VAR">tmpVar</field>
<value name="VALUE"><block type="math_arithmetic" id="M8(gKAhXzx,j}Bs!inxU" inline="false"><field name="OP">ADD</field>
<block type="convert_from_date" id="![*8.7d^6ee,z,|%9k8Z"><mutation format="false" language="false"></mutation>
<value name="VALUE"><block type="time_astro" id="!bNua++5@e)Lt=M)7U`9"><field name="TYPE">sunrise</field>
<block type="math_arithmetic" id="oGtre7X~N[zOCGz28evg" inline="false"><field name="OP">MULTIPLY</field>
<value name="A"><shadow type="math_number" id="{5jN@VsX#]zkJ,O4jlDJ"><field name="NUM">60</field></shadow></value>
<block type="convert_from_date" id="z#VJzaape6]#JqC+VCzH"><mutation format="false" language="false"></mutation>
<value name="VALUE"><block type="time_astro" id="myW^hNV-B%jT}ZP!LefT"><field name="TYPE">sunrise</field>
<next><block type="variables_set" id="N#n9QcDlh;D;nL#i1s[0"><field name="VAR">tmpVar</field>
<value name="VALUE"><block type="math_arithmetic" id="0K`.;3ARV[V{1F)IZPHH" inline="false"><field name="OP">MINUS</field>
<block type="variables_get" id="8,-HZjVcS_FAG`b5M?BR"><field name="VAR">tmpVar</field></block></value>
<block type="math_arithmetic" id="(G@z=!!JnAJL0UL6F/*`"><field name="OP">ADD</field>
<block type="time_get" id="pUt?i=.X~7J3wKd0F)3f"><mutation format="false" language="false"></mutation>
<block type="math_arithmetic" id="uQtVMZ]]e4pn3W.i#|{6"><field name="OP">MULTIPLY</field>
<value name="A"><shadow type="math_number" id="~ROv;)8R`+7oCPO2II{V"><field name="NUM">60</field></shadow></value>
<block type="time_get" id="DKf;eubDY{F0[(|9s`l|"><mutation format="false" language="false"></mutation>
<next><block type="control" id="eDM:0@yO~X07NkL_WJ54"><mutation delay_input="false"></mutation>
<value name="VALUE"><block type="variables_get" id="}W1zELgv,/1EGvhgJ0{V"><field name="VAR">tmpVar</field></block></value></block></next></block></next></block></next></block></next></block></statement></block></next></block></statement></block>
<block type="on" id="~Q]qBQC7}ajvI}E9k#qW" x="-1812" y="263"><field name="OID">piface.0.IN0</field>
<statement name="STATEMENT"><block type="comment" id="9TKQnU5_i+`P08%@81O4"><field name="COMMENT">Rollo ueber Taster</field>
<next><block type="controls_if" id="2^|#.N@GK|ZGA(oE4DWk"><mutation elseif="1" else="1"></mutation>
<value name="IF0"><block type="logic_operation" id="I:[h5I(ci;em=~wk5yqX" inline="false"><field name="OP">AND</field>
<value name="A"><block type="logic_operation" id="XmEAkf3nOr4;04R]%Zn5" inline="false"><field name="OP">AND</field>
<value name="A"><block type="logic_compare" id="Sy17`:^=V5^[l^!tD…"><field name="OP">EQ</field>
<value name="A"><block type="get_value" id="=+|Y
QF
~5+4v[=5(Xwa"><field name="ATTR">val</field><field name="OID">piface.0.SW_EG_AUTO</field></block></value>
<value name="B"><block type="logic_boolean" id="u8Pg?)cqF7Rc8l8@zo/W"><field name="BOOL">FALSE</field></block></value></block></value>
<value name="B"><block type="get_value" id="7ZEO_82p9yTl9wa.ffFK"><field name="ATTR">val</field>
<field name="OID">piface.0.IN0</field></block></value></block></value>
<value name="B"><block type="logic_operation" id=")A%rTvF_L8_1,r{Uij9x" inline="false"><field name="OP">AND</field>
<value name="A"><block type="logic_compare" id="`UyJC_#)lX?HJfPplj~Q"><field name="OP">EQ</field>
<value name="A"><block type="get_value" id="2)iBDLWcp6ptst7e7iUJ"><field name="ATTR">val</field>
<value name="B"><block type="logic_boolean" id="r)#@brzhzs%=F/6tn`KG"><field name="BOOL">FALSE</field></block></value></block></value>
<value name="B"><block type="logic_compare" id="]`SxfR{xo(x{0SMafUh:"><field name="OP">EQ</field>
<value name="A"><block type="get_value" id="~;0vvk+LpQ%qtzV.0#(q"><field name="ATTR">val</field>
<value name="B"><block type="logic_boolean" id="d236jt5{=G0ak.0v`QxZ"><field name="BOOL">FALSE</field></block></value></block></value></block></value></block></value>
<statement name="DO0"><block type="control" id="qW_n2@L`Sv~!4O{Z8vv5"><mutation delay_input="false"></mutation>
<value name="VALUE"><block type="logic_boolean" id="DAA4}hh=7##jaL2xjI-o"><field name="BOOL">TRUE</field></block></value></block></statement>
<value name="IF1"><block type="logic_operation" id="}1mWSyDqh;aD7Dz_]OD#" inline="false"><field name="OP">AND</field>
<value name="A"><block type="logic_operation" id=",oN@Cz1GYen4h~cov}Ky" inline="false"><field name="OP">AND</field>
<value name="A"><block type="logic_compare" id="V-MIKN]QBzlGmE4;^D7A"><field name="OP">EQ</field>
<value name="A"><block type="get_value" id="@2p)0PL[rJfL^~FuNa5S"><field name="ATTR">val</field>
<value name="B"><block type="logic_boolean" id="R_.-K@uO19651m[WZ[i5"><field name="BOOL">TRUE</field></block></value></block></value>
<value name="B"><block type="get_value" id="6*@-hzhG:m/pYteD)Mt%"><field name="ATTR">val</field>
<value name="B"><block type="logic_compare" id=",x+f0OFT;}4?l)H)uPzd"><field name="OP">EQ</field>
<value name="A"><block type="get_value" id="QpEO6Vf,MXEMRf-JO7^."><field name="ATTR">val</field>
<value name="B"><block type="logic_boolean" id=";L*K`|kL6VKG824~{b;h"><field name="BOOL">FALSE</field></block></value></block></value></block></value>
<statement name="DO1"><block type="control" id="Ag(uwo(|f*IXn5k,4V,|"><mutation delay_input="true"></mutation>
<field name="DELAY_MS">1000</field>
<field name="UNIT">ms</field>
<value name="VALUE"><block type="logic_boolean" id="Sd)2s7[_82%)1Uyr:vAV"><field name="BOOL">FALSE</field></block></value></block></statement></block></next></block></statement></block></xml> ]
4473_rollo_steuerung_m_fehler.txt
4473_rollo_steuerung_m_fehler.txt -
Hallo und Willkommen im Forum!
Code bitte hier im Forum in dem Post einbinden unter Benutzung der Code-Tags, ggf. auch noch Spoiler-Tags.
Rainer
Hallo RaimundV
Du hast das Script "Dynamischer Sonnenauf- und Sonnenuntergang" etwas falsch eingesetzt.
An dem Script sollte man nicht rum bauen.
Lass das Script so laufen wie es ist.
Triggern musst Du dann nur "MinutenSA" und/oder "MinutenSU"
Und dann Aktionen ausführen. Ist in dem Thread aber auch noch beschrieben.
Grüße
Das Skript ist wieder Original.
Globale Variablen "MinutenSA und MinutenSU der WERT ist unter "Objekte" rot bei Bestätigt steht fase.
Kann das sein das der Wert nicht im Skript läuft.
Hallo
MinutenSA / SU über das Script anlegen lassen?
(javascript.0.MinutenSA / javascript.0.MinutenSU)
Das Script 2x starten. Beim ersten Mal werden die Variablen angelegt.
Beim zweiten Start sind die dann im Script bekannt.
Blockly nicht unter "global" gespeichert?
Grüße
wie kann ich sehen da Blockly nicht unter "global" gespeichert ist
Siehe Screenshot, wo hier Common steht darf kein Global stehen
~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201712 ... 05c405.jpg">https://uploads.tapatalk-cdn.com/20171210/5e9ef7bf510b980ee3dcdea31505c405.jpg</link_text>" />
Send from mobile device~~
